What's wrong with my motorcycle?
Discussion in 'UK Motorcycles' started by Paul Carmichael, Oct 23, 2010.
  1. The Older Gentleman escribió:
    Not an option where I live.
    I have the plugs out, and apart from one looking a bit black, they seem ok,
    unfortunately. It would have been nice to have something to blame it on.
    Perhaps I'll stick some new ones in anyway while the bike's in bits.
    http://paulc.es/tmp/plugs1.jpg
    I wonder if there's a carb renovation firm around here...
  2. Paul Carmichael
    Erm, a view into the end from an angle would be rather more use tha a
    view of the sides & threads.
    This view does imply that the spark gaps are a bit big for most bikes,
    mind, unless they're tiny plugs.
    Pip Luscher, Oct 23, 2010
  3. Pip Luscher escribió:
    The one that's a bit black is black inside as well.
    Not much better, but http://paulc.es/tmp/plugs2.jpg
    They are tiny plugs, and the gaps are ok.
    Next question: Can I test the plugs by flashing 12v across one of the coils?
    Or will that bugger them?
  4. Mark Olson escribió:
    I know what you mean. Just that the bike is currently scattered all around
    the patio and I was hoping to put it back together just in case it rains
    (highly unlikely) or (more likely) I forget how it all goes back together. I
    think the (one and only) bike shop is shut from Sat lunchtime onwards.
    Ah well, I'll just shovel all the bits into a box until Monday.
  5. Might work. I was thinking that after six months in baking Spanish heat,
    that crap will be well caked on.
    Worth a try, though.
    How many jets do you think he can lose?
    The Older Gentleman, Oct 23, 2010
  6. Mark Olson escribió:
    Just been and ordered some new ones. But not those fancy platinum ones,
    'cause they're like 15/16 euros each, whereas the boggo ones are about 10.
    Won't get them until Mon afternoon, so I guess I'll spend that time ruining
    the carbs.
  7. The Older Gentleman escribió:
    Will have a look on Monday. Or of course, I could just take the carbs up to
    the local bike mechanic and trust him to clean them.
    It always runs rough after the summer layoff, but has normally sorted itself
    out once warmed up for the first time. Mind you, it's has always run rough
    at tickover when cold, and knocks and rattles to buggery ever since I've had
    the bike, which is 10 years.
    We've got no carpets.
  8. Paul Carmichael
    crn Guest
    Is the right answer.
    crn, Oct 23, 2010
  9. Mark Olson escribió:
    Keen to get it on the road at the mo, so will manage with the plastic ones
    for now, but thanks for the advice. As it turns out, getting the plugs out
    of mine isn't such a task as I've made it. The manual says something like
    "One way to get at the plugs is strip all the fairings off" and then details
    how this is done, followed by "but the easiest way is to remove the tank",
    which took me all of 5 minutes, having already reduced the bike to a million
    bits of plastic and bolts.
  10. Paul Carmichael
    Yeah, I reckon. Certainly the electrode edges are quite sharp, so not
    eroded through age or whatever.
    The gaps just looked disproportionately big.
  11. Paul Carmichael
    eamo Guest
    Greetings,
    it would appear that this may, at this stage, be of the "trying to
    put the shit back in the horse" category of info, what with you having
    disassembled your steed, but.....
    and notwithstanding the various suggestions already made, on
    reasonable basis re carbs etc, i will say this.......
    i have a FI (ergo no carbs :p) 03 bird wot i have put 55k on in 365
    day use and your precise symptoms happen to mine without fail when
    ambient temp is below ~8 C.
    So
    1) what was ambient/engine temp at time of your endeavour? (i know u
    reside at latitudes removed from me, but there exist seasons there
    too, im sure)
    2) did u persist in coaxing it to run, even on 3, untill it had
    nearly attained normal operating temp? and did terrifying lunching
    noises/lumpy running persist at this point?
    The terrifying rattle/rumble of death noise occurs wit my cold oil/
    engine and part worn clutch (but by no means near end of life), which
    can even stall engine, when its trying to do its FI/ECU controlled
    warm up. solution: hold clutch in till it hits 40 c. - sweet hum of
    contentment. blackbird clutches rattle like **** when cold.
    The fuelling on FI one is controlled during warm up by wax items wot
    remain solid below x temp, and theorectically melt and normal throttle
    body control resumes. i cant recall wot mr honda calls this system. In
    any event its not great. I, with MK I right hand, I hold throttle for
    30 sec to ensure 1000 rpm is maintained, then continue to hold clutch
    in (as above) till magic number shows on temp gauge. Runs like swiss
    (japanese) watch thereafter.
    Mine has been serviced by book. has iridium plugs replaced as per
    manual etc. I feel less than inclined to 'go at' wax thingies, clutch
    holding is easier.
    Mine may indeed have some problem, but not at normal temperatures.
    Thus i feel my approach is simpler and lower cost.
    Yer black plug may be but a loose plug lead or a vibed out plug [1]
    [1] many's the man that is less than inclined to torque plugs to full
    torque, due to thread strippage terrors, in face of minor corrosion.
    Blackbird magic vibes (3.2-4k rpm, due to cam chain tensioner
    shittieness, can vibe out a 'just about' tightened plug [2]
    [2] I have learned
    eamo, Oct 24, 2010
  12. Paul Carmichael
    malc Guest
    But we've seen your film!
    Malc
    Rusted and ropy.
    Dog-eared old copy.
    Vintage and classic,
    or just plain Jurassic:
    all words to describe me.
    malc, Oct 24, 2010
  13. eamo escribió:
    Seasons we have. Only 2 though. It would have been around 15C probably. I've
    not seen it below that yet this year.
    I did and they did.
    Heh. Clutch doesn't work well. If I leave the bike stood for more than a few
    days, it sticks solid.
    But I couldn't pursuade it to run on 4.
    New plugs and cleaned carbs will be the order of Monday.
    Paul Carmichael, Oct 24, 2010
  14. Paul Carmichael escribió:
    Except not being Popeye means I can't get the bastard carbs off!
  15. Paul Carmichael
    Domènec Guest
    <adds malc to red nosed bastards list>
    Domènec, Oct 24, 2010
  16. Paul Carmichael
    eamo Guest
    ah. i see.
    ah. oh dearie me, there methinks, the behaviour of yours diverges from
    mine. As you were, may the fettling coninue...
    Ewww. An issue.
    ah. yes. not good then.
    In conclusion; Yer bike is indeed dying.
    Bon Chance.
    eamo, Oct 24, 2010
  17. Paul Carmichael
    eamo Guest
    *proffers tinned spinach*
    eamo, Oct 24, 2010
  18. Grimly Curmudgeon escribió:
    It was said to contain a good dose of iron. I heard recently that it
    contains as much iron as any other green grub.
    Last night we had spinach with roast pork, boiled spuds and carrots. I cook
    the spinach in a wok with butter. Lovely. If it's not overcooked, it doesn't
    stick to your teeth.
  19. Paul Carmichael
    Guest Guest
    Ok, so I haven't started it since April. Come to start it just now, and it
    Shit in the carbs
    I wouldn't do that. If you end up taking to a mechanic he won't touch it
    until you hose it all off!
    Guest, Oct 25, 2010
  20. escribió:
    Done that. Paid the mechanic to clean the carbs. He says they were well
    gummed up. Put them back on, along with new plugs.
    Worse than ever. Hunting like hell. Will just about run on full choke for a
    few minutes, then dies. Leave it for a while and it starts and sounds fine.
    Then starts chugging and the gearbox threatens to explode as the engine
    grinds to a halt.
    So, tank back off, I suppose, and check hoses etc? Or could it be something
    to do with the vacuum part of the system?
    Paul Carmichael, Oct 26, 2010
