Unable to fill tank fully?
Discussion in 'Bay Area Bikers' started by Jim, Apr 30, 2007.
  1. Jim
    Jim Guest
    I recently moved to CA. I can't seem to fill my tank fully. Unless I
    get a complete seal from the nozzle to the tank, the gas won't flow.
    Doing so pushes the nozzle into the tank several inches and kills the
    flow early.
    Does anyone have a pointer to how to properly fill up the tank fully?
    Being short by 1.5 gallons sucks.
    Thanks a bunch
    Jim
    Jim, Apr 30, 2007
  2. I assume you're talking about the pumps that have a foreskin?
    Just pull it back with your hand.
    -Patti
    Patti Beadles, Apr 30, 2007
  3. Jim
    Rich Guest
    When you do that, you may want to reduce the rate of flow so as to get
    all the gas you're paying for to stay on the inside of the tank.
    Rich, Urban Biker
    Rich, May 1, 2007
  4. Hi
    I am thinking of getting one of these....
    http://tinyurl.com/us3zh
    it might save a few cents, or dollars, at the going rate.
    dave
    Devoid Corpuscle, May 1, 2007
  5. Jim
    barbz Guest
    Exactly. There's a sensor in the nozzle that shuts off the gas when fuel
    levels get high enough to trigger it. Works fine with automobiles. Sucks
    with motorcycles.
    You have to yank that rubber sheath back enough to breathe the lovely
    smell of gas. Plus, you have to pay attention, you can overfill the tank
    by disabling the sensor.
    Barb
    Chaplain, ARSCC (wdne)
    "Keep fighting for freedom and justice, beloveds, but don't forget to
    have fun doin' it. Lord, let your laughter ring forth. Be outrageous,
    ridicule the fraidy-cats, rejoice in all the oddities that freedom can
    produce."
    --Molly Ivins
    barbz, May 1, 2007
  6. Jim
    barbz Guest
    Heh. You mean, gas-soaked shoes don't count as a reserve tank?
    Barb
    produce."
    --Molly Ivins
    barbz, May 1, 2007
  7. Jim
    Steve Watt Guest
    Actually, it's easier than that. They have a contact wire; you just need
    to compress the end of the boot a little.
    The gas shutoff sensor seems to be inside the metal part of the nozzle,
    at least on the various pumps I've run into. You hold back the foreskin
    a bit (enough to tease the sensor into thinking it's snugged up against
    something), put the tip of the metal in line with the fuel tabs at the
    top of the tank, and just pump. It'll shut off when the fuel hits the
    tip.
    At least, all of the Chevron stations I use work that way.
    Steve Watt, May 1, 2007
  8. Jim
    James Clark Guest
    Things are not necessarily as they seem.
    James Clark, May 3, 2007
  9. Jim
    Steve Watt Guest
    Yep. Care to share? I'm curious how the things work.
    Steve Watt, May 3, 2007
  10. HardWorkingDog, May 3, 2007
  11. Jim
    James Clark Guest
    The Car Talk version is that the pump pulses the fuel. This creates a pressure wave. As the talk
    fills, the returning wave becomes stronger. When a set threshold is set, the pump shuts off the gas.
  12. Jim
    Jim Guest
    Thanks to everyone who responded. I learned something. I managed to
    pull the "foreskin" back and now have a full tank of gas. God, that was
    frustrating. The tip of slowing down the rate was useful also. The gas
    stayed in the tank instead of all over the place.
    Jim
    Jim, May 4, 2007
  13. Jim
    barbz Guest
    The people who know this stuff, we were around before those foreskins
    were required by law, back when "Ethyl" was a fuel and not Lucy's neighbor.
    The fueling sheaths are to protect us from gas fumes. Personally, I love
    the smell of gasoline in the morning, it smells like Road Trip!
    Barb
    produce."
    --Molly Ivins
    barbz, May 4, 2007
  14. Jim
    Rich Guest
    I can barely remember the pre-Lucy days. Most of the cars parked on my
    block then had running boards. The major brands of gas were Socony, who
    sold oil under the Mobil name, and Tidol, whose lubricant went by the
    name Veedol.
    Rich, Urban Biker
    Rich, May 5, 2007
  15. Jim
    muddy cat Guest
    I remember 25 cent a gallon fuel and Flying A.
    muddy cat, May 5, 2007
  16. Jim
    Alan Moore Guest
    When I first took up motorcycling, I experienced a sense of deja-vu
    when I filled my tank for $5.00 and got back change.
    Al Moore
    DoD 734
    Alan Moore, May 6, 2007
  17. Jim
    muddy cat Guest
    You can't even do that any more.
    muddy cat, May 7, 2007
  18. Jim
    barbz Guest
    Nope. Costs around $10-$11 to fill my standard R65 tank. Dang, that's
    double what it used to cost, or more. I've filled it for $4 not that
    long ago...
    Barb
    produce."
    --Molly Ivins
    barbz, May 7, 2007
  19. The weekend after 9/11 I got very low on fuel coming down the north
    side of Mt. Lassen on my Goldwing. I made it to Old station and the
    fillup was 5.25 gallons at $2.149 per gallon for a total price of
    $11.28. This set my personal records for the most fuel and the most
    money on a M/C fillup. Now, of course, I exceed the money record on
    routine fillups of less than 4 gallons.
    Michael R. Kesti, May 8, 2007
