Unaugural Update
Discussion in 'Australian Motorcycles' started by BT Humble, Feb 25, 2008.
  1. BT Humble
  2. BT Humble
    Knobdoodle, Feb 25, 2008
  3. BT Humble
    bikerbetty Guest
    bikerbetty, Feb 25, 2008
  4. BT Humble
    Yeebers Guest
    I figure you mean 'if you build it, they will come' but assume it was a
    rhetorical question.
    <manually moved to the bottom to appease the bottom-posting god..>
    Yeebers, Feb 25, 2008
  5. BT Humble
    A Brumby would be easier to lift. Have you got one to spare?
  6. BT Humble
    It'll burn a treat, if that's what you mean!
    (Mostly poplar. No high-falutin' pine pallets for us bumpkins,
    matet!)
  7. BT Humble
    Minx Guest
    (What was the line from that movie, "Field of Dreams"?)
    "It reminds of us of all that once was good and it could be again. "
    Minx, Feb 25, 2008
  8. BT Humble
    Is "bottom posting" putting the male into the slot?
  9. BT Humble
    I have.... but I can't actually move it, sorry!
  10. BT Humble
    Yeebers Guest
    Only for a basement / ground floor unit I guess.
  11. The Happy Drunk, Feb 25, 2008
  12. BT Humble
    "We're gonna need a bigger boat!"
  13. BT Humble
    This one's built on top of a pretty hefty tree stump, so there should
    still be a bit of it burning the following morning.
  14. BT Humble
    Resound Guest
    What's that truck there for then?
    Resound, Feb 25, 2008
  15. BT Humble
    OK; the Brumby's in the front yard BT... you know the address.
  16. BT Humble
    Toosmoky Guest
    "Oh, my God! You're from the sixties!..."
    Toosmoky, Feb 25, 2008
  17. BT Humble
    G-S Guest
    She exagerates... I only have 1 boat (at a time :)
    G-S
    G-S, Feb 25, 2008
  18. BT Humble
    I tried taking the photo with a 20c coin positioned next to the pile,
    but it just didn't convery the sense of scale as well as the truck
    does.
  19. BT Humble
    Are you giving up on it and buying a Jumbuck then?
  20. BT Humble
    Naah; it's just down the list of priorities at the mo.
    If I get the Trump registered OK then I'll put some effort into the
    Brumby.....
    Knobdoodle, Feb 26, 2008
