Why is it?
Discussion in 'UK Motorcycles' started by Salad Dodger, Apr 26, 2010.
  1. Salad Dodger
    Salad Dodger Guest
    When you need to do a pair of jobs, that one is piddlingly easy, and
    the other impossible.
    GL1500 fork seal.
    RHS, 37 minutes, fork back in lower yoke.
    LHS 3 hours and counting.
    The fork won't pull apart. All the bolts are out, as is the oil, and
    the spring.
    It's currently in a vice, with a ratchet strap hooked through the
    bottom, attached to the garage door mounting. Taut as a guitar string.
    A 2lb hammer is being applied gingerly. With a wood block in between.
    Everything else on the Wing is okay, afaict. Even the exhausts don't
    fart anymore.
    | ___ Salad Dodger
    _/_____\_ GL1500SEV/CB1300SA-9/CBX1000Z
    _\_____/_| .106850../..08850.../..32457.
    '^' RBR Clues: 08 Pts:0145 Miles:0406
  2. Salad Dodger
    Jim Guest
    Is this the one where you can pop the seal out by filling it all back up
    with water and pushing it together?
    Jim, Apr 26, 2010
  3. Salad Dodger
    Thomas Guest
    Sometimes you can blame an engineer. (This comes from someone who
    retired from a career in engineering.)
    I bought an ST1300 after owning an ST1100. It seems as if Honda put a
    team of newbie engineers on the ST13 with no supervision. For any
    task, the 13 takes twice as many tools and twice as many fasteners as
    the 11. Just pulling the front wheel on the 13 takes: 3 allen
    wrenches (5, 6, & 17mm,) and 4 hex wrenches (8, 10, 12, & 22mm.) The
    left brake caliper is held with socket head cap screws while the right
    uses hex head bolts. Absurd.
    Thomas, Apr 26, 2010
  4. Salad Dodger
    Salad Dodger Guest
    It's now lying at the back of the garage.
    I've cobbled together another fork out of spares.
    When that Froggie recovery lad strapped it to the trailer last August,
    he managed to force out nearly half the total amount of ATF.
    750ml in, ~400ml out.
    Anyway, it's now re-forked. Finish bolting the front on tomorrow, then
    it's in the hands of the MOT gods once more.
  5. Salad Dodger
    Salad Dodger Guest
    One assumes correctly.
  6. Salad Dodger
    Salad Dodger Guest
    Oh, and for added "fun", try dropping a Wing off the centre stand, and
    then realising that re-attaching the bars *might* have been a good
    move.
    Glad my mum made me eat my greens.
    That said, it's so well balanced, it was ridiculously easy to put back
    onto the centrestand in the same configuration.
  7. Salad Dodger
    That was going to be my questioon. I spent half an hour pulling forks
    apart before Pip reminded me there was a circlip installed as well.
    Daft thing was I'd just stripped the other fork with no bother.
    Lozzo, Apr 26, 2010
  8. Salad Dodger
    Salad Dodger Guest
    The "circlip" that Honda use is more of a big wavy bit of bent wire,
    and is unmissable when looking at the seal.
  9. Salad Dodger
    Same as most others, they pretty much all have that wavy bent wire
    thing now
    Lozzo, Apr 26, 2010
  10. Salad Dodger
    zymurgy Guest
    Water ? ITYM cheap oil.
    It's piss easy popping the seal out by overfilling then jacking up the
    fork using a trolley jack. Much easier than farting around stripping
    the fork damper tube out.
    Paul.
    zymurgy, Apr 26, 2010
  11. What an excellent idea. Never thought of that.
    The Older Gentleman, Apr 27, 2010
  12. Salad Dodger
    Salad Dodger Guest
    Unless a frog sort has blown the seal by strapping the Wing onto a
    trailer a little too tightly.
    Salad Dodger, Apr 27, 2010
  13. Salad Dodger
    "Non, eet eez just ze frost sur ma moustache"
    CT, Apr 27, 2010
  14. Salad Dodger
    Salad Dodger Guest
    Pah. You're preaching to the choir on Honda's complexity for simple
    jobs.
    Front wheel on a GL1500SE:
    1x19mm; 4x12mm; 4x10mm; 6x8mm; 6x6mm hex; 4x5mm hex and 1xscrew.
  15. Salad Dodger
    Salad Dodger Guest
    And they have looked upon me with benevolent eyes.
    Salad Dodger, Apr 28, 2010
  16. Salad Dodger
    Colin Irvine Guest
    +1
    Colin Irvine, Apr 28, 2010
  17. Using the patented Mavis Beacon "Hunt&Peck" Technique, Colin Irvine
    +2
    Wicked Uncle Nigel, Apr 28, 2010
  18. Salad Dodger
    Salad Dodger Guest
    Thank you all. You can uncross your fingers now.
    Just got it home.
    By 'eck, those TorqMonsters make it sound more sporty than it is.
    A proper six-pot howl at peak torque revs and above.
    "Front brake pads not tested" on the yellow slip.
    Can't see them without taking off the disc covers, and you're not
    allowed to dismantle the bike while testing.
    This is its eleventh MOT (fifth from the same place) and the first
    time it's been noted.
    They *did* test the brakes, though.
  19. Salad Dodger
    davethedave Guest
    CBR400 spark plugs. body off, seat off, multiple fasteners to do. Tank off, air-box
    off, realise you can't get the plugs out without removing the engine or some shit
    pause briefly to turn the air blue, in a tirade of abuse that would make even Nige
    blush, at the witless drawing board monkey that came up with such an overly complex
    abortion of an excuse for a bike. Then, of course , Haynes manual stylee the
    refitting is the reverse of removal.
    2 hours for no benefit.
    ZXR400 same job. 1 x allen bolt on the seat, 3 on the tank, air-box comes off easy
    as pie, pop the leads, out with the plugs, in with the new, pause briefly to smile
    at the thoughtfulness of the designers whilst smoking fags (Its only petrol) and
    drinking tea. Cable up HT, pop on the air-box and the tank, remembering to hook up
    the fuel. :) screw on the seat. Start up, ride to pub in countryside, phone mate
    with CBR400, gloat.
    One and a half hours-ish including road test and a pint.
    Why do Honda do it? Why? They all seemed to be designed to cause you maximum grief.
    davethedave, Apr 28, 2010
  20. Salad Dodger
    Salad Dodger Guest
    Looking at the dismantled one, it looks like he slider bushing has
    slid over(outside) the damper bushing, and is catching under the lip
    below the seal.
    I've got my eye on a set on Ebay, which could be a useful safety net
    for the future.
