Ultrasonic cleaners - any good ?
Discussion in 'Classic Motorcycles' started by chrisu, Apr 8, 2006.
  1. chrisu
    chrisu Guest
    I've gots a lot of SOB bits that need cleaning - especially a set of
    carbs. I was wondering if these Ultrasonic baths are as good as people
    claim. Any experience ? - other alternative is a few cans of carb
    cleaner and my trusty airline.
    yours in the (probably vain) hope of a helpful & non-piss taking
    response...........
    chrisu, Apr 8, 2006
  2. chrisu
    mb Guest
    Yes, they do get stuff clean but...
    Make sure you find out what the solvent and/or temperature will do to
    any O-rings you have in the carbs.
    mb, Apr 8, 2006
  3. Never used them, but for some jobs - such as cleaning gummed carbs -
    they're supposed to be indispensable.
    The Older Gentleman, Apr 8, 2006
  4. chrisu
    JB Guest
    The £14 one from Aldi has proved itself to be essential for this and other
    tasks. For stubborn gum and shite in some old Dellortos, I used coca-cola as
    a solvent. you want to see the shit that came out.
    Good on valves/rockers too (with paraffin as solvent).
    JB
    JB, Apr 8, 2006
  5. chrisu
    chrisu Guest
    coke as a solvent - great idea !
    chrisu, Apr 8, 2006
  6. chrisu
    That's about as old as the hills, that one.
    Keep up at the back, willya?
    Timo Geusch, Apr 8, 2006
  7. chrisu
    Roger Hunt Guest
    Can I use any old cola, or must it be the real thing? (Serious question)
    Roger Hunt, Apr 10, 2006
  8. Check the ingredients -- you're looking for ortho-phosphoric acid,
    not caffeine!
    Dr Ivan D. Reid, Apr 10, 2006
  9. chrisu
    Laura has cleaned coins with cheap generic cola.
    platypus, Apr 10, 2006
  10. chrisu
    Roger Hunt Guest
    ok ... I did Chem many years ago so I'll read lots of labels, and thank
    goodness I don't drink the stuff - it sounds filthy.
  11. chrisu
    platypus said...
    Jasmine cleaned rust out of an MZ tank with a mix of Dr Pepper and
    cheapo cola. IIRC Blaney did the same. We used to use it to unseize
    engines that had pistons corroded in the bores, just pour it onto the
    piston crown through a spark plug hole and leave it a few days to soak
    past the rings and do its work.
    Lozzo, Apr 10, 2006
  12. chrisu
    Ovenpaa Guest
    They are very good, I use mine for carb and clock parts, for jets and bodies
    etc I use water and detergent.For clock parts I use a mix of water,
    ammonia, and cheap nail varnish remover (1), this cleans brass parts
    incredibly well. For really tarnished parts I use citric acid powder and
    water mixed.
    The UC is also very good for removing polish residue from alloy parts that
    have been polished.
    An essential bit of gear and a great labour saving device in my house.
    Steer clear of the eBlag units used for tattoo tools they have a poor
    reputation, oh, and you only get what you pay for with these things, also
    get one with a basket, or make a basket, parts left in contact with the
    stainless steel container for long periods of time can shag the
    transducers.
    (1) Don't use a plastic basket!
    Ovenpaa, Apr 10, 2006
  13. it's also handy for cleaning the bog. and cheaper than toilet duck.
    Austin Shackles, Apr 10, 2006
  14. chrisu
    Roger Hunt Guest
    I think I'm going to dismantle my Aldi £14 one, and dangle the
    ultrasonic thingie in the bog water to see how well that works.
  15. 100% coca cola, in my case. Worked a treat. Took me a year to put
    the tank back on the bike, mind - but that's another tale of
    ineptitude.
    vulgarandmischevious, Apr 11, 2006
  16. I had a quick shufti at a bottle of Tesco cola last night; they
    list it as phosphoric acid (I think the ortho- denotes a straight-chain
    molecule; there's the possibility of a branched chain with the same
    chemical formula but the straight one is the common one).
    Dr Ivan D. Reid, Apr 11, 2006
  17. I meant the generic cola, in fact. but it's possible that the ultrasound
    thing would clean the bog, as well.
    Austin Shackles, Apr 11, 2006
  18. <VVBG>
    ukrmc - teaching you how to read soft drinks labels....
    The Older Gentleman, Apr 11, 2006
  19. chrisu
    Roger Hunt Guest
    Oh I see - http://en.wikipedia.org/wiki/Phosphoric_acid (H3PO4)
    No idea why they call it ortho-, because metaphosphoric acid is
    ([HPO3]n), a glassy solid used as a desiccant, etc. It's tempting to
    think it might take in a water molecule and turn into the ortho- type.
    Roger Hunt, Apr 11, 2006
  20. I would have thought with kids the age yours are/have recently been,
    it'd be mandatory. Of course, for people like JP, _not_ reading the label
    can be fatal. :-(
