Why switch to synthetic oil?
Discussion in 'Motorcycle Technical Discussion' started by GuBrCo, May 8, 2007.
  1. GuBrCo
    GuBrCo Guest
    what are the advantages of switching? besides costing more is there any
    disadvantage using synthetic oil?
    GuBrCo, May 8, 2007
  2. Synthetic oils are more slippery ;-/
    Seriously, though, they really do perform well on modern high-revving
    engines, and many high-performance bike manufacturers recommend only
    synthetics in their motors.
    In theory. oil change intervals are extended if you use synthetics in
    more elderly engines, but I'd say using them in something like an SOHC
    Honda Four or an old Z900 is overkill.
    The Older Gentleman, May 8, 2007
  3. GuBrCo
    E M F Guest
    GuBrCo scribbled;
    E M F, May 8, 2007
  4. Clutch slip, on car synthetics with friction modifiers, yeah, but
    increased oil leaks? Nah.
  5. The early versions of synthetic oil lacked the seal swell component
    found in most lubricants, and so synthoil got the reputation of
    causing leaks. No longer a problem.
    Michael Sierchio, May 8, 2007
  6. Ah, right. Thanks. That must be damn early, because synthetic oils have
    been around for decades.
  7. GuBrCo
    John Johnson Guest
    I've always heard of it being associated with 1970s synthetics. I don't
    know if that counts as "damn early" or not, as I wasn't following
    synthetic oil at the time.
    Later,
    John
    John Johnson, May 8, 2007
  8. GuBrCo
    E M F Guest
    " Bob Scott scribbled;
    E M F, May 9, 2007
  9. Utter nonsense. My Ducati handbook even recommends fully synthetic oil
    (Agip, as it happens, though any decent brand will do).
    The Older Gentleman, May 9, 2007
  10. GuBrCo
    Ken Abrams Guest
    1) No additives.....means nothing not already IN the oil. ALL engine oils
    have additives.
    2) There are several synthetic oils made SPECIFICALLY for wet-clutch
    motorcycles.
    Not only are they perfectly safe for a wet-clutch vehicle, they offer
    superior lubrication characteristics and increased resistance to thermal
    breakdown, both in normal use and should the bike overheat for whatever
    reason.
    Use a synthetic designed for a car? Certainly NOT but in my book, the
    slight extra cost for a good motorcycle synthetic is well worth the added
    protection. It even protects (somewhat) from a stupid human trick of
    forgetting to change the oil on time.
    Ken Abrams, May 9, 2007
  11. What does Sir think a 10/40 synthetic oil is?
  12. GuBrCo
    John Johnson Guest
    AFAIK, synthetic oils consistently outperform regular motor oils in
    resistance to viscosity breakdown from heat, retain their viscosity and
    lubricating characteristics longer, and often allow engines to run
    cooler (presumably because of better heat transfer characteristics, but
    possibly also lower friction in the engine).
    That motorcycles have, do, and will run just fine on non-synthetic motor
    oils doesn't change the above. That your bike is just fine on regular
    10-40 is irrelevant to synthetic oil properties. Furthermore, you got
    those properties just plain wrong, though it's not uncommon for people
    to claim that synthetics are unsuited to wet clutches because so many
    motorcyclists used automotive synthetic oil and had problems with it.
    Unfortunately for you, the problem has nothing to do with the synthetic
    nature of the oil and everything to do with the additive package
    designed for vehicles that don't bathe their clutch plates in engine oil.
    Later,
    John
    John Johnson, May 10, 2007
  13. GuBrCo
    GuBrCo Guest
    message
    Thanks for all of the information. I ride an 05 Shadow Aero 750 with 20k Km
    on the clock and have made the switch to motorcycle SAE 10W 40 synthetic
    oil. A friend has stated that I should do another complete oil change in
    another 3k Km. to get rid of the remaining dino oil. I know synthetic and
    dino oil is supposed to be fully compatible so is this oil change still
    req'd?
    GuBrCo, May 10, 2007
  14. No. Unless the bike is due an oil change then anyway. Your friend is an
    ignoramus - no offence intended.
    The Older Gentleman, May 10, 2007
  15. Fine. However, synthetic oil *will* offer better protection. As I
    implied at the beginning of this thread, before you started getting
    confused about additives, it is for the owner to decide whether the
    cost/mileage equation is worth it or not.
