What have I done?
Discussion in 'UK Motorcycles' started by platypus, Jul 11, 2006.
  1. platypus
    Ged, it's big. And black.
  2. platypus
    platypus said...
    Does Mike's missus know?
    Lozzo, Jul 11, 2006
  3. platypus
    SD Guest
    Time to untie the bag of sugar, then. :)
    | ___ Salad Dodger
    |_\_____/_| ..80389../..21885.../..31432.
    '^' RBR'06 Points: 85 Miles: 413
    SD, Jul 11, 2006
  4. platypus
    I (cleverly) backed it into the drive, so it was pointing uphill. This
    evening, as I was giving it a little pre-MOT[1] fettle, I decided to put it
    on the centrestand. Could I get it off again? Could I ****. Even putting
    it in gear, revving up and rocking backwards produced nothing but noise and
    burnt-rubber smells. I eventually had to get Sarah to shove at the back
    while I strained at the front.
    [1]Tomorrow 8:30AM
  5. platypus
    It was better without the smell of burning rubber.
  6. platypus
    SD Guest
    Very sensible: this is a habit worth developing.
    Fnaar. See, shoulda gotta 15.
    <crossed bits>
    | ___ Salad Dodger
    SD, Jul 12, 2006
  7. platypus
    I have owned heavy motorcycles before, you know.
    Maybe later, when I'm bored of this one.
    I took off the not-yet-connected spotlights, and the hiway pegs I couldn't
    quite reach, pumped up the tyres (there was only 20psi front and rear, so no
    wonder it was a bit iffy on the run home), and replaced the whiskery strands
    of scorched copper wire in the main fuse with a decent bit of solid-core.
    How could it fail?
    platypus, Jul 12, 2006
  8. platypus
    SD Guest
    No you haven't - you've owned quite heavy motorcycles before.
    There is a difference.
    Indeed. Shall I take the "Big Bike Parts" Catalogue to Chimay? :)
    | ___ Salad Dodger
    SD, Jul 12, 2006
  9. platypus
    Only if you want to see Platy struggling with his Rings Of Fire.
    Pip, Jul 12, 2006
  10. platypus
    Jackie Guest
    I can see you are going to have fun in Chimay, just make sure you
    don't flip this one, or give it a little lay down on the grass. I hate
    to think how heavy it will be when you have it fully loaded with
    Chimay's finest.
    Jackie, Jul 12, 2006
  11. platypus
    zymurgy Guest
    I couldn't possibly speculate that it may have been Platy who was
    loaded with Chimay's finest |-)
    P.
    zymurgy, Jul 12, 2006
  12. platypus
    Well, it's suddenly a lot easier to cope with. I checked the front
    suspension pressure, with should have been in the 0 - 6 psi range. What it
    actually was, was 37 psi. On zero, I can comfortably flat-foot it, and it
    doesn't bump up and down so abruptly at the front.
    Passed easily.
    Jesus no. I might be tempted.
  13. platypus
    Far too heavy to flip.
  14. platypus
    SD Guest
    <slaps down a fiver>
    | ___ Salad Dodger
    SD, Jul 12, 2006
  15. platypus
    SD Guest
    Blimey - no wonder it felt odd.
    Good, cos I can't find it.
    | ___ Salad Dodger
    SD, Jul 12, 2006
