Unaugural 8.0 - Roll Call
Discussion in 'Australian Motorcycles' started by BT Humble, May 1, 2010.
  1. BT Humble
    Touche!
    BT Humble, May 11, 2010
  2. BT Humble
    Oh well, if it's all MY fault then...
  3. BT Humble
    VTR250 Guest
    I carry a toothbrush on all trips because I might get lucky at any
    place I stop!
    Unlike you, who rides to Portland. To stare out to sea. Probably
    alone.
    With your foetid breath. ;-)
    VTR250, May 11, 2010
  4. BT Humble
    On the contrary, once the dust settled the problem was revealed to be too
    much gravel on the front brake!
  5. Yep, nice of you to admit your fault
    George W Frost, May 11, 2010
  6. I carry a toothbrush on all trips because I might get lucky at any
    place I stop!
    alone.
    Wow, watch out when I get close, I may breathe all over you
  7. I did ride across to Mount Gambier for the ride as I hadn't been to Mac park
    for a few years,
    But, I didn't mention that because I knew you would read it and I didn't
    think that you would know where Mount Gambier was
  8. BT Humble
    Lars Chance Guest
    Hey; I never *said* I was gonna' show up!
    I'm a pre-piker.
    Lars Chance, May 11, 2010
  9. BT Humble
    Lars Chance Guest
    You know what it's like to sleep with Marty?!!?
    (Does he kiss you afterwards and *spoon*?)
  10. BT Humble
    bikerbetty Guest
    <ignoring BTH's witty response> ;-P
    Didn't touch the front brake! AND I remembered Lemmiwinks' exhortation -
    'when in doubt, wind it out' on the previous lot of corrugations, and bumped
    my way over those, unharmed and with great relief... but on 'Betty's Bend' I
    honestly can't tell you what it was that caused the front to go haywire... I
    remembered to keep my shoulders loose and not to panic or tense up, and I
    wasn't going fast... The gravel there did seem to vary in depth - dunno if
    that had anything to do with it - and today Lemmiwinks put something on my
    blog to the effect that on corners (on gravel) you need to lean the bike
    but keep your body upright - maybe it was something to do with that??? Not
    sure....
    In any case, it reinforced my absolute antipathy towards non-bitumen
    surfaces. For next year's Unaugural I shall get either (a) a postie bike, or
    (b) a lift!
    betty, able to put a teeny bit of weight on the multicoloured foot now
    bikerbetty, May 11, 2010
  11. BT Humble
    bikerbetty Guest
    LOL. Bastard. ;-)
    betty
  12. BT Humble
    Marty H Guest
    its called counter balancing...
    to cut a long story short, you push the the bike to the side you want
    to turn with you leaning off there other causing the centre of gravity
    to be still 90 degree from the road, even though the bike/tyres are
    learning to one side, there is no sidways force on the bike so the
    tyres dont slip sideways (lowside)
    great technique on the dirt and in the wet
    easy to do, just place your arse crack on the side edge of the seat on
    the opposite sit of the turn and push the handle bars from one side to
    the inside of the turn..push them sideways/away, not turn.
    you and the bike make a V, the bike on the inside of the turn, you on
    the outside of the turn.. once bikes are leaning to one side above
    20kmh, they turn naturally
    it made BT's road good for 100kmh+ for me
    80% of riding on the dirt is mind over matter... yes, its hard to over
    come, practise on a bike and body that doesnt mind falling over helps
    (cause you will)
    mh
    Marty H, May 11, 2010
  13. Yeah, I hate road bikes on gravel as well. I haven't dropped one yet,
    but can feel that the bike is likely to go lots of times. My way of
    handling it is:
    1. Go slower (duh)
    2. Use more rear brake. Even to the point of all rear brake unless you
    really need the front.
    3. Wash off any speed you need to before going into a corner and take
    the corner as upright as possible
    4. Buy a trailbike and fang it like a mad bastard. Heaps of fun.
    Kev
    Kevin Gleeson, May 11, 2010
  14. BT Humble
    G-S Guest
    Both methods work... long distance desert racers tend to use Nevs method
    and riders of lighter dirt bikes either use Martys method or a variation
    on speedway style.
    It's a bit like arguing if knee down or classic style road racing is
    better...
    it depends upon the bike.
    G-S
    G-S, May 11, 2010
  15. BT Humble
    CrazyCam Guest
    OK, to turn a bike you have to have some sideways force acting through
    the tyres to to road surface.
    For most circumstances, leaning the bike and body more or less at the
    same angle works just fine.
    However, at times, one may want to have the bike leaning either more or
    less than the rider's body.
    Ripping round a nice smooth rack track on sticky tyres, one might well
    (assuming one is fit enough) hang off to the inside of the turn, to
    reduce the angle of the bike for a given corner, so that the tyres are
    still maintaining a good contact patch, and one has the potential to go
    faster than the rider basically just sitting upright relative to the bike.
    OTOH, if you are faced with doing the MOST, to get your P-plates (in
    NSW) on a Kwaka GPX or GPZ 250, to do the U-turn, you have to get the
    bike leant over a fair degree, but you don't actually want to have much
    speed on, so you lean your body away from the turn, pushing the bike
    down under you, so the bike turns tightly, but at low speed, and,
    hopefully, you don't fall over.
    Make sense so far?
    So, for example, when I get new tyres fitted, my scrubbing in technique
    is to ride round turns, leaning outwards from the turn, thus
    using/scrubbing more of the side of the tyres, but at a lower speed than
    I'd normally take the turns.
    It's not that there is no sideways force, only that the force is less,
    because the turn is being taken slower.
    Aye, but, if the turn radius is fixed, and you reduce the speed, then
    you have less force required.
    "Reduce the speed" is a relative term! :)
    On the smoother straight bits, I might have seen 70 or 80 on the speedo,
    had I had the time to look, but the corners were taken a lot slower than
    that, and I was leaning out from the turn.
    I agree about the mind over matter bit, but for some of us, whose bodies
    are already having troubles with athletic things like walking, and even
    standing up, our bodies just aren't interested in the option of falling
    off a motorbike.
    Me too!
    regards,
    CrazyCam
    CrazyCam, May 12, 2010
  16. BT Humble
    PostmanPat Guest
    Heheheh...
    *Attempts to run away,hampered by his more-recently-acquired
    swollen,multicoloured foot*
    I certainly can't recommend slamming a Transalpsworth of weight on it.
    My Wedgetail Outriders should be arriving shortly...
    Postman Pat the Crippled (my levers are fine though)
    PostmanPat, May 12, 2010
  17. BT Humble
    TransTankSlap?
    BT Humble, May 12, 2010
  18. BT Humble
    Boxer Guest
    True, particularly if you hit sand or bulldust, stand up weight to the rear
    and give it the berries.
    Worked well when I went to Birdsville last year on the GS.
    Boxer
    Boxer, May 12, 2010
  19. BT Humble
    Lars Chance Guest
    Ooh; I do the complete opposite. I lean my body as far as necessary so
    I can keep the bike totally upright.
    Lars Chance, May 12, 2010
  20. BT Humble
    Lars Chance Guest
    Dammit!
