What GPS
Discussion in 'UK Motorcycles' started by Dan L, Dec 28, 2005.
  1. Dan L
    Daz Guest
    <snip>
    Oi! There's only room for one ugly bloke in here.
    Daz, Dec 28, 2005
  2. Dan L
    Dan L Guest
    Bad form 'n all, but I have made an impulse purchase of a Navman icn320.
    Seems pretty good and basic, now I need to molish a safe way of mounting it
    to the bike.
    Dan L (Oldbloke)
    Space in shed where NSR125 used to be
    BOTAFOT #140 (KotL 2005), X-FOT#000, DIAABTCOD #26, BOMB#18 (slow), OMF#11
    Dan L, Dec 28, 2005
  3. There's a very expensive weather proof TomTom.
    HTH.
    Steve Uzochukwu, Dec 28, 2005
  4. This is what I've got.
    It has quite a few "Windows CE" annoyances, and sometimes needs a
    master reset.
    Word of warning - get a decent ally case for the PDA, from somewhere
    like PDA addons World, or prepare for the costly broken screen fix.
    BTW, both the Bluetooth and WiFi AFAIK on the 4150 are now slightly
    behind and won't necessarily work with everything.
  5. Dan L
    David Mahon Guest
    There are some Bluetooth and WiFi driver updates, together with a ROM
    update, on the HP site if you've not already installed them. I've had
    mine for a year now, and it works with everything that I've thrown at it
    so far (including WEP encryption on my WiFi) so I'm happy. I've got an
    aluminium case (Proporta) as it happens.
    If you do break the screen (or more likely, just the sensor digitizer)
    you can get a new one from these people:
    http://www.ipaqrepair.co.uk/
    Cheaper than buying a new 4150.
    For those just wanting GPS, I'd suggest the 1940 model which has
    Bluetooth but no WiFi and goes for less. But then again, if you just
    want GPS and would have absolutely no use whatsoever for a PDA I suspect
    a bespoke solution is a better bet unless you happen upon a PDA going
    really cheap.
    David Mahon, Dec 28, 2005
  6. Dan L
    muddy Guest
    I didn't get that from the 'few hundred quid' statement.
    muddy, Dec 29, 2005
  7. Dan L
    Dan L Guest
    Heh, I'm new to all this.
    Anyhoo, now have a small Sat Nav unit, hopefully will do what I need it to
    do.
    Dan L (Oldbloke)
    Dan L, Dec 29, 2005
  8. Dan L
    Greybeard Guest
    Sorry mate, we've been here before.
    Had to change my news profile, and got the wrong name in the wrong hole, so
    to speak.
    Your reputation is safe ;o)
    Greybeard
    FLHRCI -01 UK ( 95 cu-in Stg 2. Big Boy!)
    Trumpet Trophy 1200 -91, for rainy days
    nntp@foxtails[dot]co[dot]uk
    Greybeard, Dec 29, 2005
  9. Dan L
    Gyp Guest
    You can't just say you've got one, you have to tell us what it is so we
    can slag it off!
    Gyp, Dec 29, 2005
  10. Dan L
    Dan L Guest
    It is a Navman icn320.
    I shall be fully testing it later today.
    So far, my local post code map is about 5 years out of date, and my house
    number doesn't seem to exist either.
    Dan L (Oldbloke)
    Dan L, Dec 29, 2005
  11. Dan L
    David Mahon Guest
    Must be in this thread already, but RAM mounts
    (http://www.ram-mount-uk.com/) are generally the way to go.
    David Mahon, Dec 29, 2005
  12. Dan L
    Dan L Guest
    Cheers for that.
    Nothing specific to my new Sat Nav, but some interesting ideas.
    Dan L (Oldbloke)
    Dan L, Dec 29, 2005
  13. Dan L
    Ben Guest
    Neither did I. I got it from the fact that _everybody_ wants a Sat
    Nav, they just call them "GPS".
    Ben, Dec 29, 2005
  14. Dan L
    Ben Guest
    GPS tells you were you are. That's it. You then add functionality to
    that to provide satellite navigation.
    At it's most basic you have the likes of Garmin's, which are little
    more than a GPS unit unless you have appropriate software to load
    tracks into them. The only navigation they will do it "as the crow
    flies" style where you pick a point in it's basic internal map (or
    input coordinates) and it'll give you an arrow that always points in
    the direction of it. Doesn't take roads into account at all.
    "Sat Nav" systems have a database of roads, postcodes, etc built into
    them and couple this with route finding software and a map. They're
    capable of plotting a route for you on the road and then using GPS to
    figure out where you are on it.
    Basically the latter are great for use on the road when you want to
    get somewhere. They're bugger all use halfway up a mountain in the
    pissing rain. The former are perfect as a navigational aid but no
    good at telling you how to get to a little street in Milton Keynes
    unless you already know where it is.
    Ben, Dec 29, 2005
  15. Dan L
    SN Guest
    [snip]
    Er... Garmin's ...what? Garmin does a range of GPS receivers, some of which
    don't have any mapping and some with full Sat-Nav. The 2610s are full Sat-Nav
    units with Europe-wide mapping, are waterproof and have touch screens which
    are ideal for biking. They also have several route preferences - fastest,
    shortest and custom, where you tell the unit what type of road you prefer or
    would like to avoid. Garmin have at least one motorcycle tester who rides in
    Europe. The custom routes feature was based on a recommendation from him
    because he wanted interesting rides. As far as I know no other GPS
    manufacturer has anything like it & it's why I got a 2610.
    As well as giving turn by turn directions and recalculating on the fly if you
    miss a turn or have to divert.
    SN, Dec 29, 2005
  16. Dan L
    Ben Guest
    I meant the likes of the Garmin eTrex that I and another poster in the
    thread own, and hence was discussing. I'm aware they have a full
    range of devices.
    Ben, Dec 29, 2005
  17. Dan L
    SN Guest
    [snip]
    Thought you might be but it wasn't clear from the post IMO.
    SN, Dec 30, 2005
  18. Dan L
    It might be in another thread but maps are generally the way to go. If
    you can't read a map then you shouldn't be allowed on the road.
    Andy Bonwick, Jan 1, 2006
  19. Dan L
    David Mahon Guest
    Your origami must be much better than mine. I have no idea how to "mount
    it safely to the bike" using a map.
    David Mahon, Jan 1, 2006
  20. Dan L
    gomez Guest
    But it is the the easiest city in the UK to find your way around in.
    Or do you hate it for other reasons?
    gomez, Jan 2, 2006
