TYRES!!!
Discussion in 'UK Motorcycles' started by Krusty, Aug 11, 2009.
  1. Krusty
    No, not which ones - something different. Icba to check, but istr
    several people having punctures very soon after getting new tyres. If
    that's the case, I have a theory...
    Fitted the wheels back on the MV earlier, shod with some lovely new
    Power 2CTs, & when I yanked it off the stand & pushed it forwards, it
    made a godawful racket. The cause of this was lots of gravel from the
    (unsurprisingly gravelly) ground where I was working had stuck to the
    tyres where the big Michelin stickers used to be, & was grinding away
    at the CF hugger & front guard as it passed underneath.
    There's quite big lumps of gravel stuck firmly to the sticky residue,
    so things like small bits of sharp flint, old nails etc would stick
    nicely too. Give 'em a few miles to work their way through the rubber,
    et voila - new tyre puncture.
    The moral to this story is next time you get new tyres, check where the
    labels were for anything pointy, then either clean the glue off or coat
    it with dust or something.
  2. Krusty
    I think generally sharp objects like nails lie flat on the ground - I
    suspect that rear punctures are so much more common than fronts
    because the front tyre rolls over them then flicks them up, and if
    you're unlucky they land just right for the rear tyre to catch them.
    Still supports your sticky labels theory - they're more likely to
    flick up stuff at slower speeds.
    Maybe, and this is a very wild guess, things like nails, flints etc
    are also more common on slower, residential roads, or at least, roads
    nearer to residential areas, where the tyres would normally be cooler
    and less sticky.
    Pip Luscher, Aug 11, 2009
