Tyres
Discussion in 'UK Motorcycles' started by Linger, Apr 6, 2006.
  1. Linger
    Andy Hewitt Guest
    I used them on the Diversion, and found them OK. Then again, the Divvy
    600 isn't a good tool for comparison.
    Andy Hewitt, Apr 7, 2006
  2. Linger
    Andy Hewitt Guest
    Not bad, I must admit the Avons are getting close to being my next
    choice.
  3. Linger
    Andy Hewitt Guest
    Out of interest, what sizes do you use? I can't seem to find a match in
    that range.
  4. Linger
    Beav Guest
    They weren't cheap when I bought mine (same price as 014's in fact) but they
    grip like a bitch when they're hot. Summer's on the way too, so the cold
    issue isn't such a prob. Mine are staying on for now and by the time it
    comes to change'em, the hottest of the weather is likely to be behind us.
    Beav
    OMF#19
    VN 750
    Zed Thou
    mail is beavis dot original at ntlworld dot com (with the obvious changes)
    Beav, Apr 7, 2006
  5. Linger
    Beav Guest
    The only expereince I've had with the Diablo's is on a pal's Superduke and
    they were excellent, but again, that was in the summer and most tyres are
    good when the're hot. The Conti's are, but the difference between cold and
    hot is just too much. On the same road, the bike will either wheelie if I
    push it (wheelie's aren't my thing, but they're definitely the Zed's thing)
    or lay a darkie with zero provocation depending on temps and like wheelspin
    even less than unexpected wheelies.
    I'd contemplated the Diablo's, but I've heard some good things about the
    Metzler M3 things. Too many fucking choices.
    Beav
    OMF#19
    VN 750
    Zed Thou
    Beav, Apr 8, 2006
  6. Linger
    Linger Guest
    My front is fucked. Plenty of wear left but the shape has gone.
    Feels awful.
    Linger, Apr 8, 2006
  7. Linger
    they were the OEM tyres on both my Bandit 1200 and my TRX850 - crap
    for both.
    darsy, Apr 8, 2006
  8. Linger
    Gyp Guest
    In message <4436e8c2$0$2571$>,
    Gyp, Apr 8, 2006
  9. Linger
    Psychochris Guest
    Try http://www.avonmotorcycle.com/us/en/Fitments.asp
    Name: 120/70 R17 (58W) AV45-ST
    Rims: MT3.50-17 Size: 120/70-17
    Pressure: 2.50bar (36psi)
    Name: 150/80 R16 (71W) AV46-ST
    Rims: MT3.50-16 Size: 150/80-16
    Pressure: 2.90bar (42psi)
    I've got the "B" rated ones - they have a higher load range than the
    standard ones.
    Ask your local friendly tyre place.
    Psychochris, Apr 8, 2006
  10. Linger
    Andy Hewitt Guest
    What are you saying there mate? ;-)
    I will indeed.
    Thanks, I've also lurked around in the FJOC forums too, and they are all
    going over to the Avons too. Looks like the choice is made then.
    Andy Hewitt, Apr 8, 2006
  11. Linger
    Grippy enough to get off the edge of the rear and close to it on a
    Bandit 12, similarly fitted to an RF900.
    Do it.
    Pip, Apr 8, 2006
  12. Linger
    ChrisDC Guest
    Viagra
    ChrisDC, Apr 8, 2006
  13. Linger
    Andy Hewitt Guest
    [Snipped Text]
    Ordered them today. Booked in to have them fitted in a couple of weeks.
  14. Linger
    mb Guest
    I know that old "FJ wasn't designed for radials" argument, but that
    doesn't mean it doesn't benefit from them.
    I tried BT45s on my FJ once and never liked them, maybe they've
    improved over the last couple of years. I don't like the present
    Macadams much either but they seem a bit more stable than the BT45s.
    mb, Apr 8, 2006
  15. Linger
    Andy Hewitt Guest
    [Snipped Text]
    Macadams were OK on a light bike, like my old Diversion, although I did
    have a couple of tail-end moments with those.
    Both my K100 and the FJ have been shod with BT45s. Perhaps it's because
    I haven't used anything else that I know no different, but I've been
    fairly happy with them.
  16. Linger
    snip>
    I liked the 207RRs on my 9R and the 218s are ok but not confidence
    inspiring on the 10R. I don't know what the **** to put on next
    because they've got to last a trip to the Nurburgring and 10 days on
    the IoM as soon as I'm home from France so really sticky tyres might
    be a bad idea.
    Andy Bonwick, Apr 9, 2006
  17. Linger
    It's got RRs front and rear before it even gets a sniff of a new rear.
    They're the ones I fitted. It'll be a 180 rear tyre so expect a bit of
    twitchy stuff from the front when you're on the gas.
  18. Linger
    Dan L Guest
    I've got Avons on my Zephyr.
    All I can say is that they are black, round, and the front one needs pumping
    up every few weeks.
    They also both have chiken strips about 2" wide.
    Other than that, they aren't at all bad, much better than the old Exedras
    that used to be fitted.
    Dan L (Oldbloke)
    Space in shed where NSR125 used to be
    BOTAFOT #140 (KotL 2005/6), X-FOT#000, DIAABTCOD #26, BOMB#18 (slow), OMF#11
    Dan L, Apr 9, 2006
  19. Linger
    deadmail Guest
    Here's a top-tip.
    Check your tyres from time to time. I knew the rear on my K100 was 'a
    bit bald' since it had done about 6.5k[1]... inspecting it today there
    were two patches about the size of my thumb where it was wearing into
    the canvas.. whoops.
    Fortunately I had a spare set of wheels with half decent tyres on them
    which I could swap. I'm almost too embarassed to take these knackered
    ones to the shop to put the new tyres on these wheels.
    [1] Normally about 4.5k does a rear in but I'd fitted a pirelli 'speed
    demon' which was slightly wider and seemed to be wearing well enough.
    deadmail, Apr 9, 2006
  20. Linger
    Bear said...
    Give Kawasaki their due, they did use a wider rim on the E model. A
    wider wheel that can't be fitted to the C model cos the spindle is a
    different diameter, and the hub is a different width too IIRC.
    Lozzo, Apr 10, 2006
