what'll make a 2 stroke run and sound crap
Discussion in 'Motorcycle Technical Discussion' started by Charlie, Nov 13, 2003.
  1. Charlie
    Charlie Guest
    guys my wr200 started playing up a bit towards the end of my last ride.
    Louder idle, with very noticeable 2 stroke cracking noise (not a *bad*
    sort of cracking noise, just a sort of unmuffled 'ding'. sounds kinda
    like a lot of worn out kids 2 strokes)
    less bottom end power, more noticeable midrange hit, and doesn't rev out
    as well. sounds louder and a bit crappier most of the time.
    Things on my to do list are: check exhaust packing, check powervalve
    setting. (electric whizz bang powervalve on these things)
    Any other thoughts on what'd cause my symptoms? I can't see any cracks
    in the exhaust or anything like that.
    Charlie
  2. 2 strokes all sound crap
    Brett Danvers, Nov 13, 2003
  3. Charlie
    Derek Guest
    Pinging? Try pulp if you dont already.
    Derek, Nov 13, 2003
  4. Charlie
    Charlie Guest
    right, easily diagnosed. No need to panic folks. Powervalve cable has
    snapped.
    Charlie
  5. Charlie
    Fred Kroft Guest
    how old is it ?. does it get regularly serviced ?. do you ride it hard
    or are you putting it around ?. it's a single isn't it ?. do you premix
    fuel or is it self mixing ?. is it running or hotter/colder than usual ?.
    i would be replacing spark plug. the condition of it will tell you
    quite a lot as well.
    i've never heard of this.. so my knowledge on modern 2's are a bit out.
    reed value ?.
    2's are simple. assuming that the block, piston, crack case isn't
    leaking, you are looking at plugs, timing, fueled mixture, failed
    carberettor, dirty fuel, blocked fuel filter..... the 2's i've
    seen normally have a spring loaded header fitting on the engine
    block. if it's louder, maybe you could check that the header is
    firmly attached ?..
    having failed all that, get a mechanic to have a look.
    -f
    Fred Kroft, Nov 13, 2003
  6. Charlie
    CrazyCam Guest
    **** you, and the camel you rode in on.... :)
    regards,
    CrazyCam
    CrazyCam, Nov 13, 2003
  7. Charlie
    FuTAnT Guest
    Better split the cases anyway.
    Cam
    FuTAnT, Nov 13, 2003
  8. Charlie
    Fwoar Guest
    I was gonna say - sounds like the powervalve is stuck
    Daron
    Fwoar, Nov 13, 2003
  9. Charlie
    Jules Guest
    He's got camel in ****-you-quantities...
    Jules, Nov 13, 2003
  10. Charlie
    Woodsrider Guest
    There you have it....Might want to re-pack your silencer while you're at
    it....
    Woodsrider, Nov 13, 2003
  11. Charlie
    kiwipete Guest
    **holding back**
    kiwipete
    kiwipete, Nov 14, 2003
  12. Charlie
    Damien Guest
    "kiwipete" < (cut the CRAP to reply) 'X-No-archive:
    yes> wrote in message
    garn Pete, tell us what you really think - you have every other time!
    Damien (marvelling at kiwipete's incredible display of self-restraint)
    GPX250 (stolen) -> CBR600
    Damien, Nov 15, 2003
  13. Charlie
    kiwipete Guest
    Nah..
    kiwipete
    kiwipete, Nov 18, 2003
