Tyres II
Discussion in 'UK Motorcycles' started by ginge, Aug 7, 2009.
  1. ginge
    ginge Guest
    Remind me, is it better to have softer rubber on the front than the
    back, and never the other way around, yes?
    Got a plan for tomorrow to get a new front qualifier II for the 10R,
    and at the same time cascade the half worn one down onto the ZRX to
    replace the absolutely knackered front azaro. I know mixing tyres
    isn't the cleverest thing to do, but given the ZRX is a stable old bus
    a sticky front should be good for the rest of the year, I'd have
    thought.
    Opinions?
    ginge, Aug 7, 2009
  2. Using the patented Mavis Beacon "Hunt&Peck" Technique, ginge
    The way you ride it will make no difference.
    What? WHAT? You asked!
    go and talk to the Catholics.
    Wicked Uncle Nigel, Aug 8, 2009
  3. ginge
    Should've emailed TOG. He's the expert...
    wessie, Aug 8, 2009
  4. ginge
    It has to be better than whatever you were riding on back from Chimay.
    ogden, Aug 8, 2009
  5. ginge
    ginge Guest
    Christ yes, I had no confidence in that front once the roads got damp.
    Think I'll give it a try. It's not going to cost much to get it fitted
    to the loose wheel if I strap it on the pillion seat and take it with
    me.
    ginge, Aug 8, 2009
  6. ginge
    Colin Irvine Guest
    I've always understood this to be the case, but particularly so in
    cars where a rear-wheel skid is easier to control than a front-wheel
    skid.
    On a bike it doesn't seem quite so obvious to me. Whilst I can see
    that you may have more control of a bike if the rear wheel loses grip
    momentarily as compared to the front wheel, a front wheel giving way
    will ultimately result in a low-side whereas with losing a rear wheel
    you can end up with a high-side. The former (i.e. harder front tyre)
    is, I imagine, less likely to do you damage.
    Having hypothesised I now look forward to SWK giving you the right
    answer.
    Colin Irvine, Aug 8, 2009
  7. ginge
    I had zero confidence in those Corsa 3s (have I mentinoed yet how much I
    hated them) towards the end, especially after having the front end tuck
    under. Whereas these Road 2s, hell, I'd marry them. And their sister.
    Why not take the wheels off the 10R as well and put them all in the car?
    ogden, Aug 8, 2009
  8. ginge
    DozynSLeepy Guest
    If this is an economy thing, as in you've already helped to kick start
    the economy and now the bailiffs are kicking down your door to reclaim
    their 40" flat screen TV, then yes, it's a good plan.
    DozynSLeepy, Aug 8, 2009
  9. ginge
    You're looking at minimising the damage after the horse has bolted, so
    to speak. I'd rather not have the horse bolt in the first place.
    The only time the front really takes any load is under braking, whereas
    the rear takes a hammering every time you open the throttle. So you want
    a soft front and hard rear. And, as you say, the rear is generally easy
    to recover when it lets go but when the front goes you're pretty much
    fucked. So you want a soft front and a hard rear.
    In short, you want a soft front and a hard rear.
    ogden, Aug 8, 2009
  10. ginge
    ginge Guest
    I'll probably put those on the ZRX next time out, but there's a rear
    azaro to kill off first - they don't have the 190/55 size the 10r uses
    in less than a pilot power it seems.
    I've only got one (borrowed) front paddock stand, and it doesn't fit
    the 10R forks, plus my feeble allen key doesn't want to shift the
    calliper bolts, so I'll let sonmeone else loosen it all first time
    out. It'll be easy enough to strap the wheel to the pillon seat, I
    reckon.
    ginge, Aug 8, 2009
  11. ginge
    ginge Guest
    It's more a case of wanting to put the best rubber on the 10R, whilst
    the workhorse ZRX just needs a new tyre good enough for a bit of
    commuting and nipping to the shops on.. it's either going to get the
    hand down or wait until next month's pay packet, as this months is
    going on a europe trip..
    ginge, Aug 8, 2009
  12. ginge
    Don't you believe it. Basic fizzix, innit: you need the centre of the
    loas supported, or it'll feel 'orrible - even if it doesn't fall off
    it'll feel like it's going to. Problem is that by the time you've
    installed a rider there isn't enough length in the average pillion perch
    to take half a wheel (anna bit for comfort).
    Trust me, it's a **** sight easier to lob it in the boot of a handy car
    than it is to fit it on a pillion, let alone actually strap it down
    securely. The exception is if you have a Gold Wing or similar, obv.
    Pip, Aug 8, 2009
  13. ginge
    ginge Guest
    Hmm, I'll test it tomorrow but my planned approach is as follows:
    Strap under pillion pad and round centre of wheel/brake disc bit, with
    one disc resting on pillion pad.
    Bungee from right pillion peg, looped round spoke 1, bungee from left
    pillion peg looped round spoke 2, Rokstrap round spoke 3 and looped
    under mudguard.
    Can't see it moving much at all like that.
    alternatively I'll say **** it and just get the new tyre only.
    ginge, Aug 8, 2009
  14. ginge
    Welcome, Brother.
    You might find that even in a front end lock up they remain amazingly
    controllable
    Hog, Aug 8, 2009
  15. ginge
    Granted, it won't be able to move far. My point remains - how are you
    going to fit your little ginger self on there as well?
    I'd still suggest "**** it, I'll sling it in the boot of the car" is a
    fucksight simpler.
    Pip, Aug 8, 2009
  16. ginge
    Which is exactly what I'll be doing in about an hour's time when I have
    new tyres fitted to the Versys. I cba with fucking around with bungees
    etc trying to get two tyres strapped onto a bike with no rack.
    Lozzo, Aug 8, 2009
  17. ginge
    Aren't you changing both tyres on the 10R before you go? You'll have
    done something approaching 3k miles by the time you get home so unless
    the existing tyre is almost 'as new' you'll be riding on canvas at the
    end.
    Getting back to your original question: sell the Azaro and put the
    money towards a pair of decent tyres. You'll be mixing a tyre that's
    been part worn on a sports bike with a brand new tyre and my suspicion
    is that you'll get something will want to shake the front wheel every
    time you cross white lines under power.
    Andy Bonwick, Aug 8, 2009
  18. ginge
    ginge Guest
    The rear is maybe 100 miles old, had I not been going to europe I'd
    have got another 1500 out of the front easily.. I just don't reckon
    it'll make the whole trip.
    they'll both be part worn as the rear azaro is about half worn, same
    as the front qualifier I'd be moving across, but fair comment.
    ginge, Aug 8, 2009
  19. ginge
    ginge Guest
    'cept I don't have 2 front paddock stands to take both fronts off, and
    the tyre place I use is 20 miles away, which is a faff.
    ginge, Aug 8, 2009
  20. You're not doing yourself any favours, you know.
    The Older Gentleman, Aug 8, 2009
