Tyres for SO Italian bikes.
Discussion in 'Classic Motorcycles' started by Eiron, May 18, 2007.
  1. Eiron
    Eiron Guest
    What's good and sticky these days in the old Italian standard sizes,
    100/90-18 and 110/90-18 or 120/80-18, H or V rated?
    Eiron, May 18, 2007
  2. Eiron
    JB Guest
    Tubed or Tubeless? I have used Maxis with a tube in my Guzzis and they are
    excellent. I used to use Pirelli Phantoms or BT45 but the Maxis seem just as
    good wet or dry.
    JB
    JB, May 18, 2007
  3. Eiron
    Gyp Guest
    Continental TKV11 &TKV12 would get my vote?
    Gyp, May 18, 2007
  4. Eiron
    Eiron Guest
    Tubed. It has BT35F/BT45R currently, which seem OK.
    Eiron, May 18, 2007
  5. I've got a conti supertwin on the SOBoxer, seems a good tyre. Conti Blitz
    on the front.
    Austin Shackles, May 18, 2007
  6. Eiron
    Gyp Guest
    I've not tried the supertwin, but the Blitz id as hard as rock
    Gyp, May 18, 2007
  7. Eiron
    Gyp says...
    I had those years ago on a GSX750EFE, they were of limited use back in
    the late 80s.
    Lozzo
    Suzuki SV650 K3
    Suzuki GSX-R750L
    Yamaha 250 Flat-tracker
    I ride way too fast to worry about cholestorol.
    Lozzo, May 18, 2007
  8. Eiron
    Mark Olson Guest
    Yep. Contis were the only tire that ever scared me on my KZ750E2.
    Ditched them immediately for a Metzeler ME33/ME99A combo.
    Mark Olson, May 18, 2007
  9. Eiron
    Gyp Guest
    I'm surprised. Agreed the Conti TK tyres are scary, but I've never had
    any problems with the TKVs
    Gyp, May 18, 2007
  10. Eiron
    Gyp says...
    I hated them when I had the GSX, which was 1987 and I can't for a moment
    think they've got any better over the last 20 years. Move with the
    times, Gyp - forget all the old shite you thought was good in its day
    and buy stuff that works instead. I know this would mean throwing the
    entire contents of your garage on eBay and looking at buying..shock,
    horror...modern tyres etc, but you'll thank me for it, really you will.
    Lozzo
    Suzuki SV650 K3
    Suzuki GSX-R750L
    Lozzo, May 18, 2007
  11. Eiron
    Gyp Guest
    Oh, I'm happy to move with the times and if there's better tyres out
    there I'll happily give them a try.
    Thing is, having tried the Metz 33/99 combo in the past I preferred the
    Contis
    So if I am to move with the times what's the best in
    90/90H18 & 120/90H18 (R80)
    3.25H18 & 4.00H18 (R65)
    100/90H19 & 130/90H16 (the other one)
    Gyp, May 18, 2007
  12. Eiron
    Mark Olson Guest
    It was 20 years ago so I'm a bit hazy on the odd consonant, but I do
    remember they were Conti TK<mumbles> and were touted as being high
    performance tires. Once bitten, twice shy.
  13. Eiron
    Gyp says...
    Honestly, for those kind of sizes and the bikes you run I'd say Maxxis.
    I know they used to be called Cheng Shin, but they've had a massive
    injection of money from a European company, I think it's Du Pont, and
    their tyres are really quite good now.
    They may be at the budget end of the market, but the Barracudas I fitted
    to the CB250RS were absolutely excellent. I replaced the rear with a
    cheaper and harder Hi-Max, and even though it lasted well over 10,000
    miles it still gripped well enough to scrape the exhaust. The Barracudas
    were astonishing in the wet.
    If you still don't trust Taiwanese tyres then I'd go with Bridgestone
    BT45s or similar.
    Lozzo
    Suzuki SV650 K3
    Suzuki GSX-R750L
    Lozzo, May 18, 2007
  14. I'd agree. I've bought them, and they're remarkable VFM, and *way*
    better than the Dunlops and Avons and Pirellis of the SOB era.
    The Older Gentleman, May 18, 2007
  15. Eiron
    Gyp Guest
    I had Cheng Shin on my Bantam, and they couldn't handle the power of
    either the engine or the brakes. Bettering them would not be hard!
    I like astonishing in the wet.
    I'll definitely consider them, though on the Beemer I'm tempted to work
    on the basis that as the Contis have not let me down in the last 18
    years (the only time I've had slides was when I swapped temporarily to
    Pirellis) they have my confidence, which is a very important thing as I
    corner like a girl at the best of times.
    Then again, perhaps if I put them on one Beemer to start with... I take
    it that the Maxxis are err competitively priced?
    The Dunlops on the Hardley are absolute poo though, and Bridgestone
    strangely don't have a fitment for any Harleys. The Avon Venoms get a
    good write up though
    Gyp, May 18, 2007
  16. Eiron
    On my Moto Guzzi Bridgestone grip well but only last 4000 miles.
    Metzlers grip well, are good in the wet and have so far made it past 4000
    miles. Steering seems even slower though.
    Contis are ok but drop off (eek) when worn out in the wet.
    I have run Michelins in the past. They weren't that bad but not
    impressive and cost the same as the others.
    Avon Roadrunners worked ok on my old Suzuki GS550/GS750s but never had
    them on anything with any power, handling ability or brakes.
    sweller, May 27, 2007
  17. Eiron
    Have to agree than Bridgestone BT45's, old tech though they are, grip
    incredibly well. They are quite soft and the fronts do wear in irregular
    patterns so its only 2 to 1 against rear replacements. For a SOB like my
    beemer said mileage is hardly a problem.
    I just put one on the front of an HD1200 Sportster, 21 inch. It was able to
    perform most un-HD like manoevers!
    Hog, May 28, 2007
