Winter's arrived...
Discussion in 'UK Motorcycles' started by Eddie, Oct 23, 2006.
  1. Eddie
    I think you may have misunderstood what carb icing actually is. It's
    not the petrol itself freezing, but the moisture sucked in with the
    air that freezes due to the pressure drop as it's sucked into the
    carb. This causes ice crystals to form which then block up the jet(s)
    and cause fuel starvation.
    A less volatile mixture may indeed reduce the freezing point of liquid
    petrol, but shouldn't make any difference to this phenomenon.
    _______
    Ace, Oct 23, 2006
  2. Eddie
    Eddie Guest
    IIRC, despite the name, carb "icing" doesn't actually involve ice at
    all.
    Isn't it caused when the temperature in the air stream drops below the
    dew point, causing water vapour in the air to condense in the jets?
    But yes, this is still true.
    However, ISTR that one way of lessening the effects is to use a mixture
    which includes something in which water is soluble, although I can't
    remember what that is. The so-called winter-grade petrol may include
    some of this.
    Eddie, Oct 23, 2006
  3. Eddie
    Eddie says...
    Dump the antiquated piece of carburretor laden crap and move into the
    21st century. Buy a bike with fuel injection.
    Lozzo
    GSF600SW (broked)
    'I do not object to people looking at their watches when I am speaking.
    But I strongly object when they start shaking them to make certain they
    are still going.' William Norman Birkett, 1st Baron Birkett, Oct 1960.
    Lozzo, Oct 23, 2006
  4. Eddie
    muddy cat Guest
    **** that, no KSBs. I miss frightening small children and dogs.
    muddy cat, Oct 23, 2006
  5. Eddie
    Cab Guest
    You're not advocating that Eddie buys a Beemer, are you?
    Cab, Oct 23, 2006
  6. Eddie
    I expect FI Kwaks still freeze up
    Hog, Oct 23, 2006
  7. Eddie
    Hog says...
    The Gixer didn't and I haven't ridden the Gaytona in cold enough
    conditions to tell. It does seem to be mainly a Kawasaki thing, but it
    has only ever happened to me once, and that was on my 2nd ZZR1100 on the
    M1 one morning.
    Lozzo
    GSF600SW (broked)
    Lozzo, Oct 23, 2006
  8. Eddie
    Lord I should think not! perfect it was.
    Hog, Oct 23, 2006
  9. Eddie
    catman Guest
    My Monster did as well. No idea which cylinder, but it would happily
    die. Fixed with 'posh' petrol.
    www.cuore-sportivo.co.uk
    catman, Oct 23, 2006
  10. Eddie
    MikeH Guest
    My GPX750 did it as soon as autumn arrived.
    Used to hit the icing point just as I reached the big roundabout near us
    (Cooper Dene at Bournemouth) and the engine would be fine until I slowed
    to approach the roudnabout. As soon as I opened the throttle to carry on
    the engine would die. Every time. I did catch on after the first couple,
    but that combined with the traditional Kwak off/6000rpm choke made the
    darker morings more 'interesting'.
    MikeH, Oct 23, 2006
  11. Eddie
    I wouldn't know because mine doesn't venture out of the garage on days
    when it's likely.
    Andy Bonwick, Oct 23, 2006
  12. Eddie
    "very wise" that's what SOB are for
    Hog, Oct 23, 2006
  13. Eddie
    SD Guest
    itycb right. My GPz750R did it from new, which made running it in a
    right git, and it stalled *every* morning at the end of the Westway,
    from October to March.
    The bloke at Pineways informed me that "they all do that, mate", as if
    that was okay, on a bike I'd just HP'd my life on for the next three
    years.
    | ___ Salad Dodger
    |_\_____/_| ..87753../..22653.../..31893.
    '^' RBR Clues: 84 Pts:1800 Miles:5704
    SD, Oct 23, 2006
  14. Eddie
    Beav Guest
    My fuel injected Zed never has, but the VN (carbs) did it for fun. In fact,
    the VN did it so much I suspected a faulty pair of carbs, so I changed them
    in an "elimination exercise". Different carbs, same problem but the Zed has
    never shown even a hint of the problem.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Oct 23, 2006
  15. Eddie
    Something like that. Worked very well with Elly's 9R, which iced like
    a bastard commuting up the M1. Having said that, it was tolerable on
    the motorway, just a bit of a snag a) getting down from 175 WFO in
    time to make the off-slip - and b) getting away at the top, then round
    the roundabout in heavy traffic. Filtering was a little on the dodgy
    side too, iirc.
    It can be difficult to source - Wynn's Dry-Fuel, intended to absorb
    moisture from fuel tanks of laid-up vehicles also worked well and may
    be easier to lay your hands on, there being more Wynn's stockists than
    Silkolenies these days.
    Pip, Oct 24, 2006
  16. Eddie
    Kim Bolton Guest
    I thought the problem was caused in part by the latent heat of
    vaporisation of the fuel; that is, it takes heat from its surroundings
    in order to evaporate. These surroundings are, of course, the
    carburettor. It is quite possible in the right conditions for the
    temperature of the carburettor not only to fall below the dew-point
    and therefore suffer from condensation, but also to fall below the
    freezing point of the condensate, i.e. icing.
    I suspect it depends on the LHV of the fuel, which could be changed by
    changing the components.
    Kim Bolton, Oct 24, 2006
  17. Eddie
    PDannyD Guest
    On Monday 23 October 2006 09:35, Eddie [] wrote in message
    My FZS600 had a very bad bout of "carb icing" last spring. Turns out the
    plug gaps were way too wide[1] and the carbs were out of balance by quite a
    lot. The plug gap was the main culprit though.
    [1] When measured, they turned out to be more than double what they should
    have been. They looked ok to me but then I'm used to old Land Rovers.
    PDannyD, Oct 24, 2006
  18. Pro-FST: British Technology Engineered in Britain.
    Pro-FST (Fuel System Treatment) was developed in 1992 following an
    unofficial request from Kawasaki Motors (UK) Ltd., for something that
    would deal with the particularly British problem of carburettor icing in
    damp, cold weather. (It was also specifically a motorcycle malady. Cars
    have room for heated air intakes.) KMUK were harder hit at that time
    than the other 3 big Japanese MIC manufacturers, because they sold a lot
    of 'GT' models to dispatch riders, who obviously covered a lot of miles
    in all weathers; there were also a lot of complaints from the 'off road'
    fraternity.
    John Rowland, (R & D Chemist)
    (Your writer has run into this one! The throttle slide in the AMAL
    carburettor of my 990cc Matchless engine, on a Morgan 3-wheeler, would
    sometimes freeze up so badly that I had to drive on the ignition cut-out
    like a Sopwith Camel pilot! I am now a Pro-FST user.)
    eric the brave, Oct 26, 2006
