VERY Long Term Storage
Discussion in 'Motorcycle Technical Discussion' started by Greg Berchin, Aug 2, 2003.
  1. Greg Berchin
    Greg Berchin Guest
    Hi, folks;
    I have a 1990 ZX-11 in nearly pristine condition, and it's a
    keeper. It was my first "new" bike, and I'd like to have it
    around when I'm 90 years old so that I can show to the youngsters
    on their solar-powered soy-derived 2050-model Suzukawis what 1990
    technology could do. So I'd like to know the CORRECT way to
    package this up for multi-decade storage. Can anyone point me to
    some references for this?
    Thanks,
    Greg
  2. Greg Berchin
    Greg Berchin Guest
    Why yes, of course. Doesn't everybody? :)
    Greg
  3. Greg Berchin
    Dave '97 F3 Guest
    Dave '97 F3, Aug 2, 2003
  4. Greg Berchin
    Greg Berchin Guest
    No need for YOU to be sorry. I just take it in stride.
    Myself, included. (I live in Minnesota.) However, I believe that
    really long-term storage requires removal of all of the fluids,
    whereas simple winter storage does not. Furthermore, it seems
    like all rubber parts will have to be protected somehow.
    Note that I was just joking about taking it out of storage in
    2050. But I can certainly see keeping it in storage for a decade
    or two. By that time I'll be retired, and hopefully have the time
    and resources to devote to a restoration.
    How do museums do it?
    Yes, I understand. But it would still be nice to try to preserve
    the bike. Otherwise it will just sit under a tarp in my garage,
    which is guaranteed to cause it to deteriorate. I don't ride it
    much any more, because every ride increases the probability that
    an accident will occur. If my bike is going to get dinged or
    dented or scratched, I'd rather it happened to a more "common"
    bike that I don't care so much about.
    Thanks for your suggestions,
    Greg
    Greg Berchin, Aug 3, 2003
  5. Greg Berchin
    Ben Kaufman Guest
    <SNIP>
    Huh? Think for a moment. He's talking about storing a bike for something close
    to 40 years, not 4 years. Yes, of course the lubricants should be drained and
    flushed, but of primary importance is an environment that inhibits oxidation and
    other chemical reactions that cause deterioration.
    Ben
    http://autos.groups.yahoo.com/group/rockland_mc_riders
    Ben Kaufman, Aug 3, 2003
  6. Greg Berchin
    Cymen Vig Guest
    From: Future Violations Reduction Agency, year 2040
    We have knowledge that you plan on using a motor vehicle that burns what
    you call GASOLINE in the year 2043. We urge you to reconsider your idea
    as the GASOLINE VIOLATION ACT of 2035 requires the immediate
    incarceration of anyone who uses a GASOLINE-powered vehicle. The THOUGHT
    CRIMES ACT of 2039 requires that you be informed of your violation with
    due time. You have committed a thought crime punishable retroactively in
    2030. If you have not negated this crime by 2005 the maximum sentence is
    reincarnation. Please remedy the situation before it is too late.
    Cymen Vig,
    Lethal Emissions Enforcer,
    Future Violations Reduction Headquarters (2040),
    2040.153.16:43 GST
    Filed per communication requirement X53894.253, "Thought Crimes, circa
    2000-2005."
    Cymen Vig, Aug 4, 2003
  7. Greg Berchin
    Greg Berchin Guest
    Kind of like storing military Jeeps in Cosmolene, right?
    Not a bad idea. Thanks.
    Greg
    Greg Berchin, Aug 4, 2003
  8. Greg Berchin
    Greg Berchin Guest
    You will have to catch me first! I don't think that your
    solar-powered mopeds will run with my 175 MPH Superbike. :)
    Greg
  9. Greg Berchin
    Tim Morrow Guest
    Same goes for the brakes. The pistons in the calipers and m/c's will probably
    seize wihtout fluid. (Ditto hydraulic clutch lines, master, and slave
    cylinders.) I would highly recommend CHANGING the brake fluid prior to storage,
    and you might want to do some careful analysis of which spec fluid would be best
    for long term storage. (I.E. The best fluid for high performance street riding
    might not be the same as the best for racing, which in turn might not be the
    best for storage.)
    Agree that the fuel system should be completely drained and dried, and dessicant
    added to the tank and possibly float bowls too might not be a bad idea.
    New tires with silicone on the bead seating area?
    Dielectric grease packed in multi-pin wire connectors?
    Opaque (paper or cloth) covers over the instrument faces to prevent fading?
    Lithium or axle grease on the pivot points of the side stand and/or center
    stand?
    What about relieving the strain on the various return springs, like the stands,
    and the clutch springs?
    Leaving the engine at bdc with extra (clean, new, fresh, synthetic) oil in the
    crankcase?
    Storing a new, dry, never had acid added correct battery with (but not IN) the
    bike?
    New brake pads?
    New spark plugs?
    Fresh, dry, factory oem air filter element?
    Just thinking out loud....
    Tim
    Tim Morrow, Aug 5, 2003
  10. Greg Berchin
    Ben Kaufman Guest
    Back in the later '70s car horsepower was plummeting as gasoline was getting
    scarce and anti-pollution devices were starting to occupy a noticeable amount of
    the engine compartment. I figured by 1990 all we'd have left were things
    powered by lawn mower engines. Boy, was I wrong. Therefore, I would like to
    believe that in the future we may not use petroleum distillates but even if it
    turns out to be powered by a "giant rubber band" it will be faster than what we
    have today.
    Ben
    Ben Kaufman, Aug 5, 2003
  11. Greg Berchin
    Eric Goforth Guest
    I'd loosen up all the valve adjusters a lot or remove the rockers, if the
    bike has them to make sure all the valves are closed. If you're going to
    store this bike for fifty years, it'd probably be a good idea to buy a set
    of piston rings and plan to do a ring replacement and hone job when the bike
    is reawakened. I don't think that having a piston ring sitting at the same
    position for 50 years will be good for it or the bore.
    -Eric
    Eric Goforth, Aug 6, 2003
  12. Greg Berchin
    Greg Berchin Guest
    Lots of good details in your message. Many of these should be
    checked even for just winter storage. Thanks.
    Greg
    Greg Berchin, Aug 6, 2003
  13. Greg Berchin
    Greg Berchin Guest
    Big job! Probably the BEST way to do it, though. I'm not certain
    that I have enough discipline to do that, though.
    Greg
  14. Greg Berchin
    Greg Berchin Guest
    It is possible that there will still be internal combustion
    engines, but they will probably burn simpler hydrocarbons like
    alcohols or non-hydrocarbons like pure hydrogen. Either one has
    better anti-knock properties than gasoline, so compression ratios
    will be higher (or engines will be supercharged), and engines will
    be more powerful for a given displacement. And as advanced
    materials technologies permit 30,000 RPM, we should see some real
    screamers ...
    Greg
  15. Greg Berchin
    Paul Harris Guest
    Don't worry, Harleys will be still poking along at 2,500 rpm, as how
    else will you get that "potato potato" sound? At that advanced date in
    the future, not only will the hardware be obsolete, but also the noise
    it makes. But don't worry, it will still look "retro," with chromed
    this, billet that, and fringe leather everywhere it can be hung . . .
    Paul Harris
    Paul Harris, Aug 7, 2003
