Warranty question...
Discussion in 'Australian Motorcycles' started by Centurion, May 10, 2004.
  1. Centurion
    Centurion Guest
    Are brake discs usually covered under warranty? Found out at Eastern Ck on
    Friday that the '9 has a gawd awful shudder from the front discs when
    braking hard at anything over about 150km/h. :( Makes turn 1
    interesting; ...4th, 5th, 6th (270km/h or so), grab the brakes, *holy
    crap!* get off the brakes!!, 5th, bugga, bugga, pucker factor 10....
    Had a look at the discs after the first session and there's all these little
    "dots" on the discs (about the same size as the vent holes) - looks like
    little raised sections. What's my chances of Kwakka fixing it up? Can you
    machine bike discs?
    James
    ZZR250==>ZX9R
  2. Centurion
    Johnnie5 Guest
    how old ? how many kays ???
    do a google for matt , aprilia and warped brakes and you will find yourself
    quite an interesting story ;)
    Johnnie5, May 10, 2004
  3. Centurion
    Manning Guest
    Tried that, got 19 hits and the closest was something about a Laverda. Wanna
    give us a bit more info (or a link?)
    Manning
    Manning, May 10, 2004
  4. Centurion
    Johnnie5 Guest
  5. Centurion
    Duncan Guest
    They are machinable but that will possibly get them close to their service
    limit.
    If you're bike has the 6-pot tokicos (same as 98-01? 6R) then the standard
    thickness is 4.85-5.15 mm and the sevice limit is 4.5 mm. So you can
    imagine there really isn't too much to play with.
    My discs started wearing funny with pronounced ruts running like record
    grooves after the first set of pads but they still worked fine. Now I am
    down to the service limit (a bit beyond actualy) but I'm going to hold out
    until the pads wear out as after market discs cost $400 EACH and OEMs are
    anywhere up to double that.
    I plan on looking into getting discs from a wrecker.
    Oh yeah another thing I remeber hearing is that is there any evidence of you
    ever having used a disc lock (rust patterns?) then they'll automaticcaly
    blame that. I took off full throttle a couple of times on my ZZR250 with
    the lock on and it developed a horrible low speed shudder.
    Duncan, May 10, 2004
  6. Centurion
    Biggus Guest
    I would guess not, but you can always try
    Biggus, May 10, 2004
  7. Centurion
    Centurion Guest
    1 year, 11 months - 2 year warranty. 14,768km.
    Offline ATM - saw your link lower in the thread....I'll check it out.
    Cheers,
    James
    ZZR250==>ZX9R
  8. Centurion
    Centurion Guest
    Actually it's a 2002 ZX9R so it's got 4 pot Nissin's. I'd say the
    tolerances are pretty similar tho; 3/8's of 1/5 of bugger all.
    James
    ZZR250==>ZX9R
  9. Centurion
    Centurion Guest
    Thanks yeh - dumb is good. I can do that when it comes to mechanical thingy
    whatsits.. ;)
    James
    ZZR250==>ZX9R
  10. By all means, go for it, but I think you may be out of luck.
    For starters, they will claim that the disks are a consumable, (with a
    service limit and the like etc) which may or may not let them get away with
    it.
    But, as soon as you say it doesn't happen till you are doing over 150km/h on
    it, they will probably deny your warranty claim.
    There are exclusions in there about all sorts track riding including track
    days, and not just competition racing. And it will be a bit hard for you to
    argue that they need to replace it because you are having trouble doing
    40km/h over the limit on a public road.
    I suppose you could always say "I went to the northern territory for a
    holiday and...."
    James Mayfield, May 11, 2004
  11. Centurion
    Centurion Guest
    I think you may be right on this point - although the irony of it is that
    the machine is DESIGNED to travel at much higher speed than the safety
    nazi's on NSW will let you.
    Yeh - checked the warranty and the only exclusions (along the track-day
    lines) are for damage that occurs in competitive riding in organised
    competitions or events. I guess *how* they define 'competitive riding in
    competitions or *events*' is the clincher.....they don't say that though.
    Yeh - I like that idea :p
    James
    ZZR250==>ZX9R
    Centurion, May 11, 2004
  12. Centurion
    Johnnie5 Guest
    same claim made by aprillia and didnt stand up in court
    checkt the link and go for your life , ben done here once before
    email matt and he might help you out
    Johnnie5, May 12, 2004
