wah wah wah
Discussion in 'Australian Motorcycles' started by Brett, Jun 21, 2004.
  1. Brett
    Brett Guest
    Damn
    My indicator switch died on the way to work last night. I indicated right
    for the last 5 klicks. Just got a price for a new switch block - over
    $200!. Why don't they make them repairable or modular. IAW Murphy's Law
    this happened the day after I spent $100 that I couldn't afford to spend on
    tickets to a concert. In keeping with the ambience of the bike I am
    thinking of wiring in a bodgy switch. An on-off-on toggle switch in a 35mm
    film cannister electrical taped to the handlebar should do the job.
    Brett
    R(atbike)80
    Brett, Jun 21, 2004
  2. Brett
    Moike Guest
    http://www.motobins.com/displayfinal.php?function=show&subs=222a&title=LEFT/LIGHTING
    Moike
    Moike, Jun 21, 2004
  3. In aus.motorcycles on Mon, 21 Jun 2004 17:25:32 +1000
    What makes you think it isn't repairable?
    And why not go to a wrecker, get something more or less right, and wire
    it in?
    Zebee
    Zebee Johnstone, Jun 21, 2004
  4. Brett
    sharkey Guest
    Odd that, the Honda ones are ... are you sure you can't sneak it
    apart somehow?
    Discount Motorcycle Wreckers in Brunswick do lots of older
    BMW stuff.
    Well, you could. Your other option would be to grab your current
    worthless switchblock, pull out its innards, bog up the holes and
    drill a new hole for the toggle switch! Very nice.
    -----sharks
    sharkey, Jun 21, 2004
  5. Brett
    Mad Biker Guest
    I took the spuds one appart and cleaned it out and used washers to space it
    so it springs freely - works well now
    should be 2 screws underneeth that you take it off with, and then you can
    pull it appart from inside of it. i think they are mostly the same so buy
    one that looks similar with the same switches from a wrecker and wire it up.
    or use your hands to turn :)
    Mad Biker, Jun 21, 2004
  6. Brett
    Brett Guest
    I'm having a go at fixing it but don't hold out much hope. It's definitely
    not meant to be fixed, I had to hacksaw it, bend bits out of the way to get
    at the broken piece. I have glued the broken piece together. If that
    holds, I then have to return the switch block to some resemblance of its
    original shape and see if it works.
    The only place in Bne that wrecks BMWs is the place I can get the new one,
    they don't have a second hand one either.
    Brett, Jun 22, 2004
  7. Brett
    Brett Guest
    you would think they are mostly the same. Most of the ones I have seen are
    a top and bottom half that clamp around the handlebar. Mine has a metal
    handlebar clamp whish has the choke lever on it. the switch block is a
    plastic panel that screws on the clamp facing the rider.
    Brett, Jun 22, 2004
  8. Brett
    Moike Guest
    Moike, Jun 22, 2004
  9. Brett
    Nev.. Guest
    It's hardly a ratbike if you're pricing a new switchblock. A 3 position
    toggle switch from Jaycar is about $2
    Nev..
    '03 ZX12R
    Nev.., Jun 22, 2004
  10. Brett
    Brett Guest
    thanks but it's my daily transport so i have to fix it quick
    Brett
    Brett, Jun 22, 2004
  11. Brett
    Brett Guest
    I'm 'pricing' one not necessarily 'buying' one.
    Brett
    Brett, Jun 22, 2004
  12. Brett
    Brett Guest
    it's fixed! it works! for how long I don't know
    Brett, Jun 23, 2004
  13. munich motorcycles in WA is a good place to buy new and second hand
    parts for BMW
    http://www.munichmotorcycles.com.au/
    or at least they were the last time i needed to replace broken bits of BMW
    fulliautomatix, Jun 23, 2004
Similar Threads
Loading...
