Wheelie School
Discussion in 'UK Motorcycles' started by Donald, Jan 30, 2007.
  1. Donald
    Veggie Dave Guest
    The only difference between a slow and a fast wheelie is that the slower
    you go the smoother and more relaxed you have to be. The actual
    technique itself is exactly the same - you just have a dramatically
    reduced room for error.
    Veggie Dave
    UKRMHRC#2 BOTAFOF#08
    IQ 18 FILMS http://www.iq18films.com
    POST PRODUCTION http://www.iq18films.co.uk
    Toxic Shock Syndrome Gets More Girls Than Me
    Veggie Dave, Feb 1, 2007
    #41
  2. Donald
    Ah, I was assuming that B12s had carbs.
    Pip Luscher, Feb 1, 2007
    #42
  3. Donald
    Veggie Dave Guest
    They do. They're just old oil-cooled GSXR1100s with smaller carbs (2mm
    smaller IIRC), header pipes, lower profile cams and diaphragm clutches.
    Veggie Dave
    #43
  4. Donald
    Oh, ta.
    So my point was valid for B12s, which were uppermost in my mind when I
    originally posted, though for some reason I didn't extend the logic to
    FI bikes.
    #44
  5. Donald
    Eiron Guest
    Diaphragm clutches? You are supposed to be listing differences,
    not similarities, between Bandits and oil-cooled gixxers.
    Eiron, Feb 1, 2007
    #45
  6. Donald
    Veggie Dave Guest
    Funny, my oil-cooled GSXR11 definitely isn't a diaphragm clutch. Now,
    the GSXF11 (Powerscreen) also has a diaphragm clutch.
    Veggie Dave
    #46
  7. Donald
    Veggie Dave Guest
    Further investigation shows that the last few oil-cooled models were
    diaphragm clutches ('91 and '92 from what I can find) while the earlier
    ones aren't.
    Veggie Dave
    #47
  8. Donald
    Eiron Guest
    '89 to '92 (K-N) were diaphragm, '86 to '88 (G-J) had coil spring clutches.
    Eiron, Feb 1, 2007
    #48
  9. Donald
    Veggie Dave Guest
    How odd. I have an '89 GSXR11 and that's a spring clutch. I wonder what
    model it is then.
    Veggie Dave
    #49
  10. Donald
    Eiron Guest
    Eiron, Feb 1, 2007
    #50
  11. Donald
    Every fucking thing. Read the thread again and THINK.
    #51
  12. Donald
    This I have noticed. You do seem to have got hung up on some pretty
    trivial point for no other obvious reason.
    #52
  13. Donald
    Not my intention, rather, it seemed to be yours to argue the **** out
    of some very trivial point. I don't buy that "anyone who has ever met
    me..." bollocks from your other post either.
    Oh do stop acting the arsehole.
    Right, here goes:
    Your problem seems to be with the revs, not the fact that an engine
    behaves slightly differently depending on whether it's burning fuel or
    not on the overrun. Is that so? If not, then what exactly is your
    problem?
    Assuming that its' the revs thing, I'll continue.
    Are you saying that the extra drive that the slight drive an engine
    might get from a closed throttle will vanish completely at higher
    revs?
    I think the effect *might* be less noticeable at higher revs, but I
    don't think it would disappear entirely. If you want to claim that as
    a climb-down then fill yer boots.
    The reason I cited the 2000rpm figure (it's actuallt the spec. for
    that bike) was simply because I had a clear correlation between the FI
    cutting in and the engine drive increasing, not any partiular reason
    for it to be a low-rev phenomenon.
    I originally posted my comment because I gather that a bike in a
    stable wheele will be quite sensitive to any slight changes in drive,
    so I figured that under those circumstances, the slight difference
    *could* be rather more significant.
    Happy now?
    If I've missed your point or you still "can't understand", which I
    really don't believe, then feel free to call me a troll, 'cos I really
    CBA to continue this.
    #53
  14. Donald
    Molly Guest
    I can relate to this. The gap seems huge especially when they sail past you.
    www.MollyG.net
    ZX10R; GS500E, GSX600F (Feisty Racing Colours
    http://www.sportsbike.org/pink.jpg ).
    GHPOTHUF#27 TGF, UKRMFBC#7, BOTAFOF#11, YTC#9, GYASB#1. SbS#23.
    DFWAG#2, DS#2, DIAABTCOD#20. remove "thisbit" in the reply
    http://www.Sportsbike.org
    Molly, Feb 1, 2007
    #54
  15. Donald
    Molly Guest
    On less powerful bikes I've used the back brake method to wheelie, if you
    know what I mean. What's your views on using the back brake to help loft
    one?
    Molly, Feb 1, 2007
    #55
  16. Donald
    Gyp Guest
    OK, it's gone, but that's not really important; businesses come and go.
    Cutting through the ranting, it would appear that the you did not agree
    with the approach that was being taught. And as you're not complaining
    about the others, it would appear that you are happier with their
    approach
    All I did was describe my rather enjoyable day out and the approach to
    wheelieing that was taken on that day - low speed balance point wheelies
    I don't know if what was being taught was the right technique, or if it
    led to unsafe wheelies on the roads.
    Whatever, I couldn't wheelie before, and I can't wheelie now, but for an
    experience day, I wholly enjoyed it.
    Gyp, Feb 1, 2007
    #56
  17. Donald
    Veggie Dave Guest
    It's incredibly hard to get it right and takes a lot of practise and
    co-ordination. I've only had to use it on a restricted 50 [1] which
    needed all the help it could get to loft. A lot of guys use it for
    standstill launches but I've found my CBR doesn't need the extra help
    the rear brake bounce gives ... thankfully.
    It's a proper old school technique from the days when bikes were heavy
    and had, relatively speaking, little power.
    Jimmy Fireblade teaches this technique at his school.
    [1] In the end it was easier to launch it from a standstill than try and
    bounce it when the bike was moving. Sadly I got no footage of me on the
    bike when I got to the point where I was really happy riding it, but
    this was shot a couple of days after I got it:
    http://vids.myspace.com/index.cfm?fuseaction=vids.individual&videoid=1521
    111710
    Veggie Dave
    #57
  18. Donald
    Tim Guest
    Makes note in diary to reserve (more) hospital visiting time.
    Tim, Feb 1, 2007
    #58
  19. Donald
    Veggie Dave Guest
    I've got to get permission to use that song on the next DVD.
    Veggie Dave
    #59
  20. Donald
    Pete Fisher Guest
    How about one where the ignition is cut when the throttle is wide or at
    least well open, would pumping losses have any bearing?
    | Pete Fisher at Home: |
    Pete Fisher, Feb 1, 2007
    #60
