Vices.
Discussion in 'UK Motorcycles' started by Krusty, Mar 18, 2006.
  1. Krusty wrote
    Air cooled bikes rock.
    steve auvache, Mar 19, 2006
  2. Krusty
    ....and oil cooled
    Hog, Mar 19, 2006
  3. Krusty
    <eyebrows rise>
    Take hold of the new link. Open the sachet of grease, lube the pins
    and wipe a bit at the base of each pin. Drop an 'O' ring on each pin.
    Squeeze a bit of grease onto the 'O' ring.
    Line up the link with the chain ends and slide the pins through. Push
    an 'O' ring onto each pin, squeeze some grease onto it and close with
    the side plate.
    Mushroom the ends of the pins.
    I'll do you a swap for my Bandit: it has a new chain and doesn't use
    coolant.
    Pip, Mar 19, 2006
  4. Krusty
    Aye but that's the knarly bit that folk don't like doing.
    I'm not that keen on it myself, if the right chain tool isn't to hand,
    as I never feel positive that I didn't get the link too tight or the
    pins sufficiently secure.
    I know *precious*
    Hog, Mar 19, 2006
  5. Krusty
    Pip emerged from their own little world to say
    <pedant mode>
    apart from the oil that is
    </pm>
    wessie, Mar 19, 2006
  6. Krusty
    All of the above I'd already done...
    ....but this bit stopped me in my tracks. I was expecting the pins to be
    hollow, like wot they usually are. But they ain't. It was only when I
    spotted the clip link buried at the bottom of the bag that the light
    dawned. Looks like I'm going shopping tomorrow[1].
    Jolly kind of you, but I couldn't possibly put you to such
    inconvenience.
    [1] Which should make BGN happy.
    Krusty.
    http://www.muddystuff.co.uk
    http://www.muddystuff.us
    Off-road classifieds
    Krusty, Mar 19, 2006
  7. Krusty
    heh - excellent plan.
    Krusty.
  8. Krusty
    Did you leave the hub lying flat when it was in the oven or did you
    have it standing on it's side?
    Andy Bonwick, Mar 19, 2006
  9. Krusty
    On its end, so the hole was facing up iyswim. Why? Are you going to
    tell me it's now distorted & I have to go & buy a magnesium one to
    replace it - please...
    Krusty.
  10. Krusty
    O.IC. HST, I'm sure I've mushroomed solid pins before - you only need
    to spread them a tiny amount, to retain the side plate. Four taps
    with a medium hammer, while holding a big hammer behind works for me.
    This place is going downhill. No V-Max yesterday, now no MV today.
    You're all tight cunts.
    Pip, Mar 19, 2006
  11. Krusty
    I tend to make sure they're riveted properly leaving no chance of them
    making a break for freedom. A centre punch is usually employed to
    leave a nice big dent in the centre then a ball pein hammer completes
    the procedure.
  12. Krusty
    Hey, I only do this sort of crap on an almost daily basis so what
    would I know about heat distortion?
    Have you checked that the bearing isn't still loose after the casting
    cooled down? This one is quite serious btw, some castings don't return
    to the same size after being either heated or frozen. You might have
    to spend some of your hard earned cash..
  13. Krusty
    I think you may have misunderstood my "please", & on reading it back, I
    can see why you might. I meant 'please tell me I need to buy a mag one
    coz I really, really want one', not 'oh purleeeese, gimme a break'
    iyswim.
    The second bearing was harder to get in, so I think it had shrunk
    again. Plus it's a fairly tight fit in the swingarm, so I'm pretty sure
    I'd have noticed a struggle if it was still swollen. Also the
    paintmarks on the pinch bolts lined up perfectly when torqued - another
    good sign. I'll keep a close eye on it for the first couple of hundred
    miles though.
    Krusty.
  14. Krusty
    I thought softlink pins generally had hollow ends? Anyway the problem
    is as this is a split link, the pins are longer, & have grooves for the
    circlip thingy just outside the sideplate. So whilst I could splay the
    ends enough to stop the sideplate coming off, it would still have room
    to move out & let shite in behind it. I think a trip to my local bike
    emporium for a pukka softlink would be more prudent.
    Krusty.
  15. Krusty
    Good plan. I wouldn't try to use a hard link as a soft one and I
    wouldn't use a spring clip on something putting out (at a guess) about
    110bhp as your bike probably does.
  16. Krusty
    I'd sussed out that you might want a magnesium one hence my comments
    in the next paragraph.
    That's ok then. I've fucked up more than once putting components
    together by using heat where it really wasn't the best idea.
  17. Krusty
    Gyp Guest
    Dad's got a big one & lives in ' Bassett.
    Gyp, Mar 19, 2006
  18. Krusty
    110? Bloomin cheek! 145 to be precise.
    Krusty.
  19. Krusty
    Aye, positive. There was a chain, a quick release sprocket system & two
    sprockets, but no softlink.
    Krusty.
  20. Using the patented Mavis Beacon "Hunt&Peck" Technique, Gyp
    Not to worry, these things often skip a generation.
    Horse will thank him for it.
    Wicked Uncle Nigel - To stay young requires unceasing cultivation of
    the ability to unlearn old falsehoods.
    Wicked Uncle Nigel, Mar 19, 2006
Similar Threads
Loading...
