USB External HD
Discussion in 'UK Motorcycles' started by Switters, Jan 26, 2011.
  1. Switters
    Switters Guest
    I'm looking for a USB HD as a quick and easy external file store. There
    are loads around and it's difficult to tell which are any good.
    The iomegas appear to suffer from shoddy USB connectors.
    The WD Passport seems stuck with pre-loaded, auto-booting software.
    Though I run Ubuntu, so hopefully I could just plug it in and delete the
    pre-loaded shit.
    Nearly all of them state Windows/Mac as a O/S pre-req. WTF? It's a
    portable disc. The O/S shouldn't matter.
    Anyone have personal recommendations?
  2. Switters
    Catman Guest
    Buy one that fits your budget.
    Wipe and format to your preferred FS
    Store data.
    #www.cuore-sportivo.co.uk
    Catman, Jan 26, 2011
  3. Switters
    zymurgy Guest
    I think that's just a 'compatability' sticker, not an OS pre-
    requisite.
    Like catman says, buy the one you like the look of most, and reformat
    it. Or buy an empty USB2 3.5" format or 2.5" disk box and put your own
    disk in it. There's loads of choice on Ebay.
    You could also consider USB3, eSATA or firewire connectivity depending
    on your budget.
    Cheers,
    Paul.
    zymurgy, Jan 26, 2011
  4. Switters
    prawn Guest
    Well, Santa bought me an iomega drive and it works. No probs with Linux
    I have even formatted it with an ext4 file system.
    prawn, Jan 26, 2011
  5. Switters
    ginge Guest
    You mean the stuff you delete, the moment you get the drive?
    ginge, Jan 26, 2011
  6. Switters
    Catman Guest
    If not sooner, IME
  7. Switters
    We have several of the big WD USB drives. They are excellent. Just format
    them with your f/s of choice.
    Hog, Jan 26, 2011
  8. Switters
    Kevin Stone Guest
    +3
    Kevin Stone, Jan 26, 2011
  9. Switters
    ginge Guest
    indeed, i have a couple.
    plus who in their mind doesn't disable autorun on a windows PC?
    ginge, Jan 26, 2011
  10. Switters
    Ben Guest
    Also...
    Treat as disposable and don't rely on it.
    Ben, Jan 26, 2011
  11. Switters
    Catman Guest
    Oh yes, missed that one. LOCKSS
  12. Switters
    Tim Guest
    Tim, Jan 26, 2011
  13. Switters
    DozynSleepy Guest
    I've got a bunch of the Maxtor Onetouch 4 1Tb drives. Got some natively
    formatted for Linux (ext3) and Windows NTFS, seem okay on both
    platforms. Occasionally have a spin up time out when they've gone to
    sleep on Linux though. For home use I tend to format the drive as NTFS
    since Ubuntu works perfectly with it.
    I'd just find the cheapest largest drive you can get and buy two of
    them. Losing a terabyte of data if you accidentally knock the drive off
    the table is a lot easier to bear if you've got a mirror sitting in the
    cupboard :).
    Saying that I quite like the look of some of the drives which are
    powered off the usb connector, saves lugging a power brick around as well.
    hotukdeals have some 1Tb usb drives listed under £50.
    DozynSleepy, Jan 26, 2011
  14. Switters
    Colin Irvine Guest
    +1. And, as ginge pointed out, you can get free Acronis for it.
    Colin Irvine, Jan 26, 2011
  15. Switters
    ginge Guest
    I did, but in the disk cloning thread the other day.
    Best product at disk cloning and PC imaging I've ever used, and I've
    used most of them over the years.
    ginge, Jan 26, 2011
  16. Switters
    Switters Guest
    These are the type that I'm looking at.
  17. Switters
    Switters Guest
    This is what I was banking on, but some numpty users reported problems,
    which didn't make sense.
    The moral is "don't believe everything (anything?) you read on the
    internet".
  18. Switters
    Switters Guest
    Yeah, that's the stuff. :)
  19. Switters
    SIRPip Guest
    Sooner? You walk down the aisles of PC World with a FOAD
    electro-magnet, don't you?
    SIRPip, Jan 26, 2011
  20. Switters
    Paul - xxx Guest
    I've just recently used it based on that recommendation (I started the
    thread) and would say it does exactly what it should .. very, very
    good. ;)
    Paul - xxx, Jan 26, 2011
