Ultimate ear protectors
Discussion in 'UK Motorcycles' started by BGN, Aug 9, 2005.
  1. BGN
    BGN Guest
    Hello luvvies.
    While rummaging through a few old links relating to ear plugs I
    stumbled across <http://www.ultimateear.com/products_motorbike.html> -
    I'm fed up with warming up and rolling disposable plugs so I'm
    interested in some of a more permanent nature.
    Can anyone please tell me what the audio quality is like from the UEP
    75's if plugged into an iRiver/MP3 player/etc and has anyone used the
    75's long term? I'm concerned that 1) The quality/bass response will
    be a bit naff and 2) what is the wear and tear like for daily use? The
    cable doesn't look too robust.
    Thanks for your help.
    BGN, Aug 9, 2005
  2. BGN
    I've got some UEP 75s somewhere, albeit with acoustic filter inserts
    rather than embedded speakers. I've not worn them in aaaaaages, mostly
    due to "interesting" fitment - the mould is taken without a helmet on,
    so any deformation due to ears being squished isn't taken into account.
    I've never been inclined to listen to music while riding. The day I
    even think about it, I'll know it's time to get a more stimulating
    bike - I'd rather be concentrating on the ride than Shirley Bassey.
    ogden, Aug 9, 2005
  3. BGN
    Catman Guest
    How would moulds be taken with a helmet on?
    www.cuore-sportivo.co.uk
    Catman, Aug 9, 2005
  4. BGN
    Catman Guest
    If you get any, I'd be interested in seeing how well they actually block
    noise.
    Catman, Aug 9, 2005
  5. BGN
    Christofire Guest
    Wouldn't you have to get your own, as they'll be moulded to his ears?
    Dave Swindell (formerly of this parish) used to like his. Have a
    google. The whole job doesn't seem to have changed much for years -
    same materials, process, colours, etc.
    Christofire, Aug 9, 2005
  6. BGN
    Er. Squirt moulding goo into ear. Put on helmet. Allow goo to set.
    Remove helmet. Remove moulds.
    Is this a trick question?
    ogden, Aug 9, 2005
  7. BGN
    They block noise exceptionally well. I've worn mine to gigs plenty
    of times (as they have proper filters, they don't bugger up the
    sound quality too much). They're just crap under a helmet.
    ogden, Aug 9, 2005
  8. BGN
    Catman Guest
    Not at all. Does that actually work? I can see goo going all over the
    inside of the helmet and so on.
    Catman, Aug 9, 2005
  9. BGN
    Catman Guest
    Yes, but yours don't have speakers in. Which is what I wanted to know......
    Catman, Aug 9, 2005
  10. BGN
    Catman Guest
    Well, yes. I'd take his experience under advisement.
    IC, ta
    Catman, Aug 9, 2005
  11. BGN
    Easy enough to put a thin cover of some kind (cling film?) over the
    ears before donning the helmet.
    ogden, Aug 9, 2005
  12. BGN
    Catman Guest
    I can still see the things getting distorted when the helmet goes on, and
    then not actually working.
    Do you know of any companies that actually make moulds with the helmet on?
    Just curious.
    Catman, Aug 9, 2005
  13. BGN
    Off the top of my head, no. For all I know, I'm the only person who's
    ever had that particular problem.
    ogden, Aug 9, 2005
  14. BGN
    frag Guest
    Catman scribbled:
    Drill holes in helmet.
    Put helmet on.
    Inject mould stuff into ears through holes.
    Allow to set.
    frag, Aug 10, 2005
  15. BGN
    Catman Guest
    Wouldn't you need to swap the first two steps round, to make sure the holes
    were in the right place :)
    Catman, Aug 10, 2005
  16. BGN
    Catman Guest
    Possibly. I know my E.A.R. plugs were made sans helmet, and fit just fine.
    Greenleopard never asked me to take a helmet when I (nearly) went up there.
  17. BGN
    frag Guest
    Catman scribbled:
    Peel blood & bits of ear off moulds.
    Throw moulds away due to having no ears anymore.
    frag, Aug 10, 2005
