Very strange electrical problem
Discussion in 'Motorcycle Technical Discussion' started by pete, Apr 6, 2006.
  1. pete
    pete Guest
    This is on the level. I noticed when I turned the ignition on on my '02
    Bandit last weekend, the rear brake lights came on.
    After a short spell, they start flashing slowly on and off. It continues
    after starting it up.
    I unplugged the brake light switches and it keeps doing it, the usuall tail
    lights which are supposed to be on, ain't.
    I had a good look at the schematic, no obvious theories I could come up
    with. And I haven't been mucking with the wiring lately.
    The only thing I can think of is maybe there is a shot diode someplace.
    This weekend I'm going to spend some time on it, I have an attack plan, but
    I'd rather be riding the thing.
    Any theories which might save me some time? I don't think this is normal
    behavior.
    Thanks
    Pete
    pete, Apr 6, 2006
  2. pete
    pete Guest
    The bulbs are a candidate, I replaced both of them a while back. I couldn't
    find the exact same thing, so I went thru the blister packs at the store and
    got a pair with the same base but the wattages were different.
    I'm thinking it also must have something to do with the flasher unit causing
    them to blink, it's mabe not getting the current it expects to flash at turn
    signal speed.
    I'm keen on the faulty diode theory, somehow allowing them to ground or
    whatever thru it. The schematic probably doesn't show them all.
    Something else I though of, there may be something screwy in the ignition
    switch. I've never used it, but apparently there is a position CCW to the
    stearing lock position which is an emergency flasher thingy.
    If I figure it out I'll post what it was, in the rather unlikely chance it
    happens to someone else here! :eek:)
    P.
    pete, Apr 7, 2006
  3. pete
    FB Guest
    The problem might be inside the ignition switch itself. The tail light
    ordinarily runs off a separate set of contacts than the ignition uses
    so the tail light can be used as a parking light. That's required for
    overnight parking in Japan.
    But the brake lights and turn signals would get their power through the
    same contact.
    FB, Apr 7, 2006
  4. pete
    FB Guest
    I don't. But the Japanese riders have to leave their parking lights on
    all night or park off the street. Japanese home market models will have
    a small parking light on the front, too.
    All export models probably have the wiring for the front parking light
    and may have a cover over a hole in the fairing where the parking light
    would go.
    And, since Japanese home models would need parking lights, there's a
    separate tail light contact in the ignition switch as well as a parking
    light contact. That way you have a tail light when the ignition switch
    is in the ON position or in the PARK position.
    FB, Apr 7, 2006
  5. pete
    FB Guest
    would go.
    FB, Apr 7, 2006
  6. pete
    FB Guest
    would go.
    FB, Apr 7, 2006
