What am I missing?
Discussion in 'UK Motorcycles' started by rufty_tufty_hoolythug, Jan 21, 2010.
  1. Windows XP machine. File and Printer Sharing turned on. Can be seen
    on a network browse. When you try to connect to the shared documents
    folder it prompts for a username and password. All settings I can see
    are set to allow everyone read only access. Any ideas?
  2. rufty_tufty_hoolythug
    Chris Dugan Guest
    I'm going to guess this is a couple of home pc's connected in a
    Workgroup?.. Called WORKGROUP, MSHOME etc.
    If so the simple answer is to create accounts on the machine hosting the
    shared folder that match the names and passwords of the ones on the
    machine trying to connect to it... that way Windows will automatically
    try to use the current user account details when challenged by any remote
    computer that you are attempting to connect. The reason you get to see a
    logon box is because that username/password combination is not recognised
    and you are being asked for a valid combination.
    e.g. if you are on your laptop and at the welcome screen you click on
    Chris to get onto the desktop then you need to setup a user account on
    the machine with the files that you want with the same username and
    password.
    Look in the control panel and go into 'users and passwords' I'm working
    from memory here 'cos I only do windows at work... not at home :)
    Chris Dugan, Jan 22, 2010
