wet clutch
Discussion in 'Motorcycle Technical Discussion' started by pater, May 26, 2005.
  1. pater
    pater Guest
    Recently did new springs on an old Bultaco (75) clutch. The clutch
    discs in this particular application are all metal, not half metal &
    half fiber. The thing was slipping so the supplier told me to replace
    the springs & fill it with ATF as opposed to the 30w oil recommended by
    the manufacturer. This did a nice job & haven't had a problem since. My
    question here is can the same fluid be used in a 69 triumph wet clutch
    with fiber plates?? Doing one for a friend & if this will be an
    improvement in performance over the required 5-30 oil I want to set him
    up like that. Thanks in advance.
    pater, May 26, 2005
  2. pater
    les Guest
    Make sure the Triumph doesn't have the breather coming off the case by the
    primary. They changed in '69 or '70 and vented the engine thru the primary,
    as well as them sharing oil. The safest way to tell if it shares oil is to
    pull the primary cover and see if there are 3 small holes about 1/16"
    diameter drilled thru into the crankcase.
    Les
    les, May 26, 2005
  3. pater
    pater Guest
    Thanks for the input. It appears I have the situation where the oils
    the same in both cases. Oh well.
    pater, May 29, 2005
