What's wrong with my motorcycle?
Discussion in 'UK Motorcycles' started by Paul Carmichael, Oct 23, 2010.
  1. Paul Carmichael
    TOG@Toil Guest
    No. Get a better mechanic, and one who's got an ultrasonic cleaner,
    and get him to do the job *properly*.
    TOG@Toil, Oct 26, 2010
    #41
  2. Paul Carmichael
    crn Guest
    Agreed, but it is clearly running weak unless on choke so maybe check
    for air leaks twixt carbs and inlet. I once spent an entertaining
    day looking for a similar fault when I put a carb back on with an
    O ring hiding on the floor.
    crn, Oct 26, 2010
    #42
  3. Paul Carmichael
    Could be lots of things really, but I'd start by checking nothing's
    living in the airbox (or left a nest there), & of course try running it
    with the petrol cap open just in case.
    Krusty, Oct 26, 2010
    #43
  4. Paul Carmichael
    TOG@Toil Guest
    Shouldn't the mechanic have done that when he replaced the carbs after
    cleaning them?
    #44
  5. TOG@Toil escribió:
    I really doubt there is one in this part of the world. But I will be taking
    the bike up to the mechanic now that I've got it running after cutting the
    split end off the vacuum pipe, as it still ticks over on 3.
    I think the vacuum pipe was the original problem, so I think I've wasted 80
    euros and lots of time. Silly me.
    Paul Carmichael, Oct 26, 2010
    #45
  6. wessie escribió:
    It's only six months old. Do you think it may have gone off?
    #46
  7. Paul Carmichael
    TOG@Toil Guest
    In Spanish summer heat? Quite possible.
    #47
  8. Because one carb is still gunged to hell and breakfast?
    The Older Gentleman, Oct 26, 2010
    #48
  9. Mark Olson escribió:
    When I got them back they stunk summat horrible of some solvent or other.
    #49
  10. What he said.
    #50
  11. The Older Gentleman escribió:
    Indeed. Which is why I took them to a bloke wot has an airline, as I don't.
    I might add here that I was a motor mechanic for quite a few years and have
    stripped and cleaned hundreds of carbs. Although they were things like SUs
    and Zeniths etc.
    Wanna talk about submarine instruments, leaded windows, fitted wardrobes,
    porting console games or ant-virus software while we're here? And don't call
    me Jack.
    Paul Carmichael, Oct 27, 2010
    #51
  12. Paul Carmichael
    TOG@Toil Guest
    Things have changed. All the additives and stuff in modern unleaded
    fuel present a far worse problem than you probably had to deal with,
    back in the day. Also, modern bike carbs are horrendously complex
    things with more galleries and passages than you'll find in the Tate.
    TOG@Toil, Oct 27, 2010
    #52
  13. Paul Carmichael
    Ah, that's what it is: the carb's closed for Elf 'n' Safety reasons.
    CT, Oct 27, 2010
    #53
  14. Paul Carmichael
    oxymoron alert.
    darsy, Oct 27, 2010
    #54
  15. Paul Carmichael
    TOG@Toil Guest
    Heh. Yes, it did strike me as such as I was typing it.
    #55
  16. Paul Carmichael
    davethedave Guest
    Ok lets do submarine instruments then.
    davethedave, Oct 27, 2010
    #56
  17. Paul Carmichael
    TOG@Toil Guest
    Fair enough. A carb is a fairly simple device. "Delicate", then.
    #57
  18. Using the patented Mavis Beacon "Hunt&Peck" Technique, davethedave
    Paging Champ! Champ to the conning-tower please.
    Wicked Uncle Nigel, Oct 27, 2010
    #58
  19. TOG@Toil escribió:
    I just rode the bike up to the workshop that cleaned the carbs. He wrote
    "carburation" (well, in dago, obviously) on the job card. I wonder if I'm
    going to get charged twice for the same thing.
    Probably.
    #59
  20. Paul Carmichael
    wasn't it technically a saabmarine?
    darsy, Oct 27, 2010
    #60
