Why won't it start?
Discussion in 'UK Motorcycles' started by Lady Nina, Mar 12, 2009.
  1. Lady Nina
    It's a well-known phenomenon, and has always been thus, not related to
    'modern' petrol at all. Standard part of pre-flight checks on small
    aeroplanes, for instance, to open a drain cock and let the water out
    before you even get into the pilot's seat.
    Ace, Mar 13, 2009
    #81
  2. Lady Nina
    SteveH Guest
    Many years back, my mechanic drained a couple of pints of water from the
    bottom of my Diversion's petrol tank after it broke down and the AA
    couldn't find anything wrong.
    Seems it had settled in the reserve bit of the tank, so only became an
    issue if you were well into the reserve supply - which it why it never
    surfaced until the day I was rushing to get home and couldn't be arsed
    filling up.
    SteveH, Mar 13, 2009
    #82
  3. Lady Nina
    Eiron Guest
    That's not suspended water. That's just water at the bottom of the tank,
    being denser than petrol.
    The difficult bit to believe is that crn's petrol had ~10% water in a
    suspension or emulsion without it being noticable.
    Eiron, Mar 13, 2009
    #83
  4. Lady Nina
    Simes Guest
    It was probably in the bottom of the tank anyway - the result of
    condensation settling on the sides of the cold tank then running down
    into the petrol. Still doesn't show that the petrol has 'gone off' or
    that the fuel was like that when you bought it.
    Simes, Mar 13, 2009
    #84
  5. It's in my Dad's garage. I'll bring it here when my Herald has been
    restored.
    I liked both. The black suited it better, but the red is more shiny!
    vulgarandmischevious, Mar 13, 2009
    #85
  6. This is a serious matter. You are doubting Bear's very eyes.
    #86
  7. Lady Nina
    crn Guest
    Who said 10% ?.
    Around a quarter of an inch (ICBA to go out and measure in the dark) in
    the bottom of a gallon plastic container[1] is rather less than that.
    The Bantam has been giving grief if left standing for a few days, when
    I carefully removed and examined the carb there were water droplets in
    the bottom of the main jet cover. Draining the tank did not reveal any
    water until it had been left to stand for 4 days so the water must have
    been suspended in the fuel and then settled out. My guess is that the
    shaking of a short ride would have mixed in in again.
    I have no idea where the water came from, maybe it came from the pump,
    maybe condensation, maybe rain getting in around the fuel cap, who knows.
    The petrol tap takes fuel from very low in the tank so it would only
    take a small buildup of maybe a quarter of an inch for it to get down
    into the carb.
    Most modern bikes have a reserve setting so the main setting would be
    drawing fuel from a bit higher in the tank so the Bantam is maybe more
    sensitive to this problem.
    [1] Originally contained parafin, about the same shape as a gallon
    metal can of oil.
    crn, Mar 13, 2009
    #87
  8. Lady Nina
    crn Guest
    Does it matter ?. The symptoms of difficult starting are the same and
    many cases of "stale fuel" could actually be a drop of water in the carb.
    The cure is also the same - clean the carb, empty the tank and refill
    with clean fuel.
    crn, Mar 13, 2009
    #88
  9. The pope has admitted making a mistake.
    #89
  10. I haven't professed an opinion about the life of petrol.
    #90
  11. Lady Nina
    Higgins Guest
    Ye dinnae look that bonnie tae me, laddie.
    Higgins, Mar 14, 2009
    #91
  12. Lady Nina
    boots Guest
    They do? Not IMLE, my shite old bonneville has but the more modern
    stuff has just had a warning light come on.
    boots, Mar 14, 2009
    #92
  13. Lady Nina
    I suspect that you are neither bonnie, nor a prince.
    Champ, Mar 14, 2009
    #93
  14. Lady Nina
    I don't think I did, you know.
    Champ, Mar 14, 2009
    #94
  15. Oh. I always took the two things to be synonymous - going off is when
    the volatiles evaporate and leave the varnish.
    The Older Gentleman, Mar 14, 2009
    #95
  16. Lady Nina
    crn Guest
    Yebbut there is a long intermediate period where the most volatile bits
    go quite quickly, the moderately volatiles gradually go next, and in a
    matter of years you eventually end up with a residue that smells like
    turpentine. It is a long gradual process during which the remaining
    fuel gets more and more difficult to start because the most volatile
    parts are the easiest to ignite.
    crn, Mar 14, 2009
    #96
  17. Lady Nina
    davethedave Guest
    I thought going off was when you checked the level of the fuel in the
    tank using a naked flame.
    davethedave, Mar 14, 2009
    #97
  18. Yes. I. Know.
    #98
  19. Lady Nina
    crn Guest
    Yes, I know you know. My comment was for the enlightenment of certain
    thick sods who deny that such a problem exists.
    No personal offence was intended.
    crn, Mar 14, 2009
    #99
  20. Lady Nina
    Naah, no way.
    It must be at least 20.
    Ace, Mar 14, 2009
