Weight Watching
Discussion in 'UK Motorcycles' started by Hog, Oct 2, 2006.
  1. Hog
    Thank you, Mr. Malthus.
    darsy, Oct 3, 2006
    #41
  2. Might be the Rise of the Insects. Mankind will succeed in poisoning the
    oceans and it'll be Goodbye Flipper. No more cute jumping through hoops
    at OceanWorld.
    Grimly Curmudgeon, Oct 3, 2006
    #42
  3. Hog
    Scraggy Guest
    wessie wrote:
    Dolphins will rule the largely aquatic rock.
    Only if the mice let them.
    Scraggy, Oct 3, 2006
    #43
  4. Hog
    Baloney Guest
    What a loser!
    But I can't, I'm a loser.
    I will look into this and see if I can improve this aspect of my new found
    posting skills.
    Baloney, Oct 3, 2006
    #44
  5. Hog
    Baloney Guest
    [just had a couple of pain au chocolats (always feel a twat saying
    Errr. Huh huh. Eeerr. uhuh, huh
    1) I have no idea. Even after visiting dictionary.com, I have absolutely no
    idea.
    2) Not that I'm aware of. But you never know. I do feel rather special
    sometimes.
    #45
  6. Hog
    Absolutely.
    Pip Luscher, Oct 3, 2006
    #46
  7. Hog
    catman Guest
    As in 'bus'? ;)
    www.cuore-sportivo.co.uk
    catman, Oct 3, 2006
    #47
  8. Viruses mutate faster than humans.
    Darren Robinson, Oct 3, 2006
    #48
  9. Hog
    porl Guest
    Bit academic then, isn't it? Unless some other form has evolved enough
    to be able to appreciate history from 50 million years previous.
    Evolved cats maybe.
    "These sediment results from the 21st century are fascinating, Zongcat.
    Those humans really screwed things up. Pass me my coffee would you? USE
    TWO PAWS..! Damn, you idiot. Go and make me another one"
    porl, Oct 3, 2006
    #49
  10. Hog
    <relaxes>
    Hog, Oct 3, 2006
    #50
  11. Hog
    Krusty, Oct 4, 2006
    #51
  12. Hog
    Steve Parry Guest
    edited HTH ;)
    Steve Parry, Oct 4, 2006
    #52
  13. Hog
    porl Guest
    And you, sir, are ugly. But in the morning I'll be sombre. Or something.
    porl, Oct 4, 2006
    #53
  14. Hog
    I haven't, no, but I think I get the primordial message
    Hog, Oct 4, 2006
    #54
  15. Hog
    Well, I've been to Devizes, but I didn't...
    Waitaminute. Those used to be human?
    platypus, Oct 4, 2006
    #55
  16. Hog
    Rubbish, twaddle and codswallop.
    _______
    Ace, Oct 5, 2006
    #56
  17. Hog
    Thank **** for that
    Hog, Oct 5, 2006
    #57
  18. Hog
    catman Guest
    Glad you said that.
    catman, Oct 5, 2006
    #58
  19. Hog
    catman Guest
    Ace may well have a different / more accurate take (see disclaimer), but
    the development of immunity by a host is a completely separate process
    from the mutation of the virus.
    Also, while you are sort of correct that it *may* not be in the *best*
    interest of the virus to kill it's hosts too quickly, to suggest that
    the essentially *random* mutation will tend to produce specifically less
    dangerous forms is obviously flawed.
    The amount of time that many viruses have been around would mean that
    they were all pretty much harmless.
    Since the mutations that cause 'evolution' are essentially random, the
    successful phenotypes will be determined by selective pressure in the
    environment. *Some* will be less dangerous, some will be more
    dangerous, some will be roughly the same and some will be non-viable.
    Disclaimer: I last studied this in 1992 and I wasn't particularly good
    at explaining it then (as my degree will attest) Although I'm pretty
    sure the above is accurate, it may be badly phrased, or not particularly
    comprehensible :)
    catman, Oct 6, 2006
    #59
  20. Hog
    Not really. Yes, random mutations will tend to produce, given enough
    time, more and less virulent forms of a virus, but these new forms,
    assuming they are reproducable, will only be favoured if there's some
    strong pressure on the existing form that favours the new one.
    In the case of a highly successful virus like HIV there's clearly no
    barrier to the virus's procreation in the current environment, given
    that it takes months or years to kill its victims, during all of which
    time they remain highly contagious, so why would a less virulent form
    be any more successful?
    This could occur, but only in the most extreme cases, where for
    whatever reason the virus both caused the death of the host and
    guaranteed its lack of infectiousness within such a short timescale as
    to render it impossible to pass on to another host. Clearly this is
    not the case with a nearly pandemic virus such as we're discussing.
    If nothing else, it seems that you're falling into the trap of
    thinking about evolution from a design perspective. One might argue
    that if virus A developed characteristic X it would have a greater
    chance of survival, but for this to happen there must be a clear chain
    of events, starting with the ability for a small genetic mutation to
    cascade into the 'required' physical changes, coupled with there being
    some noticeable advantage to survival for every link in the chain.
    Examples where this can be observed are in antibiotic-resistant
    bacteria. All the normal ones are killed off, so only those very very
    few that have somehow mutated such that they're not so vulnerable to
    the antibiotic will survive at all. In this situation, particularly
    coupled with inappropriate or incomplete treatment, strains of the
    bacteria with stronger and stronger resistance can be produced.
    It's perhaps worth pondering on the number of times this _doesn't_
    happen (i.e. 99.99999999% of the time).
    _______
    Ace, Oct 6, 2006
    #60
