Why won't it start?
Discussion in 'UK Motorcycles' started by Lady Nina, Mar 12, 2009.
  1. Lady Nina
    Jérémy Guest
    I think you've discovered a grammatical error previously unknown to science
    there.
    Jérémy, Mar 13, 2009
    #41
  2. Lady Nina
    It's a line trotted out on ukrm regularly, but I've never had it
    happen. Every year since 1992 my bike has been put in the garage
    around Oct/Nov and not startup until Feb at the earliest, sometime
    later.
    A few years back the TOG Tour in early May was the first time my bike
    had moved for seven months.
    Ah, I can't beat that :eek:/
    CT, Mar 13, 2009
    #42
  3. Lady Nina
    Indeed, and one that I thought I'd managed to disprove. But I suppose
    not everyone will be convinced.
    Hah. When I had the now-Blaney 400/4 in my garage (having bought it
    for J who never really got into biking once shed passed her test)
    alongside the gixxer, I'd take it for a brief run perhaps once or
    twice a year, tops, just to keep it running, like. So there were
    almost certainly times when the petrol would have been in the tank for
    two years or more. Never had problems starting it over the whole 4-5
    years I had it.
    Ace, Mar 13, 2009
    #43
  4. Lady Nina
    Pete Fisher Guest
    Probably not an issue on most bikes. Nordwests with the Teikei two stage
    carb do suffer from it. In fact even a fairly short period unused can
    make them difficult to start even if everything else is tip top.
    Fortunately the carb has a convenient drain screw so it is easily
    rectified. Only the petrol in the float chamber seems to go off.
    The theory, and I stress this is a theory, is that the most volatile
    fraction in the fuel within the carb evaporates, even after 'topping; up
    by opening the petrol tap.. A complete fresh float bowl full from the
    tank often does the trick.
    I don't know the science of it, but I know it has worked for me a few
    times. TBF the somewhat all or nothing nature of the starter jet on them
    doesn't help. I soon discovered that a good dodge is to operate the
    'choke' progressively while cranking the motor over. It would often then
    hit the sweet spot and fire up. Still Nordwests are 'special'. In any
    case the best cure is to put FOAD CR33 smooth bores on them.
    | Pete Fisher at Home: |
    Pete Fisher, Mar 13, 2009
    #44
  5. Lady Nina
    Ace, Mar 13, 2009
    #45
  6. Lady Nina
    Pete Fisher Guest
    A carburettor is not a 'sealed container'. As I said, for most vehicles
    it is not an issue. For some high compression singles left unused for a
    while I'm not so sure. Note that just refilling the float chamber with
    'old' fuel from the tank is sufficient.
    So I'm not saying fuel does go 'off' in the tank. It could also be a
    case of some water condensation gathering in the bottom of the float
    chamber.
    I have tested the refill the float chamber with fuel strategy on several
    occasions, so empirically it works for me. Faced with a bike that
    wouldn't start after being left for a while it would be the next thing I
    checked after making sure there was a good spark.
    Also, IME it's best to leave the petrol tap on for a reasonable time
    before attempting to start any bike that has been standing for a long
    period.
    So, yes it's probably not a question of gone 'off', but just gone.
    #46
  7. Lady Nina
    Indeed, & not just high comp singles. If I leave my old Tig for even
    just a few weeks, it gets unhappy about starting. Drain the floatbowls,
    switch the tap back on, & it fires up instantly.
    I now switch the petrol tap off a minute or so before killing the
    engine to empty the bowls a bit, & it starts perfectly every time, even
    after several months.
    The Corvette started & ran fine on petrol that had been in the tank for
    13 years. Likewise my old V8 Cherokee ran fine on 5-6 year old petrol.
    So petrol in a tank doesn't go off to the point where it won't work,
    but petrol in carbs can, & anyone who says differently is wrong. Simple!
    Krusty
    '03 Tiger 955i
    '02 MV Senna (for sale) '96 Tiger (for sale)
    '79 Fantic Hiro 250 (for sale) '81 Corvette (for sale)
    Krusty, Mar 13, 2009
    #47
  8. Lady Nina
    zymurgy Guest
    There's cheap and there's crappy varieties though.
    Yea, me and chargy things don't get on, as they're always flat when
    you want to use them . and i'm too cheap to keep them plugged in
    permanently, so the start and charge and a great gurt extension lead
    does me fine.
    P.
    zymurgy, Mar 13, 2009
    #48
  9. Lady Nina
    T i m Guest
    FWIW I left the old (Madras) REB 350 for 3+ years untouched. The fuel
    smelled like paraffin the float chamber was a bit gunged up and dry,
    as was the battery.
    I gave the float bowl a bit of a clean (with stale petrol from the
    tank), a decompress and a couple of dry kicks and it fired up first
    real kick. Ok, there was a fair bit of smoke to start with but it soon
    cleared. But then it was probably designed to run on paraffin in the
    first place!
    T i m
    p.s. It was hearing that 'dob dob dob' on tickover than nearly made me
    change my mind and keep it. It was a dear old thing, never leaked a
    drop of oil and didn't miss a beat over the 5000 miles I had it.
    T i m, Mar 13, 2009
    #49
  10. Lady Nina
    M J Carley Guest
    Where can I buy one of these?
    M J Carley, Mar 13, 2009
    #50
  11. Lady Nina
    My experiences are with my ZZR600, ZXR750 and ZX-9R over a period of 15
    years, and every winter.
    Me neither.
    CT, Mar 13, 2009
    #51
  12. Lady Nina
    T i m Guest
    Where I sold mine ....
    http://www.haywards.co.uk/
    T i m
    p.s. I don't think it will really run on paraffin but I think they do
    (or did) a diesel one. ;-)
    T i m, Mar 13, 2009
    #52
  13. Lady Nina
    darsy, Mar 13, 2009
    #53
  14. Lady Nina
    I've never had the problem with injected engines either.
    Some people refuse to believe anything they haven't had personal
    experience of. If it wasn't for the Tiger, I might be in Ace's camp on
    this. But because of the Tiger, I know categorically that it can happen
    (& has to lots of others on both the Yahoo Tiger & trailriding groups
    too).
    Krusty
    '03 Tiger 955i
    #54
  15. Lady Nina
    Well let me know when you've tested it on every carb bike ever made, ok?
    Krusty
    '03 Tiger 955i
    #55
  16. Oh, it does, but only over very long periods of time, like a few years.
    The Older Gentleman, Mar 13, 2009
    #56
  17. My old 1200 Trophy was similarly reluctant. It would kick in on one,
    then two, then three and finally the other three pots would sort of kick
    the fourth one out of bed and it would be A-OK.
    #57
  18. Has Ben still got that? Bloody nice bike, that was.
    #58
  19. LOL
    #59
  20. Lady Nina
    and I (kick) started the KTM at the weekend after optimating the
    battery. It started 4th or 5th kick, after not running since last
    August.
    *nods*
    darsy, Mar 13, 2009
    #60
