Well, it's Thursday...
Discussion in 'UK Motorcycles' started by Timo Geusch, Sep 7, 2006.
  1. Timo Geusch
    .... so it must be time for the weekly VFR 750 breakdown.
    In the outside lane on the M20, no less. Fortunately I made it across
    four lanes without gettting run over which was a bit of a miracle as I
    didn't have enough momentum to just coast across.
    It looks like another dead rec/rect with dead battery. CN sent the
    same company that recovered it last week (and who also did the
    repair). Oddly enough I wasn't too keen to have them have another go
    at the bike so it's now with the Honda stealer in Maidstone.
    If it turns out that it is the rec/rect then some choice words will be
    had with a few people.
    Funnily enough, I'm *not* a happy bunny this morning.
  2. Timo Geusch
    antonye Guest
    Sounds more like a related problem that's putting more
    load onto the reg/rec and causing it to fail early than
    a problem with the reg/rec itself.
    Common causes can be things like a clogged fuel filter
    that puts extra strain on the pump, so it draws more
    amps and pops the reg/rec. Or maybe a corroded
    connection in a plug/socket somewhere that is
    causing some nasty current drain as that's not
    unusual either.
    For the sake of a fiver, I'd replace the fuel filter and
    then start checking all the obvious sockets and
    plugs for signs of corrosion.
    antonye, Sep 7, 2006
  3. Timo Geusch
    Jeremy Guest
    And this is a perfect example of the character of the 750 that is so
    lacking in the 800s.
    jeremy
    '01 Triumph Sprint ST in green
    jeremy0505 at gmail.com
    Jeremy, Sep 7, 2006
  4. antonye wrote
    Been taking lesson from Ken the Troll have we? How does a blocked fuel
    pump cause extra loads on the charging circuit?
    Corroded connections are by their very nature entirely the reverse of
    what you suggest and tend to resist the passage of elecumtrickery rather
    than encourage it.
    It could be all manner of things but one thing is for sure, the area to
    look first is the charging system not the rest of the bike.
    steve auvache, Sep 7, 2006
  5. Timo Geusch
    Jeremy was seen penning the following ode to ... whatever:
    Early 800s supposedly exhibit these endearing traits as well.
  6. Timo Geusch
    antonye was seen penning the following ode to ... whatever:
    It actually was something *far* simpler.
    Spannerwanka who 'fixed' last week's breakdown had to remove the
    connector block as the block was well melted. So he stuck new spade
    connectors on, didn't bother insulating them and hey presto, one
    working VFR.
    Until said uninsulated connectors shorted out, that is.
    Fortunately both the reg/rect and the alternator survived the ordeal
    but the battery didn't. So it's time for another mega-expensive
    battery, and the dealer fitted another connector block so the shorting
    out bit hopefully won't happen again.
    I've asked the Honda dealer to put the diagnosis in writing so I can
    go and slap the other guys around the head with the piece of paper
    until the cough up the money.
    Incidentally I have a new fuel filter here, together with all the
    other filters that I'm planning to fit when I service the bike on the
    weekend.
  7. Timo Geusch
    antonye Guest
    A DC fuel pump trying to overcome a clogged fuel filter
    or crimped fuel line can easily draw 15 amps - one of
    the prime causes of regulator failures. It will draw more
    current, which causes more load on the reg/rec, which
    causes more heat, which causes more load on the
    reg/rec, etc.
    My bad wording. A corroded connection can cause
    voltage spikes, which is also a killer of reg/recs, but
    can also create a hotspot which burns out connectors
    and reg/recs as the connector melts, goes short and
    causes all sorts of mayhem.
    Fair enough, your knowledge is obviously far superior
    to mine in fixing broken down bikes.
  8. antonye wrote
    Not convinced. I would expect other issues such as the thing running
    very lean, particularly at sustained high revs, to show first.
    Not bikes no, low voltage electro-mechanical stuff though is a different
    matter.
  9. steve auvache wrote
    Then I realised who the OP was and would now like to withdraw that
    statement.
  10. Timo Geusch
    muddy cat Guest
    I think in a properly designed system the fuse would blow before the
    system had a meltdown.
    muddy cat, Sep 7, 2006
  11. Timo Geusch
    muddy cat was seen penning the following ode to ... whatever:
    We're talking about a Honda reg/rect system here...
  12. Using the patented Mavis Beacon "Hunt&Peck" Technique, muddy cat
    It's a Honda.
    HTH.
    Wicked Uncle Nigel - Podium Placed Ducati Race Engineer As featured in
    Performance Bikes
    Wicked Uncle Nigel, Sep 7, 2006
  13. Timo Geusch
    Pete Fisher Guest
    In communiqué <-consult.com>,
    Reminds me of the time some moron diagnosed a relay fault on my Alfa 75
    V6 by connecting two wires together with a scotchlock. Fitted a new
    relay but forgot to remove the scotchlock. Fortunately I was alerted to
    this by the sound of the petrol pump running if the ignition was on even
    when the engine was stopped. In the end the problem was not the relay
    anyway but a dodgy multi-pin connector in the loom.
    | Pete Fisher at Home: |
    | Voxan Roadster Moto Guzzi Mille GT/Squire RS3 Gilera Nordwest |
    Pete Fisher, Sep 7, 2006
  14. <Holds head in hands>
    The Older Gentleman, Sep 8, 2006
  15. Timo Geusch
    Indeed. I think I've almost calmed down enough by now to phone them up
    and politely ask them to cough up all the money I had to spend on
    Thursday thanks to their little fuckup. Like, the money for the repair,
    the train fare, the taxi fares...
    Timo Geusch, Sep 9, 2006
  16. the champagne, oysters and 5 star meal at a Gordon Ramsey restaurant to
    get over the sheer stress you were subjected to .... ;-)
    Paul Corfield, Sep 9, 2006
  17. Timo Geusch
    D'oh. I knew I had forgotten something.
  18. Timo Geusch
    He's losing his touch. My VFR sailed through its MOT this morning.
    platypus, Sep 9, 2006
  19. Timo Geusch
    Look, I can't be everywhere at the same time. Please make an
    appointment the next time 'round, willya?
  20. Timo Geusch
    <Holds head in hands>[/QUOTE]
    It fell off?
    Pip Luscher, Sep 10, 2006
