Where would I get a used BMW R-series engine?
Discussion in 'UK Motorcycles' started by JB, Mar 18, 2008.
  1. JB
    Pete Fisher Guest
    These days perhaps. I think have related the tale of my vintage racing
    mate taking his R75/6 flat out through the bottom of Barregarrow.
    As to belt changes and the like, I can't see a problem if they are as
    easy to do as on the Nordwest (DOHC but screw and locknut adjustment).
    Quite glad the Tart has a chain though, and I have related the
    reasonable cost of having the clearances and FI adjusted on that
    already.
    | Pete Fisher at Home: |
    Pete Fisher, Mar 20, 2008
    #41
  2. JB
    You are a sick sick man ;o)
    Hog, Mar 20, 2008
    #42
  3. Using the patented Mavis Beacon "Hunt&Peck" Technique, SD
    Platy's did.
    Wicked Uncle Nigel, Mar 20, 2008
    #43
  4. JB
    Planned obsolescence
    Hog, Mar 20, 2008
    #44
  5. JB
    O'Contraire. They lasted the lifetime of the electrics. I slung on a
    decent used barrel, piston and head, then found I had to replace the loom.
    platypus, Mar 20, 2008
    #45
  6. Using the patented Mavis Beacon "Hunt&Peck" Technique, platypus
    Loom? Service item onna Beemer, mate.
    #46
  7. JB
    Couple hours. Apart from a little matter of mixing up the headlight and
    starter relays...
    #47
  8. JB
    Nor in mine.
    Well, yes. A 250 will be working harder throughout its life, cc for
    cc, than an 800.
    Pip Luscher, Mar 20, 2008
    #48
  9. Belt changing, at least on the SOHC bikes, is a very simple job. Maybe
    half an hour for both belts.
    Shimming... yes, that's a bit more time consuming, but mine has only
    needed shimming twice in 30k miles.
    I dunno about the DOHC bikes, mind.
    The Older Gentleman, Mar 20, 2008
    #49
  10. Indeed. Cambelts, when they first appeared on cooking production lumps,
    were only driving the cam and lasted 100k easily. Valve technology that
    lasts the life of the engine has been around for decades and there is no
    reason why BMWs should have been cursed with such crap metallurgy.
    GS850x2 XS650 SE6a
    "A scone and tea at half past three
    Makes the day a little brighter
    Keep your cakes and fancy tarts
    And stick them up your shiter."
    Grimly Curmudgeon, Mar 20, 2008
    #50
  11. JB
    Now you see why I'm less than impressed by the supposed
    bullet-proofness of BMW engines. Those air-heads are meant to be the
    most reliable ones BMW have ever built too, so what does that say about
    the later built shite they turn out.
    Lozzo
    Suzuki SV650S K5
    Honda CBR600 FW trackbike
    Yamaha SR250 Spazz-Trakka
    Suzuki GSXR750 L
    Suzuki TS50X
    Suzuki TS50X
    Lozzo, Mar 21, 2008
    #51
  12. JB
    Lozzo, Mar 21, 2008
    #52
  13. JB
    Andy Bonwick, Mar 21, 2008
    #53
  14. JB
    Why were they suggesting replacing them? I haven't got a clue but was
    it down to valves breaking, seats needing re-cutting, collett grooves
    wearing and dropping the valves?
    #54
  15. JB
    Heads fall off, innit? Valve head and stem are different metals and
    the weld between them lets go some time after 50k, leading to an
    advisory that they should be changed at 50k.
    Pip, Mar 21, 2008
    #55
  16. JB
    That's hardly a rarity is it?
    #56
  17. JB
    Ultra-light aircraft often used to use converted VW engines. I dunno
    if it's the same for microlights, but ultralights had dual-plug
    conversions done and the crank would have been crack-tested. I guess
    there would have been some sort of thrust bearing fitted too.
    Pip Luscher, Mar 22, 2008
    #57
