Hi All, I tidying up my little CB250 ShiteHawk (the Daughter may well move onto it after her test) and there is some crack damage to the lhs panel and the little one that joins the two side panels over the taillight that I like to sort pre re-painting (a mate will do that for me for nowt). Ages ago I drilled the crack on the side panel and cable tied it together at the open end of the crack (it nearly went across the whole panel) and it hasn't got any worse over the last couple of years. I have now taken plastics off, cleaned them thoroughly and super glued the cracks together, just to keep them aligned for the next step. So, working on the theory that outside of a proper 'plastic welded repair' (assuming that might be expensive?) I was thinking of screwing some small ally plates across the back of the cracks using small countersunk screws from the outside (than could be filled over) maybe with the plates bedded in some Epoxy or summat (after keying up the panel)? Is there a better (cost effective) d-i-y way please? All the best .. T i m
