Why won't my central heating start?
Discussion in 'UK Motorcycles' started by Simon Wilson, Oct 27, 2009.
  1. Simon Wilson
    72degrees Guest
    So is that a 'chauffe eau' independent of the rest of the heating
    system ? Can't see how I could get antifreeze in to our 'ballon' .
    Neat - assuming the power never drops out. I thought of similar
    solutions here (except for electrical heating rather than oil) but
    couldn't come up with a way to reset the master 'disjoncteur' in the
    case of that tripping out. I suppose I
    72degrees, Oct 30, 2009
  2. Simon Wilson
    72degrees Guest
    <drat netbook small keyboard>
    I suppose I could get our concierge to check it in the event of any
    major power outage, but the last time it would have been a big issue
    you couldn't get through the snow to our place without a tractor for
    four days anyway. What I need is a 'disjoncteur' with a web server and
    a decent backup power supply.
    I've been keeping an eye on the ranch back home using WebamXP on an
    old laptop.
  3. Simon Wilson
    Simon Wilson Guest
    Yeah the hot water system is entirely separate. I guess in theory that
    could freeze too but it's pretty well insulated. I had a max/min
    thermometer in the cellar where it's mounted last winter and it never
    dropped below 4C. Balloon - is that your hot water tank - can't be, you
    wouldn't be thinking of antifreeze in the water supply. Your central
    heating circuit is a closed circuit though, shirley?
    Yeah if the main power trips that the end of the game. It's only done it
    once in a thunderstorm so far. Otherwise in theory the router and this
    gadget are supposed to restart.
    Simon Wilson, Oct 30, 2009
  4. Simon Wilson
    72degrees Guest
    Well, yes, I suppose antifreeze would be a v. bad idea in a system
    connected directly to the mains. The ballon is right in the centre of
    the house but I suspect it gets pretty cold when it is -13 outside
    (which it can be quite often in February). We haven't got any heating
    other than wall mounted electric radiator/convector units, and of
    course the wonderful log burner.
    Our insurance man did say that it was possible to get 'remote' re-
    setting disjoncteurs, but that they were so expensive that only large
    businesses installed them. He advised that the only way to be sure was
    to drain down, so we do that to, as well as bunging salt in to all the
    waste water traps. We only need to do that in late October and again
    after Xmas, so it's not too much of a faff.
  5. Simon Wilson
    Simon Wilson Guest
    Ah, conventional rads here - would be right royal pain to drain several
    times a year. Next time I drain it I'm going to have to save it all -
    the antifreeze was 143 euro(s)[1]!
    Open fire atm, log burner is one of the nearterm projects...
    + empty the loo cisterns? I had one of those crack in a house in the uk
    that I had left empty.
    [1]never sure if there's supposed to be an s or not.
  6. Simon Wilson
    72degrees Guest
    Indeed. The one at 'the chateau' has it's own water service valve
    which speeds up the process before finally turning off the main stop
    tap.
  7. The semi-official advice was singular. Since it sounds odd using a
    singular to describe a plural quantity, it was left up to the user. The
    advice was un-heeded by most.
    Grimly Curmudgeon, Nov 1, 2009
