Tyredog review
Discussion in 'Australian Motorcycles' started by VTR250, Nov 24, 2010.
  1. VTR250
    VTR250 Guest
    Tyredog Wireless Tire Pressure Monitoring System WTPMS TD-4000A-X
    Acquired mine in July 2009. Now it's December 2010. I'm happy with
    it, but that might be because I had very low expectations to start
    with. For your $269 you get two fancy dust caps (weighing 10 g each)
    and a keychain fob, the monitor, which has an LCD screen and takes 1
    AAA battery.
    An English version of the manual is available on-line from the TyreDog
    website. That helps A LOT!
    One thing that was annoying: the battery cover for the monitor
    wouldn't fit on properly... until I worked out how the cover works.
    There is a 'L' shaped groove running along the entire length of the
    battery section, so you have line up the cover plate with the end of
    the groove and slide it in a straight line along the full length (a
    bit like threading a curtain on to a track), and then slide the end-
    tab into/under the main body. The cover will not snap onto the 'L'
    shaped groove if you only engage the end tab and press it down. I
    think this complicated, tight-fitting design is an attempt at making
    the seal water resistant.
    The monitor must not get wet. I've lengthend the chain by about 3-4
    cm using a bit of unused something that came with a phone I think, so
    at least I can unclip it when it's rainy. It doesn't hang down from
    the ignition any more but I can stick it on top of the fork cap bolt.
    I stuck a small magnet to the back to keep it in place where I can
    read it.
    If I turn it on for 40 mins, twice a day, 5 days a week, the battery
    is flat within 2 weeks on this one. How long would you expect a radio
    to last on an AAA? About the same. According to the manual, it
    should last 6 months! It would be nice to have continuous TPM while
    I'm on the road. Instead, to extend the battery life, I turn it on,
    wait for both tyres to fill in and turn it off. In other words I
    check my tyre pressure daily as part of my starting routine.
    Another minor annoyance: when the battery is changed all settings
    revert to their defaults. This is OK if your tyres are inflated to 30
    psi front and back and a high pressure warning at 40 psi, not so good
    if you want 33/36 etc.
    As long as a charged battery is installed, the TyreDog retains the
    readings it was showing when it was last turned off. You can tell if
    the readings have updated because there are LCD segments filling the
    motorcycle tyres on the display. If the tyre is black, the TD has
    picked up a reading on that tyre; if it is clear it has not. The TD
    takes 1 minute to initialise.
    When it has finished initialising, and is listening for tranmissions,
    an antenna symbol starts flashing on the display, and you can expect
    tyre readings front and back within 2 minutes. NB: If you attach the
    tyre sensor when the TD is up and running you will get a reading for
    that tyre immediately.
    As tyres deflate slowly over a long time, they need to be checked and
    adjusted once in a while anyway. I have done this a number of times
    and the TPMs are reading consistently correct as far as I can tell. I
    have also had a TD low pressure warning after a period of not riding
    the bike.
    The acid test: several days ago a cardboard box of screws bounced off
    the back of a truck travelling at 100 kph, and burst on impact,
    scattering screws across the freeway. One minute later I rode over
    the same patch. There were too many screws on the ground to steer
    around but I REALLY tried! The TPM confirmed that I had picked up
    screw on the rear tyre: I knew it should have been reading 49 PSI from
    previous experience, but was on 38. The extra information I had from
    the TPM stopped me from going at 100 kph as if nothing was wrong, but
    when thinking about what to do, it also helped me plan which option to
    take. I decided to take the shortest route to my dealer. I rolled
    onto their forecourt on 30 PSI, and used their loan bike while they
    plugged the tyre. This diversion delayed me by 20 minutes. I feel
    lucky because I did't have roadside assist and I could have been stuck
    at the roadside for hours if I had tried to press on to my
    destination.
    How do they die? Well think the sensors are not supposed to be taken
    over a certain speed (well over 110 kph). Replacement sensors are $99
    so look after them! My front sensor normally gives a reading with 2
    minutes, but recently my rear sensor does not give a reading for 15-20
    minutes, sometimes as long as 40 minutes. I have changed the battery
    and it hasn't made any difference; however, when I got a puncture, the
    readings came in frequently.
    Is it worth it? Yes I think I'm OK with what I paid for it actually.
    It's not cheap to buy, but I can imagine it's not cheap to design and
    make either. I found a nail in the car tyre today and now I'm
    thinking of getting one for the car too.
  2. In aus.motorcycles on Wed, 24 Nov 2010 03:47:58 -0800 (PST)
    But having had this experience you are going to get a tubeless tyre
    repair kit so you can fix a puncture yourself, right?
    Zebee
    Zebee Johnstone, Nov 24, 2010
  3. VTR250
    VTR250 Guest
    Funny you should say that! There are some $15 kits in Supacheap
    Auto. You have several sticks of rubber that look like lollies, a
    tube of rubber cement and a kind of awl or something to get it into
    the tyre. Have you ever used one of these kits? I think this will be
    OK but I don't know if I can trust it.
  4. In aus.motorcycles on Wed, 24 Nov 2010 13:45:54 -0800 (PST)
    Haven't use a Supercheap one but have used one bought at MCA. Tyre
    did some 10,000km on the repair, which was needed because I picked up
    a bloody great screw.
    They are fairly easy to use.
    I carry a 12v air pump with the plastic removed under the seat in the
    Noggie, the Mighty Scooter has a hand pump that can also take CO2
    cartridges and I have a few of those for it.
    Zebee
  5. VTR250
    Theo Bekkers Guest
    You guessed wrong. New BMWs have run-flat tyres. I believe you can run the
    tyre deflated at up to 80km/h for 50-100 kms.
    Theo
    Theo Bekkers, Nov 24, 2010
  6. VTR250
    atec77 Guest
    Yes but only to the change of rims arrives , run flats cost silly $ and
    can't be trusted
    atec77, Nov 25, 2010
  7. VTR250
    Theo Bekkers Guest
    Agreed. I didn't say I thought it was a good idea, only what it is.
    Theo
    Theo Bekkers, Nov 25, 2010
  8. VTR250
    atec77 Guest
    Major reason being cost , used steel wheel off holden and tyre to suit
    bimmer $50.00 , runflat $195.00 (235x40x18)
  9. Half your luck. : )
    Fraser
    Fraser Johnston, Nov 25, 2010
  10. In aus.motorcycles on Thu, 25 Nov 2010 10:01:02 +0800
    I ride a Norge, clearly cause and effect.
    So if you want that, you need a Guzzi you do!
    Zebee
    Zebee Johnstone, Nov 25, 2010
  11. Maybe in a car Theo, but I would bet you wouldn't be able to on a bike
    George W Frost, Nov 25, 2010
  12. VTR250
    G-S Guest
    You can get run flat off road tyres for dirt bikes.
    G-S
    G-S, Nov 25, 2010
  13. True Nev, so true and that was very perceptive of you to notice that.
    But, in hindsight, you may look at the newsgroup this is posted in and lo
    and behold ....
    TA.....DA !!
    it is Aus. Motorcycles
    And seeing that the Good Theo,
    posts articles in Aus.motorcycles and in fact,
    does have motorcycles himself,
    then I had to comment with tongue in cheek about running a flat on a bike
    But, you, Nev, come in with all guns blazing criticizing me for mentioning
    it
    Thanks Nev, what would the world do without your vigilance.
    By the way,
    I think that your ammunition needs a better primer
    that one went off with a fizz
  14. VTR250
    Theo Bekkers Guest
    My son's car did not have a spare. It came instead with a can of pump in
    sealer and an air compressor built into the car. They did say, don't bother
    with that, just call us.
    Theo
  15. VTR250
    VTR250 Guest
    When did this happen? What make and model?
    VTR250, Nov 25, 2010
  16. VTR250
    Theo Bekkers Guest
    When did what happen? The BMW 320d I purchased three years ago came with
    run-flat tyres. The son's car was a 2007 Mercedes 350SL.
    Theo
    Theo Bekkers, Nov 26, 2010
  17. So you could spruce up for the tow truck driver?
    George W Frost, Nov 26, 2010
  18. VTR250
    knobdoodle Guest
    I've had other people use them on my bike but the kit I bought has
    only been used on my wife's car so far [touch wood] .
    Clem
    (I bought the little CO2 cylinders too but I've yet to use one)
    knobdoodle, Nov 26, 2010
  19. VTR250
    J5 Guest
    run flat tyres
    J5, Nov 26, 2010
  20. VTR250
    J5 Guest
    moose tubes ??
    J5, Nov 26, 2010
