Weird thunking from a 2000 fireblade
Discussion in 'UK Motorcycles' started by Mark, Jul 27, 2005.
  1. Mark
    Mark Guest
    Morning,
    I have a problem with a 2000 fireblade I've had from new which
    has 20k miles on it. When I'm banked in a corner at slow speed
    (mini-roundabouts, that kind of thing) I'm getting a thunking
    from the bike. It's not something I can hear but something I
    can feel through the left peg (not the right one). The frequency
    of the thunking is wheel speed as much as I can judge. I also
    get the thunk if I stop, pull in the clutch and then pull away
    and within a second or so I get a single thunk and this happens
    when I'm upright, if I'm banked I get the 'normal' series of
    thunks. The noise is always more pronounced when the bike is
    warmed up towards the end of my commute.
    The chain is 5000 miles old (first chain change at 15k miles)
    and looks in good nick and there's no obvious wear on the
    sprockets. I put in a new cush drive about a month ago as the
    old one was shafted and causing horrible gearchanges. The bike
    seem extraordinarily sensitive to chain adjustment (always has
    been) but the problem didn't change when I adjusted the chain a
    couple of days ago. Apart from the thunking there's no apparent
    change to the way the bike rides. Looking through the oil filler
    hole there's no obvious notching of the clutch basket but you
    can't obviously see that much.
    Given the frequency of the thunk my first suspicions were that
    this was an early sign of failure of the rear wheel bearings but
    would very much appreciate a second opinion so I can fix it
    quickly and not have to resort to taking the train to work.
    Thanks for any help.
    Regards,
    Mark, Jul 27, 2005
  2. Mark
    Sounds more likely to be the cush drive than the bearings. SWK will be
    along shortly, but I'd probably try and distinguish by raising the
    rear wheel and trying to wobble by hand - if it's just
    forward/backward movement it'll be the cushes, side-to-side is the
    bearings.
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Jul 27, 2005
  3. Mark
    riccip Guest
    That's what it seems to point to. Can you feel any play in the
    rear wheel when it's off the ground? Try removing the chain and
    spinning the rear wheel by hand. If it's that bad you should feel
    it through the spindle.
    riccip
    riccip, Jul 27, 2005
  4. Mark
    Mark Guest
    No, there's no play in the rear wheel.
    The problem, I think, is that there are 3 bearings in the rear wheel,
    2 in the wheel itself and one in the sprocket plate that slots in the
    cushdrive. My suspicion is that as I can only feel the thunk through
    the left peg the bearing in the cushdrive plate has gone south and
    transmitting the thunk down the chain to the front sprocket which is
    next to the left peg. I guess dirt in the bearing when the chain was
    changed, when I installed the cush drive or on one of the occasions
    the rear tyre was changes or the grease in the bearing may have just
    washed out. Does that sound feasable?
    Anyway, I'll get the wheel off tonight and see if any of the bearings
    are notchy.
    My worst fear was that the gearbox has died and it always has felt as
    clunky as hell (thank you mr honda) and the chain only has to be a bit
    slack for it to feel terrible.
    Thanks,
    Mark, Jul 27, 2005
  5. Mark
    Mark Guest
    Took the wheel off, removed the chain and put the wheel back
    on and the wheel spins freely with no noises. Took the wheel
    back off and felt the wheel bearings and they are smooth but
    the sprocket carrier bearing is slightly notchy. No tight
    spots in the chain and the front sprocket doesn't have any
    play in it. Guess it must be the sprocket bearing starting
    to go so I'll change that and see if there's any difference.
    Cheers,
    Mark, Jul 27, 2005
  6. Mark
    Mark says...
    OK, this is going to sound really stupid, but when you have the bike on
    the paddock stand, make sure the rubber cups aren't hitting the
    sprocket nuts when you spin the wheel.
    I know it's not relevant to your situation, but it may stop someone
    else from doing what I very nearly did when this happened on my Elly's
    rat-bike. I came very close to replacing the rear wheel bearings for
    her.
    Lozzo, Jul 27, 2005
  7. Mark
    Mark Guest
    Lol, done that and then spent minutes trying to get it in neutral so
    the wheel would go around.
    It was fine on the stand, just felt the notchyness rolling the inner
    bearing race with my finger.
    It is noisy just rolling it up the drive in neutral but then it always
    has.
    Regards,
    Mark, Jul 27, 2005
  8. Mark
    SP Guest
    My Elly's? I fort Elly was Pip's?
    Lesley
    CBR600FW
    BOTAFOT#101A UKRMHRC#12
    BONY#54P BOB#18
    SP, Jul 29, 2005
  9. Mark
    SP says...
    When I was writing it I thought it might have been my 9R, then I
    remembered it was Elly's rat so changed *most* of the post.
    Lozzo, Jul 29, 2005
  10. Mark
    It is a menage a trois, after all.
    Champ, Jul 29, 2005
  11. Using the patented Mavis Beacon "Hunt&Peck" Technique, SP
    ITYF Elly is Elly's. ;^)
    and Ducati Race Engineer.
    Enfield 500 Curry House Racer "The Basmati Rice Burner",
    Wicked Uncle Nigel, Jul 29, 2005
  12. Mark
    Veggie Dave Guest
    At least that's what they let her think
    Veggie Dave
    UKRMHRC#2 BOTAFOF#08
    IQ 18 FILMS http://www.iq18films.com
    Extreme Racing http://www.veggie-dave.co.uk
    Toxic Shock Syndrome Gets More Girls Than Me
    Veggie Dave, Jul 29, 2005
  13. Mark
    Mark Guest
    Are you the lozzo I sent some spare rd350 gaskets to a few years back?
    Stiil got the rd?
    Regards,
    Mark, Jul 29, 2005
  14. Mark
    Mark says...
    Does that Lozzo owe you money?
    He's a fucker for that is the old Lozzo.
    Lozzo, Jul 29, 2005
  15. Mark
    Mark Guest
    Ah, guess not then. No, no money, just some spare gaskets in the post.
    Mark, Jul 29, 2005
  16. Mark
    SP Guest
    Ah, I see..it makes sense now. :eek:)
    Lesley
    CBR600FW
    BONY#54P BOB#18
    SP, Jul 29, 2005
  17. Mark
    Mark says...
    Same Lozzo, thanks for the gaskets. I think I owe you a drink though.
    I don't have the bike any more, sold it to Reynard of The Wirral. I
    went onwards and upwards, as they say.
    Lozzo, Jul 29, 2005
  18. Mark
    Mark Guest
    Morning,
    Finally got around to sorting this out. I ordered the bearings and the
    day
    they were delivered the bike suddenly stopped making the noise...
    fecking
    thing is like my kids, cries until they get to the doctors then perk
    up.
    So I left it and a low rumbling started from the back end that slowly
    got
    worse over a week so I changed the bearings when I serviced the bike.
    Now
    it's completely quiet again so I guess that must have been the problem.
    My suspicion is that the sprocket carrier bearing must have got some
    dirt
    in it as that was the one that was slightly notchy. The bearings in the
    back wheel felt perfect but I put the new ones in anyway. Hopefully
    these
    will last a bit longer than 20k.
    Regards,
    Mark, Aug 16, 2005
  19. Mark
    Mark Guest
    B*llocks, it's happening again.
    I seem to notice it more when it rains and I'm not using as
    much throttle. It feels like something is taking up play when
    initially accelerating slowly and then I get this thunk-thunk
    through the left peg if slowly cornering.
    Any ideas?
    Thanks,
    Mark, Aug 19, 2005
  20. Mark
    Sounds like some sort of lash in the drive train. Check the cush
    drive.
    Champ, Aug 19, 2005
