Want a Triumph...
Discussion in 'UK Motorcycles' started by AntonyF, Apr 8, 2007.
  1. AntonyF
    AntonyF Guest
    I have just decided, I really want a Triumph Daytona :eek:) - or some model of
    (modern) Triumph anyway.
    Actually, I tend to be rather sluggish when it comes to getting the stuff I
    really wanted in the first place.
    Anyone wanna swap for a Cruiser ? Oh well, back to daydreaming and wishful
    thinking for me I think !
    If I do seriously go for it, any advice on anything particular to avoid with
    Daytona's / Triples ?
  2. AntonyF
    AntonyF says...
    Servicing. If the bike is coming up for, or just past, 12,000 miles
    check to see if the big service has been done. It can cost upwards of
    500 quid, so budget accordingly. You'll need to do an interim service
    halfway between every 12,000 one, but these are usually much cheaper as
    valve clearances don't need doing.
    Aside from that the big triples don't have many issues, but some did
    suffer from weak starter clutches which cost about 800 quid to repair.
    Never let the battery get too flat, because it's low cranking power that
    causes them to fail as they slip out of engagement.
    I love my Daytona, it's a real world sports bike. By that I mean a Gixer
    Thou or ZX10R is more at home on a track and being caned senseless,
    where the Daytona will eat up mile after mile in a more relaxed way but
    still be plenty fast enough for any normal person on the road. It's more
    GT bike than sports bike, like an Aston Martin DB9 is to a Lamborghini
    Diablo.
    Lozzo
    Suzuki Bandit 600S (Green with added shit bits)
    Yamaha SR250 Delusion (It's "Special")
    I ride way too fast to worry about cholestorol.
    Lozzo, Apr 8, 2007
  3. AntonyF
    Early T595 Daytona plenty cheap in yellow and there are loads of them
    around.
    Hog, Apr 8, 2007
  4. You've really learnt to like the triples engine then. Lots of mid range
    torque. I think that's why I like the ST so much.
    eric the brave, Apr 8, 2007
  5. AntonyF
    eric the brave says...
    It's wonderful, can't think why I didn't buy one earlier.
    Lozzo
    Lozzo, Apr 8, 2007
  6. AntonyF
    Molly Guest
    I'm fancying a Triumph again.
    Molly, Apr 8, 2007
  7. AntonyF
    Ken Guest
    Berluddy Hell! 500 quid. Are they really that difficult to work on?
    I was actually browsing Triumphs for sale last night, but perhaps I'll
    stick with my Bandit 1200. At least I can maintain that myself at a
    reasonable cost.
    Ken, Apr 8, 2007
  8. AntonyF
    Ken says...
    It's 500 quid every 12,000 miles, and that includes fairing removal and
    almost half the rest of the front of the bike being stripped to do the
    valve clearances. Ok, so a Bandit 1200 may appear easier to work on, but
    I'll bet the servicing costs over the same mileage work out about the
    same if a dealer does them. If you're doing it yourself then labour
    rates don't come into it. Service parts prices are about the same as any
    other bike manufacturers.
    I've ridden lots of Bandit 1200s, the Daytonas and Speed Triples are far
    nicer to ride and own. For a start off they don't dissolve when they see
    rain falling 100 miles away and they go round corners without that
    'pregnant hippo on acid' feeling.
    Anyway, I don't begrudge paying for servicing - or anything else come to
    think of it - if I'm enjoying the bike. When I have to think about what
    motorcycling costs me I'll hang up my helmet for good.
    Lozzo
    Lozzo, Apr 8, 2007
  9. Depends. Are Bandit valve clearances shim or screw/locknut?
    If shim, are they under the bucckets or on top? Triumph, I'm assuming,
    are on top (they were on my Trophy)
    The Older Gentleman, Apr 8, 2007
  10. AntonyF
    The Older Gentleman says...
    Bandit adjustment is by screw and locknut, Triumph shims are on top of
    buckets and require a special tool to hold the bucket down, but pattern
    tools are avalable from t595.net. Shims are a piece of piss to do once
    you've done one lot. At least there are only 12 shims to do on a triple
    and they don't need doing anywhere near as often as Bandit clearances.
    Lozzo
    Lozzo, Apr 8, 2007
  11. AntonyF
    Adie Guest
    and it takes a full day to do it. they had mine from 9am and i
    couldn't pick it up til 4.30pm.
    they gave me a nice R1 to play on for the day though.
    Adie
    keeper of the ukrm faq for my sins
    YZF-R1: ZX9R E1
    Adie, Apr 8, 2007
  12. I was out on mine earlier today. Did Skenfrith the long way round with
    the SO and BIL. Lovely day for it.
  13. Bandit 12 is the same as GSXR100L M models had shim. Early Triumph have
    shim on top of bucket but I thought later Triumph's had shim under bucket?
  14. AntonyF
    I'm told the 955 engines are shim on top. I thought the Gixer 1100 went
    to shims on the WN watercooled model, the M was oil-cooled and I'm sure
    they had screw and locknut.
    Lozzo
    Lozzo, Apr 8, 2007
  15. Yes but, have you seen the list of things to do at 12,000 mile services?
    Like fork oil, head race bearing re-grease, full cable lube, change the
    hydraulic fluid, swinging arm pivot re-grease. It's very comprehensive.
    If you just want the cheaper version I.E. shims, injector balance, oil +
    filter then it's only £150 depending on shim replacement. You still get
    your book stamped for the service though.
  16. eric the brave <""simonb_at_zapik_dot_co_dot_uk\"@foo.com (eric the
    If they slapped enough grease on when building the things, this wouldn't
    be necessary.[1]
    Oh, please. How many dealers do this? And with teflon-lined cables, it's
    actually counter-productive in some cases.
    OK, though I can't see that's necessary.
    If they fit grease nipples, it's OK, If not, see above.
    [1] My Ducati races - lasted four years before they were utterly fecked.
    I think Ducati wave a bottle of olive oil at them, and that's it. Dealer
    replaced them and used half a tub of grease, it seems, on the new ones.
    Which have so far lasted six years.
  17. AntonyF
    I think so.
    Lozzo
    Lozzo, Apr 8, 2007
  18. Mine was an M. Was that the last Oil cooled model?
  19. I agree, that's why I will just get the shims, and balance done. Do the
    rest myself.
  20. AntonyF
    Bah, the last oil/air cooled 1100 was the N model, the watercooled ones
    came about in 1993 with the WP. Pretty sure the 1100 stayed screw and
    locknut til the watercooling came about though.
    Lozzo
    Lozzo, Apr 8, 2007
