Vibrating clutches
Discussion in 'Motorcycle Technical Discussion' started by Phil, Non-Squid, Mar 24, 2007.
  1. Do all clutches vibrate? My bike and a friend's car vibrate noticeably
    while slipping. I know that the two types of clutches are different, and
    for the bike case, if the plates are out of round, this will happen. I was
    wondering if this was a common thing or if this happens after the vehicle
    has been out and about for a while.
  2. No, not if they are balanced and properly adjusted, with all pressure
    plate bolts tightened an equal amount.
    The difference is that motorcyle clutches are usually oil-cooled so
    they can be slipped without glazing the fiber plates, and the smaller
    diameter
    of a motorcycle clutch makes it possible for the clutch to be spun up
    to as high as 20K RPM without flying apart.
    I cannot imagine a clutch plate somehow wearing "out of round". I can
    imagine uneven wear on one side of a fiber plate, making it a little
    wedge-shaped, though, and I can imagine the steel plates warping.
    I never knew that motorcycles or cars had any problem coming out of
    the garage ;-)
    But, what you are describing as "vibration" may be what the Brits call
    clutch "judder". Judder is noticeable when you release the clutch
    pedal or clutch lever in order to start out smoothly.
    If the clutch judders, the vehicle starts to move in jerks.
    Judder is caused by uneven engagement of a clutch, and is generally
    caused by improper adjustment of the bolts in the pressure plate. A
    car clutch would have three adjustable bolts to make the pressure
    plate push evenly against the friction plate and the friction plate
    would push against the flywheel surface at all points at the same time
    and the car would start off smoothly.
    Japanese motorcycles don't have adjustable bolts in the pressure
    plate, but old Triumphs had three bolts to adjust, and Harleys had
    them too.
    But when you install the 4, 5, or 6 bolts holding the pressure plate
    on a Japanese motorcycle, you just normally go ahead and tighten them
    all the way.
    Even though the manual may specify a torque for the pressure plate
    bolts, I don't recommend using a torque wrench on oily bolts, I always
    tighten them by hand to avoid breaking them.
    Even though the repair manuals specify tightening the pressure plate
    bolts all the way, it is not impossible for the pressure plate to be
    out of adjustment if some of the parts of the center hub are are worn
    or damaged.
    My GS-1100 had a problem with clutch slip and a friend advised me to
    buy a set of heavy duty clutch springs. When I removed the old
    springs, I discovered that some aluminum spacers on the pressure plate
    bolts were very worn, and some springs were not preloaded as much as
    other springs.
    The typical design of a Yamaha, Suzuki, or Kawasaki clutch lets you
    get at the 4, 5, or 6 pressure plate bolts easily and see exactly what
    is going on.
    But Honda engineers seem to have been reading a Dr. Seuss book when
    they designed their "hillside snee" clutch.
    The "hillside snee" was an animal that grazed on the side of a hill
    and its downhill legs were longer than its uphill legs. If frightened
    by something attacking it from the front, the hillside snee could only
    escape by jumping into its own mouth and turning itself inside out...
    The Honda clutch is designed "inside out". Honda put the pressure
    plate *inside* the clutch basket so the release mechanism could *pull*
    on it from the right side of the motorcycle, instead of *pushing* on
    it from the left side by means of a pushrod going through the
    transmission mainshaft...
    Potage St. Germaine, Mar 24, 2007
  3. Only if it's mounted on the end of the crank. Clutches are geared down
    from crankshaft speed.
    The Older Gentleman, Mar 24, 2007
  4. Phil, Non-Squid
    Gene Cash Guest
    Usually by the primary gear ratio in modern Japanese bikes, as the outer
    rim of the clutch basket is machined into being one of the primary gears.
    -gc
    Gene Cash, Mar 24, 2007
  5. Wops. That's what I meant. My CBR's old fibers were wedged (could see the
    indentations flat on one side but not the other), but I couldn't
    tell/measure anything on the steels.
    I broke one of the 4 clutch spring bolts when I replaced the clutch fibers
    last spring. I replaced it with one from Lowe's. Seems to work fine. It
    was during tightening that it snapped off. Didn't have a torque wrench, but
    at 135lbs, I'm not known for having ham-fisted methods.
    I looked for signs of wear but didn't really find any.
    It took a while for me to get my head around that diagram, but I did finally
    get it.
  6. If there is anything at all different about that bolt, it may be
    causing problems with the alignment of the pressure plate, and that
    may cause abnormal fiber plate wear.
    Hardware store bolts are often threaded all the way, or the length of
    the threaded part is different from the length of the threads on the
    bolts that the motorcycle manufacturer has made specially for their
    own designs.
    If the manufacturer of the clutch intended the bolt to be threaded
    into the clutch basket until it stopped,
    a bolt that's threaded all the way may cause pressure plate alignment
    problems because it threads too far into the bolt hole.
    And, the motorcycle manufacturer will generally specify a high
    strength bolt for critical applications.
    When you look at the head of a utility grade metric bolt, it won't
    have a number on it. But the high strength bolts do have numbers. The
    Japanese didn't put numbers like "6" or "8" on the heads of bolts for
    good luck.
    Never substitute a utility grade bolt for a high strength application.
    The three high strength allen bolts that held the starter clutch to
    the back of the alternator rotor snapped on my Suzuki, and the parts
    department at the local $tealer$hip didn't have the right grade bolt.
    The parts weenie found some lower strength bolts that were the right
    thread, so I tried to use them.
    Needless to say, I had to do the job all over again when the weaker
    bolts broke.
    Potage St. Germaine, Mar 25, 2007
