That sometimes engines take ages to fire up when you've rebuilt them? Just replaced the cylinder head on a '98 Bandit 600 for a mate, because the numpty he bought it off had snapped two of the cam cap bolts. Everything went together just perfect, but when it came to starting it the bike flattened two fully charged batteries before eventually firing and settling to a steady tickover when warm with no adjustments needed. Why couldn't it have just started up from the beginning? When the SR250 was rebuilt it fired up second stab of the button and settled almost immediately, with a simple adjustment to the tickover screw. Puzzled -- Lozzo Triumph Daytona 955i SE Suzuki SV650 K3 Honda CBR600 F-W Yamaha SR250 SpazzTrakka Suzuki GSX-R750L
2 days and umpteen flat batteries after rebuilding the lump in my MGB I called up my BiL who was at the time a spanna monkey. 2 hours later he turned up, put the key in and it fucking started. After the hassle getting it running it turned out to be such a good starter that every now and then it would fire as you turned on the ignition and actually start. Disconcerting until you got used to it.
I have recently become the proud (second) owner of a Honda ST70 that had not been used since 1981, I drained the petrol tank of what smelled like white spirit, put some petrol in and it started second kick. I have to admit, I was impressed.
I drowned one of those numerous times in welsh bogs when I was a sprog. They're indestructible. -- Krusty www.MuddyStuff.co.uk Off-Road Classifieds '02 MV Senna '03 Tiger 955i '96 Tiger '79 Fantic Hiro 250
Did you prime the carbs? Had any oil run down the bores as the head was fitted? New plugs or old? Did you *do anything* just before it started, like wiggle the plug leads or flick the kill-switch? When it finally started, did all 4 pots chime in together or just 1 or 2 initially with the others catching-on after?
Dave Emerson says... Yes, I left the fuel tank I use for carb balancing connected and turned on for 5 minutes before trying to start it, knowing the carbs had been emptied. I was checking carb balance after getting it started. No, the cylinder head I fitted was bone dry of oil as it was a replacement for a damaged one. When it arrived it had a bit of workshop dust and grit in it so I gave it a damn good clean out with clean fresh paraffin and then dried as much of it off with a clean rag, then emptied a whole huge can of brake/parts cleaner in there to be sure I blasted all the crap out of those hard to brush nooks and crannies. I left it to air dry after that. The bores were also bone dry when the head went back on. I lubed the cam journals and lobes as they were fitted and threw some fresh oil in there for good luck before putting the cam cover back on. The oil level was slightly low before I took the head off, so needed topping up anyway. Same plugs, which were replaced less than 500 miles ago, cleaned before refitting to the new head. Nope, just tried a second battery off my CBR600, which was brand new and fully charged, which it flattened. Then put the original battery on charge for a couple of hours, and within 2 or 3 minutes of trying it fired up fairly nicely all of a sudden. It spluttered, coughed and stopped a couple of times, then chimed in on all four cylinders together and happily ticked over. Weird. -- Lozzo Triumph Daytona 955i SE Suzuki SV650 K3 Honda CBR600 F-W Yamaha SR250 SpazzTrakka Suzuki GSX-R750L
Molly says... Yes, he seems chuffed to bits with it now. Thanks for sending him round. -- Lozzo Triumph Daytona 955i SE Suzuki SV650 K3 Honda CBR600 F-W Yamaha SR250 SpazzTrakka Suzuki GSX-R750L
Or fucking obsolete, as I've just discovered. Big bumper Saab 900i had a different header and front exhaust box assembly 1985-1986. The front box on my 1985 big bumper 900 has just gone [1]. [1] This is 'just' as in six months ago but how now become even louder.
If you don't mind getting your hands dirty, http://www.jetex.co.uk/website/jetexcustomexhaustparts.php should have all the parts you need to either fit a new box or replace it with a bit of pipe. -- Krusty www.MuddyStuff.co.uk Off-Road Classifieds '02 MV Senna '03 Tiger 955i '96 Tiger '79 Fantic Hiro 250
