Wonder if anyone can shed any light before I spend too many £s.. I have a 1999 VFR800. When I bought it (about 6 months ago), I'd noticed that the wires to the R/R (3 yellow ones from the alternator) had been 'modified'. The connecting plug had been removed and replaced with bullet-type connectors. Everything seemed ok though - no problems starting/charging so, apart from bolting a cooling fan to the R/R, I left it as is. Yesterday, after about 45mins, I stopped for fuel. Came out and the bike wouldn't start - just clicking form the starter relay under the seat. Lights were bright, horn worked, but the starter didn't even try to spin. After about 10mins, I tried again and it started fine. Rode for another 45 mins, switched off and all fine. After work, when I got home (about 1 hour's riding), had the same problem. I could hear (and feel if I touched it!) the starter relay clicking, but the starter refused to spin. Now, it seems that R/R is common on these bikes, so this morning I did a bit of testing. Off-load, engine off, the battery reads just under 13V. At about 3000 RPM it reads around 14.8V (14.5 with lights on). When running, the voltage seems pretty stable at all revs. I have no idea how old the battery is. Bike has done 19k miles and the service sheet for its 12k service indetifies a charging RR fault - don't know what it was or if it was fixed! Doesn't get used much - mainly weekends. Before I go buy a new battery ad R/R, does anyone have any other suggestions? Anyone got experience of failing starters on theses bikes? Planning to go to LeMans in a couple of weeks and don't fancy being stranded on the ferry! Thanks, ALan
