Where would I get a used BMW R-series engine?
Discussion in 'UK Motorcycles' started by JB, Mar 18, 2008.
  1. JB
    <boggle>
    You have to change the valves when you service it?
    Champ
    ZX10R | GPz750turbo | GSX-R 600 racer
    My advice as your attorney is to buy a motorcycle
    To email me, neal at my domain should work.
    Champ, Mar 20, 2008
  2. JB
    these 1920s-era engines aren't all that, are they?
    darsy, Mar 20, 2008
  3. JB
    I can't recall the interval but it's something like 60,000 miles. No
    different to engines needing a cam belt or the like. Remember it's
    incredibly easy to do on an Airhead. 90 mins a side.
    Hog, Mar 20, 2008
  4. JB
    platypus, Mar 20, 2008
  5. JB
    I'd say it was significantly different.
    <shrug> Still 3 hours, plus a couple of head gaskets etc.
    Not impressed.
    Champ
    Champ, Mar 20, 2008
  6. JB
    SD Guest
    I'd agree. I've changed cambelts on the Wing. I wouldn't want to
    change the valves.
    Me either.
    Owt that requires "head-off" mainteneance short of 100k miles is
    lamentable.
    If UJMs needed that level of owner interference there'd be a bloody
    outcry.
    SD, Mar 20, 2008
  7. JB
    You have *no* idea how fucking akward some cage cam belts are to change,
    airhead valves are a doddle by comparison.
    Perhaps a good comparison is the new VFR v-tec valve timing service. Over
    £500 and a day of work. That's every 12 or 24k miles IIRC.
    Hog, Mar 20, 2008
  8. JB
    Gyp Guest
    Good point; I'll not fit variable valve timing to the Boxer when I do
    the valves, then.
    Gyp, Mar 20, 2008
  9. JB
    SD Guest
    What the flying **** have cage cambelts got to do with this?
    Replacing engine parts at that regularity is not rendered acceptable
    just because it's "easy".
    SD, Mar 20, 2008
  10. JB
    You deliberately snipped my reference to Honda V-Tec VFR's, perhaps more
    applicable.
    Hog, Mar 20, 2008
  11. JB
    And you've deliberately picked the single most expensive and
    complicated Japanese bike to service.
    Champ
    Champ, Mar 20, 2008
  12. JB
    Well at least the Beemers of the day were likely to get to 60,000 miles. A
    whole host of jap stuff in the mid 70's to 80's never did.
    Anyway like I said, it isn't a big job. What goes on behind closed doors in
    a dealers workshop is no business of a respectful owner. Didn't even cost
    very much.
    Hog, Mar 20, 2008
  13. JB
    Mark Olson Guest
    I suppose it is a matter of degree. I would find it hard to defend
    such an inflexible rule.
    If the servicing is infrequent, relatively easy, quick, and inexpensive,
    it doesn't matter to me if it's the crankshaft that needs replacing.
    Is it true that changing a pair of cambelts every 6 000 or 12 000 miles
    on a Ducati is acceptable, but changing 4 valves every 60 000 miles on
    a BMW airhead is not? Not to mention the Duc needs shimming, the belt
    tension is rather finicky, and the BMW has an easy screw-and-locknut
    adjustment.
    Mark Olson, Mar 20, 2008
  14. JB
    I was intentionally not mentioning Ducati belts, as I have one, but indeed
    the BMW valve replacement compares remarkably well to the belt driven desmo
    head service overhead. Damn site easier to do yourself too.
    Hog, Mar 20, 2008
  15. JB
    The UJMs of the 70s and 80s would all have got to 60k miles assuming
    they weren't written off first. Every couple of years one of the bike
    mags would strip an air-cooled jap four and wonder at the lack of wear
    in it.
    I suppose that's one thing for BMWs tho - they generally get ridden so
    slowly that they don't get crashed.
    Champ
    Champ, Mar 20, 2008
  16. JB
    If you have to wheel on Ducati servicing requirements to defend BMW,
    then your argument really is fucked!
    Champ
    Champ, Mar 20, 2008
  17. JB
    Look I said i was trying to avoid it ;o)
    Hog, Mar 20, 2008
  18. JB
    Bollocks.
    Honda CJ250
    Honda CB250G5
    <swims away>
    Hog, Mar 20, 2008
  19. JB
    Those are not UJMs, in my understanding of the term. And comparing a
    250 with a 800 hardly seems fair.
    Champ
    Champ, Mar 20, 2008
  20. JB
    SD Guest
    No. Neither are acceptable. Cambelts on properly engineered motors are
    100,000 mile service items. Valves should last the lifetime of the
    engine.
    SD, Mar 20, 2008
