Will I kill my optimate if....
Discussion in 'UK Motorcycles' started by Fr Jack, Feb 13, 2006.
  1. Fr Jack
    Fr Jack Guest
    And lo - he did search amongst the crap in the cupboards and did find a
    battery, sealed and new.
    **** me - it's the right size and everyfink!
    Time to get it charged up and fitted!
    Cheers!
    Fr Jack
    B12S (The Red Mist), CB450DX (The Moped)
    FRJACKUKRM AT GMAIL DOT COM
    Red death, to set you free
  2. Fr Jack
    Champ said...
    Oh lovely.
    Lozzo, Feb 13, 2006
  3. Fr Jack
    Another mate got me in to start his carb equipped Triumph after an
    unprepared lay off outside. It was a bitch to start. The trick is not to
    use any throttle just full choke, and to apply the starter in 2 - 3
    second bursts after draining / refilling the carbs to purge water /
    general muck that may have ended up in the float bowls.
    Muck, Feb 13, 2006
  4. Fr Jack
    Christofire Guest
    To start the 955 you turn the ignition on and then press the starter.
    No throttle, let the bike work out what it needs. Easy.
    Christofire, Feb 13, 2006
  5. Fr Jack
    Christofire said...
    The Gixer has a choke lever that needs to be used when it's cold. I
    can't understand why cos it has FI and should work it out for itself..
    Lozzo, Feb 13, 2006
  6. Fr Jack
    Lozzo emerged from their own little world to say
    We've been here before.
    It's not a choke. It just opens the throttle a smidgen. Same on my boxhead
    system. In previous threads Champ described it as a "fast idle lever".
    wessie, Feb 14, 2006
  7. Fr Jack
    Crikey, I didn't realise the K1 did that. I always thought it strange,
    when I first got my Sprint ST, thet the VFRs I was comparing it with
    still had some sort of cold-start lever.
    FYI, the K3 onwards have proper FI, with no such fitment.
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Feb 14, 2006
  8. Fr Jack
    Elbow? No, it just takes a press of the thumb... or a turn of the key,
    in the case of the lawn mower. Dunno what sort of bike/mower you have
    that you use the elbow to start...
    _______
    Ace, Feb 14, 2006
  9. Fr Jack
    Heh.
    Thanks, I needed that ;-)
    _______
    Ace, Feb 14, 2006
  10. Fr Jack
    Whoosh.
    Muck, Feb 14, 2006
  11. Fr Jack
    ... and a pelvic thrust ...
    Pip, Feb 14, 2006
  12. Fr Jack
    It's the same on the old 748 and 916 Ducatis.
    Andy Bonwick, Feb 14, 2006
  13. Fr Jack
    And MVs.
    Krusty.
    http://www.muddystuff.co.uk
    http://www.muddystuff.us
    Off-road classifieds
    '02 MV Senna '03 Tiger '96 Tiger '79 Fantic 250
    Krusty, Feb 14, 2006
  14. Fr Jack
    Scraggy Guest
    <flounce>
    Scraggy, Feb 14, 2006
  15. Fr Jack
    simonk Guest
    And old-skool Milles (the new ones are controlled, terrifyingly, by an
    Italian computer brain)
    simonk, Feb 15, 2006
  16. Fr Jack
    Fr Jack Guest
    it can wait until I'm on better form... gotta put the acid in.
    6 ickle bottles all joined together...oh fun...
    Cheers!
    Fr Jack
    Fr Jack, Feb 15, 2006
  17. Fr Jack
    It's a piece of piss, man. Whip the lid(s) off the battery, rip the
    foil closures off the acid bottles. Line up, take a deep breath and
    invert acid bottles over battery openings and leave to drain. All
    done in a few seconds.
    Do it outside with a bucket of water handy if you're really worried.
    Pip, Feb 15, 2006
  18. [new battery]
    If I can do this without any problem, and I can, then anyone can.
    Paul Corfield, Feb 15, 2006
  19. Fr Jack
    Ben Guest
    It's not a choke, it's a "fast idle" apparently.
    Ben, Feb 15, 2006
  20. Using the patented Mavis Beacon "Hunt&Peck" Technique, Champ
    The Voyager doesn't have one.
    Which is odd, when you think about it.
    Wicked Uncle Nigel, Feb 15, 2006
