Ural
Discussion in 'Australian Motorcycles' started by Zebee Johnstone, Apr 28, 2011.
  1. Who was it bought a Ural?
    Here's some stuff came through euromoto, although it's about older
    bikes, how much change might there be...
    Points gap needs to be 0.4 to 0.6mm, plug gap is 0.6mm
    The flywheel mark on mine is firing point at tickover not TDC but
    it might not be the same on others. The only thing I'd suggest here
    is the old stick down the plug hole trick to find TDC
    Valve adjustment on my urals I do thus:
    Set engine so inlet valve just closing then set exhaust tappet at 0.05 to 0.07mm
    Set engine so exhaust valve just opening then set inlet tappet at 0.05 to 0.07mm
    This means the valve being set will be well away from the cam ramp.
    0.02mm is a bit tight
    Accepted wisdom from the ural fraternity is bin the old K301 carbs as
    descibed here. Apparently, Yam 250 Mikunis work well and can be
    fitted using the Mikuni rubber flanges. I did have the jetting
    somewhere. My bikes have K68 carbs or Jikovs which compare OK with
    modern western carbs. On early urals, the carb bolts are in the
    vertical plane so fitting alternatives like Amals need an adapter
    plate.
    Urals have roller bearing big ends so it's a low pressure oil system.
    There should always be a good few mls of oil in the rocker covers.
    These are good links to try for more advice:
    http://www.f2motorcycles.ltd.uk - the owner, Dave Angel will know
    very much more than me.
    http://www.cossackmotorcycles.com/ is a site done by Dave to help
    identify different Russian bike models and their various parts.
    http://www.cossackownersclub.co.uk/ is what it says on the tin
    www.russianiron.com has a good set of technical forums
    http://www.russianmotorcycles.co.uk/all_ural_manuals/all_ural_manuals.htm
    Zebee
  2. Zebee Johnstone
    Diogenes Guest
    That'd be GWD (George to his mates.)
    Onya bike
    Gerry
    Diogenes, Apr 28, 2011
  3. Zebee Johnstone
    Diogenes Guest
    Hey, George, are you taking the Ural to the Unaugural for its
    Uralaugural? (Please don't hit me. :)
    Onya bike
    Gerry
  4. Zebee Johnstone
    gdel.remove Guest
    ZOTT!!! :))
    But yes I am. Jenny in the cage too.
    Good piece of retro gear, but needs a lot of experienced TLC to make
    run and ride well. Mine does now.
    gdel.remove, Apr 28, 2011
  5. Zebee Johnstone
    Diogenes Guest
    That's GOT to win you a trophy at the Unaugural I reckon.
    I wish you both a safe journey. You guys are a lot tougher than I am.
    I've grown old and soft. :-(
    Onya bike
    Gerry
  6. Zebee Johnstone
    I may have forgotten to mention it, but Kevin *did* turn up at the ACT
    Field Archery Championship[1] with my longbow, so you don't need to find
    room for it.
    [1] I ended up placing 3rd[2] in my division[3][4].
    [2] No shame in that, I was beaten by the ex-Australian champion and a guy
    who spent several years at the AIS
    [3] Barebow Recurve.
    [4] Well yes, only having 3 competitors in that division obviously helped.
    BT Humble, Apr 28, 2011
  7. Zebee Johnstone
    gdel.remove Guest
    OK, never a prob anyway.
    Congratulations anyway,
