wind noise / replacement screens
Discussion in 'UK Motorcycles' started by Jeremy, Apr 8, 2009.
  1. Jeremy
    Jeremy Guest
    I'm 6' and in a relaxed riding position (arms bent), there is a lot of
    turbulenced leading to a lot of wind noise. When I straighten my back
    (so sit more upright) the difference in noise is significant - with
    earplugs in it's really quiet.
    When I bought the bike (Sprint ST 955) I ordered it with the touring
    screen - but it didn't look right so changed it back to the origininal
    within a week or two.
    I am trying to work out what is happening with the airflow that creates
    the turbulence - if sitting more upright reduces the noise then I guess
    my head is moving clear of the turbulence. So I would not expect a
    higher screen to be the answer - but ICBW.
    Jeremy, Apr 8, 2009
  2. Jeremy
    TOG@Toil Guest
    Sound about right, but The Boy Carley is the man to answer this one.
    TOG@Toil, Apr 8, 2009
  3. Jeremy
    If sitting normally gives turbulence around the head, then sitting up
    moves the turbulence to closer to your chest so you are less aware of
    it.
    A higher screen will move the turbulence up and over your head when
    sitting normally, but obviously if you sit more upright with a high
    screen then you'll experience the turbulence again.
    Or something.
    CT, Apr 8, 2009
  4. Jeremy
    Jeremy Guest
    Seems like a lower screen would be the answer then.
    Or something.
    What're double bubble screens supposed to do?
    Jeremy, Apr 8, 2009
  5. Jeremy
    Simon Wilson Guest
    My guess is that they are supposed to create two bubbles :)
    Looking at the design of them it looks like one bubble is low and wide,
    for the rider's body, and the other taller and narrower, for the helmet.
    I get a lot of wind noise/turbulence on my ST1100 (though a laminar lip
    helps a *lot*), but on my 675, which has a double bubble, the airflow
    is incredibly smooth and quiet. On the 675 my head is way up over the
    top of the screen (I don't do that crouchy thing), and yet I don't get
    any neck strain etc.
    Simon Wilson, Apr 8, 2009
  6. Jeremy
    Colin Irvine Guest
    Indeed. We had them on both Thunderaces. The smaller bubble would
    deflect air heading for the helmet, while there was plenty of air on
    the shoulders to help support the upper body. Worked a treat.
    Colin Irvine, Apr 8, 2009
  7. Jeremy
    M J Carley Guest
    You rang?
    The tests we've done show the windscreen effect on noise comes from
    the wake from the lip of the screen hitting the helmet. That wake will
    be slightly above the screen height, depending on the angle of the
    screen. To reduce the effect, you either want a high screen which
    lifts the wake above your helmet, or at least above visor level, or a
    low one which drops the wake below the helmet.
    My bill is in the post.
    M J Carley, Apr 8, 2009
  8. Jeremy
    The K4 thou was appalling with the standard screen. Since fitting an
    Airblade double-bubble I haven't really noticed whether it's good or not
    which, given how noticeable the wind was before, probably means it's
    done the trick.
    ogden, Apr 8, 2009
  9. Jeremy
    Jeremy Guest
    So it's just trial and error for Joe Public then? Based on the different
    dimensions of the human form, differing postures, differing bikes....
    Jeremy, Apr 8, 2009
  10. Jeremy
    Probably. I know that the Rizla Suzuki K3s that were raced in BSB were
    also fitted with DB screens, cos I bought one from them for mine.
    Certainly seemed to do the biz.
    Ace, Apr 8, 2009
  11. Jeremy
    M J Carley Guest
  12. Jeremy
    Jeremy Guest
    Jeremy, Apr 8, 2009
  13. Jeremy
    M J Carley Guest
