vz800 maurader 1999 front forks
Discussion in 'Motorcycle Technical Discussion' started by atastroke, Nov 15, 2008.
  1. atastroke
    atastroke Guest
    How to get springs out of upside down forks.
    Talk to me !!!!!!!!!!!!!!!!!!!!!
  2. atastroke
    . Guest
    First time I ever saw upside down forks that didn't have stacked shim
    damper cartridges,
    What a joke...
    http://webservices.motorsportdealers.com/parts/partImages/SUZ/2/02/13/0050.Gif
    Remove the #11 CAP
    Compress the spring with some sort of forked tool.
    Unscrew #9 NUT with some sort of thin spanner.
    You may have problems with the upside down damper rods turning when
    you try to loosen the caps.
    An air impact wrench may be indicated...
    ., Nov 15, 2008
  3. atastroke
    . Guest
    Apparently the $crewzuki engineers never planned for anybody to ever
    replace the fork springs.
    That's why the springs aren't shown on the drawing...
    The ends of the steel stanchion tubes and the aluminum caliper
    brackets are probably threaded and screwed in place with Loctite to
    keep them from loosening.
    I suppose you could heat the brackets in an oven to melt the Loctite
    so you could unscrew the brackets without burning the paint off...
    But that could result in a bucket of worms when you go to reassemble
    the parts.
    If you don't get every trace of Loctite off the threads, it's like
    cross threading when you screw the brackets back on. It takes *heat*
    to melt the plastic Loctite.
    Progre$$ive $uspen$ion seems to have a *generic* fork spring that fits
    many *other* motorcycles.
    The generic Progre$$ive documentation probably wouldn't be a lot of
    help.
    ., Nov 16, 2008
