Walkie talkies
Discussion in 'UK Motorcycles' started by Lozzo, Aug 22, 2006.
  1. Lozzo
    Some of you may know that I recently started spannering for a mate who
    races a ZX10R in MRO Powerbikes class[1]. Tori and I also do the pit-
    boarding, which is a bit of a laugh as at some circuits you can't see
    the rider clearly enough to give accurate signals in time to help in an
    8 lapper. All we ended up doing was counting the laps down on one
    occasion.
    On September 15th Danny's at Brands Hatch on the GP circuit, which is
    crap from a pit-boardng point of view. I'm looking to borrow a pair
    walkie talkies for the weekend so Tori can stand at Westfield and relay
    Danny's progress in time for me to put the right signals out for him.
    Can anyone please help? Last time we used mobile phones to communicate
    on the Indy circuit, but that got a bit expensive over 14 laps.
    [1] http://www.imbergracing.co.uk/
    Lozzo, Aug 22, 2006
  2. Using the patented Mavis Beacon "Hunt&Peck" Technique, Lozzo
    Yep. Pop over next time you're in the area and I've got a couple you can
    use.
    Wicked Uncle Nigel - Podium Placed Ducati Race Engineer As featured in
    Performance Bikes
    Wicked Uncle Nigel, Aug 22, 2006
  3. Lozzo
    Wicked Uncle Nigel says...
    Has anyone ever told you that you're a very nice man? Thanks.
    Lozzo, Aug 22, 2006
  4. Using the patented Mavis Beacon "Hunt&Peck" Technique, Lozzo
    Not with a straight face.
    NP, IIRC you're around at the weekend anyway, aren't you?
    Performance Bikes
  5. Lozzo
    I think I'm helping nosh an RD400 engine back together with window
    sealer and hairpins, just like we used to back in the good old 80s.
    Lozzo, Aug 22, 2006
  6. Lozzo
    Gyp Guest
    You don't need a walkie talkie; you need a Suze, you do
    Actually that's the answer to so many questions...
    You don't need a <insert item, person or concept here>; you need a Suze,
    you do
    Gyp, Aug 22, 2006
  7. Using the patented Mavis Beacon "Hunt&Peck" Technique, Lozzo
    <slaps forehead>
    <adds hairpins to shopping list>
    Thanks mate, I knew I'd forgotten something.
    Performance Bikes
  8. Lozzo
    **** that. You don't buy them, you raid your little sister's bedroom for
    them.
    Lozzo, Aug 22, 2006
  9. Using the patented Mavis Beacon "Hunt&Peck" Technique, Lozzo
    Ah. One tiny flaw in that plan.
    Performance Bikes
  10. Lozzo
    Gyp says...
    Those Suzes are a bit rare and hard to find, they only come in little
    sizes too, which is a bonus in some respects.
    Lozzo, Aug 22, 2006
  11. Lozzo
    It's ok, I still have a little sister who has her own hair.
    Lozzo, Aug 22, 2006
  12. Lozzo
    Suze Guest
    <wave>
    Guest appearances can be arranged :)
    Suze, Aug 23, 2006
  13. Lozzo
    Vass Guest
    £ 20 in comet !
    Vass, Aug 23, 2006
  14. Lozzo
    Trev Guest
    PMR radios have a range of between 3-5 miles and have loads of channels to
    choose from. Should be good for track comms
    http://tinyurl.co.uk/bpge
    Cheers
    Trev
    Trev, Aug 23, 2006
  15. Lozzo
    gomez Guest
    Many tracks are EMF pollution sewers, so cheaper radios hardly work at
    all.
    gomez, Aug 23, 2006
  16. In uk.rec.motorcycles, Lozzo belched forth and ejected the following:
    You can buy a pair for 20 quid.
    Whinging Courier, Aug 23, 2006
  17. Lozzo
    Vass Guest
    ginge!
    Vass, Aug 23, 2006
  18. Lozzo
    ChrisDC Guest
    Unfortunately, this is bollocks. They have only 8 different
    frequencies (channels).
    However, what they do have is a coding system that, even if someone
    else is hogging the channel, means you don't have to hear what they
    are saying unless you want to, and there are over 100 of these
    integrated codes.
    It is probably the most cost-effective solution, but you may have
    trouble finding a clear channel if there are many pmr sets in use
    there.
    ChrisDC, Aug 23, 2006
  19. Lozzo
    Moon Badger Guest
    If you think this may become regular, or you want a cheap bike to bike
    intercom, buy your own.
    Avoid the cheapies, they truly are shyte.
    Look for the acronyms CTSS and DCS.
    A lot of the bog basic cheapies are 8 channel only and you get a lot of kids
    playing with them, you will also pick up any CTSS transmissions.
    CTSS is the minimum. This gives you 38 'sub channels'. Its basically the
    same 8 channels but a continuous tone is transmitted along with the
    original signal. If you are using a CTSS channel along with your main
    channel, it should squelch out all transmissions not using that CTSS tone.
    Much clearer as a result.
    DCS gives you digital coded squelch and is clearer still. The transmission
    is still analogue, but you'll now get a larger range of sub channels ( 93 I
    think ) per main channel and anyone just on the base channel just hears a
    high pitched hiss.
    Cobra or Midland/Alan are good basic radios. I get between 0.25 to 3 miles
    range from mine depending on terrain. Motorola DCS units are very good, but
    pricey.
    If you want to find out more, try http://www.446user.co.uk/
    Moon Badger, Aug 23, 2006
  20. Lozzo
    Kim Bolton Guest
    As a bonus, the Midland G5 - which is small, light, easy to operate,
    and bought as a pair in a blister-pack come with NiMH batteries and a
    mains charger - also has a biker kit available for it.
    It has the basic CTCSS tone system for 'privacy', but has a good
    reputation and is easily available.
    A headset is also available, which can be used with the VOX for to
    make a hands-free unit; useful e.g for doing a pit board at the same
    time.
    All these options push up the cost, so it might be better to take up
    the offer of a loan pair first, to see if there any over-riding
    problems such as channel-usage, etc.
    Kim Bolton, Aug 24, 2006
