UKRM Seti@Home
Discussion in 'UK Motorcycles' started by Mo Childs, Dec 1, 2004.
  1. Mo Childs
    Mo Childs Guest
    I don't know if anyone else had this problem, but when the new 4.08 SETI
    Client downloaded yesterday the BOINC_CLI service stopped running the
    client. The GUI client was still OK. It started working again when I
    uninstalled and reinstalled the CLI (BOINC_CLI -uninstall etc.) I'm still
    not sure if that was a temporary aberration or not.
  2. I installed BOINC yesterday and am about to complete my first unit. All
    works fine for me on v4.08, but I can't work out how to download a
    greater number of work units??
    mike. buckley, Dec 2, 2004
  3. Mo Childs
    Salad Dodger Guest
    I changed the amount of disk space allocated, and it now holds around
    ten units at any one time.
    | ___ Salad Dodger
    _/_____\_ GLXR1500SEVRRSP/CBR1100XXX/KH500A8/TS250C
    |_\_____/_| .....73063...../..17090.../..3180./.19406
    \|^|/ ANORAK#17 IbB#4
    Salad Dodger, Dec 2, 2004
  4. Mo Childs
    Les Goodwin Guest
    latest version is 4.13
    I just let it do it's own thang and I got 2 units under progress and
    14 not started.
    Les Goodwin, Dec 2, 2004
  5. It's already got a gig of free BOINC space, what did you allocate for
    it?
  6. Mo Childs
    Eddie Guest
    Heh... mine was set to 100GB, and just got one unit at a time.
    You also need to change the setting for how often it connects - it
    should download enough units to keep it going until it tries to connect
    again, as long as there's enough disk space to hold them.
    Eddie, Dec 2, 2004
  7. Heh... mine was set to 100GB, and just got one unit at a time.
    again, as long as there's enough disk space to hold them.[/QUOTE]
    I figured it would do something like that, but after using some of the
    seti-classic add-ons I'm a bit paranoid that I'll run out of work units
    when the data server is down, although I suppose that's a good excuse to
    run another BOINC project.
  8. mike. buckley wrote
    I am awaiting the arrival of my new puter before I put boinc on it.
    certainly it, mailwasher and 98 don't cohabit very friendly like.
    Tell it you want X days worth of processing on the webs site preferences
    bit. It don't necessarily download more work units so much as get
    different sizes to fit your desired processing window is how I
    understand how it runs.
    steve auvache, Dec 2, 2004
  9. mike. buckley wrote
    There is a clue here if you care to look for it.
    This is a part of how the boinc project is designed to operate.
    seti@home is just one of the things being done with the basic engine.
  10. Mo Childs
    muddycat Guest
    I keep getting a message that it can't connect to the scheduler - ever.
    I have tried resetting, deleting and adding the project but it never
    works. I have climateprediction.net running and it's happy as can be.
    muddycat, Dec 2, 2004
  11. Mo Childs
    Mo Childs Guest
    OK, _that_ explains why I only get a couple of units I'm on broadband and
    I've got connect hourly set. I'm still trying to work out if the
    hyperthreading thang is a helping or not, but on the whole I think so.
    Mo Childs, Dec 2, 2004
  12. Mo Childs
    Mo Childs Guest
    No it just stopped working, I guess it downloaded some units that wanted the
    new version then didn't know what to do with them. I then ran the GUI and
    that fetched 4.08, then I reinstalled the Windows Service and it was back to
    normal.
  13. Mo Childs
    Salad Dodger Guest
    Fifteen Gig.
    | ___ Salad Dodger
  14. Mo Childs
    Salad Dodger Guest
    My P4's got 512Mb RAM. This is a bit shit, right?
    I'm currently shifting two units every 3 hrs 35.
    | ___ Salad Dodger
  15. Dr Ivan D. Reid wrote
    I don't understand a fucking word of that.
  16. Salad Dodger wrote
    33% more than this ole P2 keeps warm
    Takes about two days here.
  17. Mo Childs
    Salad Dodger Guest
    It's just that I've got some left over from when the old Athlon went
    bang.
    I was wondering if any of it'd fit.
    If not, I'll sling the new PSU in the old case, and try to resurrect
    it on the cheap.
    | ___ Salad Dodger
  18. Salad Dodger wrote
    Not a problem for a bloke who can disassemble a 'wing.
  19. Mo Childs
    Salad Dodger Guest
    Kewl.
    <reaches for drift and 2lb hammer>
    | ___ Salad Dodger
  20. Mo Childs
    Salad Dodger Guest
    It will?
    | ___ Salad Dodger
