What's wrong with my motorcycle?
Discussion in 'UK Motorcycles' started by Paul Carmichael, Oct 23, 2010.
  1. Ok, so I haven't started it since April. Come to start it just now, and it
    will only run on choke. Touch the throttle and it sounds like the big ends
    are about to explode. Finally get it to rev, but it won't idle and at low
    revs it sounds like there's no oil. I think it's running on 3, so about to
    look at plugs etc. Do I have a dead motorcycle?
  2. Paul Carmichael
    crn Guest
    Shit in the carbs
    crn, Oct 23, 2010
  3. Paul Carmichael
    rick Guest
    Moisture in the plug caps?
    rick, Oct 23, 2010
  4. rick escribió:
    I've started removing bits of plastic, and so far no sign of anything
    resembling spark plugs. Already drawn blood.
    If I can get it running, I'll get it tested (MOT equiv) next week and
    offload it to some unsuspecting dago.
    Then I'll buy a scooter.
  5. Gummed carbs, unless yours is FI which, IIRC, it isn't.
    Ultrasound cleaning will sort them. Don't bother faffing with magic
    fluids and cleaners and stuff.
    The Older Gentleman, Oct 23, 2010
  6. The Older Gentleman escribió:
    Oh dear. I don't even know where the carbs are. In the absence of ultrasound
    gadgets (I know a bloke who's got one, but he's a urologist), I presume it's
    a case of finding the carbs and ripping them to bits and poking things with
    bits of wire?
  7. Paul Carmichael
    well, you well need to look elsewhere than the cards.
    darsy, Oct 23, 2010
  8. Paul Carmichael
    don't bother - I already said.
    (though even I, a mechanical dunderhead, know where carbs are in
    relation to other bits of engines[1])
    [1]the complicated wibbly looking bits at the top of the cylinders,
    innit.
    darsy, Oct 23, 2010
  9. darsy escribió:
    I was just sat here scratching my head, looking for the funny in "cards",
    assuming I'd been whooshed once again.
    I have a Haynes manual. I may be some time.
  10. Paul Carmichael
    Domènec Guest
    You have a dead mueble de patio.
    Domènec, Oct 23, 2010
  11. Paul Carmichael
    crn Guest
    If you have run it for a few minutes this should have filled all of the
    carbs with fuel. With any luck this will slowly disolve any gum so it
    might be a good idea to just leave it overnight and see if it gets
    better in the morning.
    If this fails GAMI rather than faffing with things that you dont understand.
    crn, Oct 23, 2010
  12. Paul Carmichael
    Domènec Guest
    Xmax 250. Trust me.
    Stay away from Korean and Chinese stuff.
  13. escribió:
    Too late. It's already in bits.
  14. No, not if they're badly gunged. I mean, yeah, you can strip them and
    soak them and poke at jets with bits of copper wire if you want, but I
    doubt it'll run properly ever afterwards.
    Trust me(tm): ultrasonic cleaning really is the only sure-fire way to
    go.
  15. It won't.
    It won't
    True.
  16. Paul Carmichael
    crn Guest
    Or any big-name superscoot with at least 250cc.
    My 250 Majesty is a tad slow on the motorway so maybe a 400 if you do
    long trips. A nice big windscreen is nice to have for weather protection
    and less neck muscle pain at speed.
    Unless you want a cheap disposable shopping trolley that you are happy
    to throw away if it goes titzup.
    crn, Oct 23, 2010
  17. Paul Carmichael
    Salad Dodger Guest
    Be aware, plugs out is a "radiator off" job with a Blackbird.
    Salad Dodger, Oct 23, 2010
  18. Paul Carmichael
    Mike Buckley Guest
    Mate of mine with a B6 in a similar state had the carbs cleaned by the
    local garage (for about the 4th time as he's MOT'd it every year then
    not used it), it still ran fairly rough after the last attempt but he
    was told that the new petrol would eventually dissolve the remaining
    crud. I laughed at the time but without any further work and only a few
    hundred miles it has actually improved a hell of a lot, and only very
    rarely can he even tell there was a problem.
    Mike Buckley, Oct 23, 2010
  19. Salad Dodger escribió:
    Might be with the FI models, but I have the plugs out now, having removed
    the tank and fairing sides. Radiator untouched.
  20. Paul Carmichael
    Domènec Guest
    According to the guy who breaks in bikes at the Yamaha factory (from
    scooters to FJR's) Xmax wins at handling better. Wot a pro says :)
    And beware of Honda SH300 shimmies.
    Weather protection in Malaga? Say air conditioning :)
    Did 600 and 800 kms in-a-day trips on the Xmax, no pain in the neck, me
    being at 6 feet (and half inch) tall.
