What is a moped?
Discussion in 'UK Motorcycles' started by Andrew998, Nov 24, 2005.
  1. Andrew998
    Andrew998 Guest
    A question for those that know(JP?).
    I have seen a number of definitions of what a modern moped is but haven't
    found the law wording. The direct.gov.uk site uses a definition I've seen on
    a number of official sites and is thus:
    A moped is a motorcycle that has the following features:
    a.. maximum design speed not exceeding 50 kilometres per hour (km/h)
    (about 31 miles per hour (mph)
    b.. an engine capacity no greater than 50 cc
    c.. it can be moved by pedals, if the moped was first used before 1
    September 1977
    Is this really true or is there more to it? If it is true it would suggest a
    de-restricted moped is *still* a moped because it has a "design speed not
    exceeding 50km/h" (the fact that it can now do more clearly does not affect
    what it was designed to do).
    Comments from those that know please (with references if possible) rather
    than all the usual opinions that have bugger all to do with the facts.
  2. Andrew998
    David Mahon Guest
    When I did my CBT, there were three moped riders and myself (on a 125).
    Before going out on the road, the instructor asked them how fast they
    could go - they all said 35-45 mph. The one I was paired with, on an old
    two stroke, manual, trailie style 50cc bike certainly managed 45 mph but
    it was very wheezy getting up a big hill. It didn't look like it had any
    aftermarket accessories to increase power (though it might have lost a
    bit of weight - due to bits falling off).
    David Mahon, Nov 24, 2005
  3. Andrew998
    Andrew998 Guest
    Most mopeds do more than 30mph. Frankly it is recklessly dangerous to
    venture onto the road on a bike that can only do 30mph and I can see why so
    many people de-restrict them. However, this doesn't answer the question!
  4. Andrew998
    MikeH Guest
    No, it's the thing on the end of a map 'andle.
    MikeH, Nov 24, 2005
  5. Andrew998
    MikeH Guest
    o
    Just as I hit send, as always.
    MikeH, Nov 24, 2005
  6. Andrew998
    David Mahon Guest
    Nope, sorry, it doesn't. But as the instructor was happy to do the CBT
    and give the moped CBT certificates to those on bikes that can go 45
    mph, it does suggest that indeed there is "more to it".
  7. Andrew998
    Andrew998 Guest
    Unfortunately I think the 'more to it' in this case is simply common sense
    rather than any issue of law.
  8. Andrew998
    Ben Guest
    It suggests to me that the instructor was bending the rules a tad.
    Ben, Nov 24, 2005
  9. It's probably rubbish, but I always assumed a moped had to have the
    engine as part of its unsprung weight. Or maybe that's just a scooter.
    Or maybe its neither. Wibble.
    Oops. Sorry!
    Lemmiwinks, The Gerbil King, Nov 24, 2005
  10. Andrew998
    It's common, indeed normal, among scooters, yes, but hardly a defining
    factor. Most 'real' mopeds have frame-mounted engines.
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Nov 24, 2005
  11. In uk.rec.motorcycles, Andrew998 amazed us all with this pearl of
    wisdom:
    It's like a fat burd, innit.
    Whinging Courier, Nov 24, 2005
  12. Andrew998
    Andrew998 Guest
    I think I've found it and it is indeed the definition I've given above.
    ref:
    The Road Vehicles (Construction and Use) Regulations 1986 and The Road
    Vehicles Lighting Regulations 1989 (C&U and RVLR) Section 3.1.
    Moped - a motorcycle weighing less than 250kg and with a maximum design
    speed not greater than 30mph. If the engine is an internal combustion engine
    its capacity must not exceed 50cm3. Propelling pedals are not required.
    I wonder if this would allow for a defence if a 16 year old was prosecuted
    for riding a motorbike.
  13. What makes a scooter a scooter then? Just the step-through frame?
  14. Andrew998
    Well I don't think there's a legal definition, but I guess the running
    board allowing your feet to sit together is pretty much the universal
    common denominator.
    That, and the fact that they're all shite, of course.
    _______
    Ace, Nov 24, 2005
  15. What I find confusing is that this:-
    http://www.uk.gilera.com/_vti_g2_ve...ountry=GB&language=EN&mod=VGP-DNA&vers=DNAKAT
    Is referred to by Gilera as a scooter rather than a bike, but the only
    things I can see that would make it not a bike is the fact that the
    engine is unsprung, and they're usually ridden by 16yo chavs.
    Aye, true enough.
  16. If a Honda C50 counts, then yes, otherwise no. A mate had a C50 at
    school and we used to ride it round the gravel carpark of the local
    leisure centre, and build ramps and stuff. Great laugh, it was.
  17. That's about it, yes. The good old sports 'peds (Fizzies[1], AP50s[2],
    et al) could do 50mph or so, but they were actually equipped with pedals
    which locked into postion as footrests.
    After 1 September 1977, the rstricted moped law came into force and has
    been effectively unchanged since.
    This means that if you have a pre-1/9/77 bike that has fixed footrests
    (like a Suzuki A50), it's classified as a motorcycle, not a moped.
    If you take the pedals off the pre-1/9/77 bike and replace them with
    footpegs, it becomes a motorcycle, although in actual fact, I can't see
    anybody prosecuting!
    Tuning a post-1/9/77 moped to do more than about 35mph is illegal - it
    turns it into a motorcycle, although - again - I can't see many people
    getting nicked. It's like tuned 125s.
    [1] Purple ones were faster
    [2] Red, it was......
    The Older Gentleman, Nov 24, 2005
  18. Andrew998
    Andrew998 Guest
    message
    Snip history
    I know all the history thanks.
    But this is my point. The way the reg is worded seems to suggest that it
    isn't illegal to tune them to do more than 30mph. The wording is 'with a
    maximum design speed not greater than 30mph.'. Even if it is tuned to do
    more the fact remains that its design speed is 30mph. This is poorly worded
    legislation and our legsslative systems works on what the law says rather
    than what was intended.
  19. Andrew998
    No, it's not that it's poorly worded, it's your interpretation.
    Nothing about it says 'design speed at manufacture' or similar.
    Clearly if you've tuned it, it's with a design of more than 30kph in
    mind, so the 'design speed' is no longer what it was.
    _______
    Ace, Nov 24, 2005
  20. *Ding*
    The Older Gentleman, Nov 25, 2005
