Wireless networks
Discussion in 'UK Motorcycles' started by Lozzo, Jul 16, 2005.
  1. Lozzo
    Why doesn't mine work and why do I have to drop a CAT5 cable out of the
    window to access Elly's machine to post this?
    I even bought a Netgear usb doohicky so I'd make sure it all worked
    properly, but I can't connect to the network. I get a good signal and
    it tells me I'm connected to the group, but nothing happens when I open
    either Firefox, Gravity or Outlook. We've changed Elly's settings to
    allow my machine's MAC id to access the network etc with no joy.
    Is there anyone in our vicinity any good with network troubleshooting
    who might be able to help please?
    Lozzo, Jul 16, 2005
  2. Using the patented Mavis Beacon "Hunt&Peck" Technique, Lozzo
    Is euphemism, yes?
    BTW, tell Pip I got his SMS. I'll reply when I get my breath back... ;^)
    and Ducati Race Engineer.
    Enfield 500 Curry House Racer "The Basmati Rice Burner",
    Wicked Uncle Nigel, Jul 16, 2005
  3. Using the patented Mavis Beacon "Hunt&Peck" Technique, Lozzo
    BTW, in slightly more serious mode.
    Has Elly got WEP enabled?
    If so, you've almost certainly typed the wrong encryption key on your
    machine.
  4. Lozzo
    Wicked Uncle Nigel says...
    It works fine with her laptop, so I'd asume it is enabled. We've
    checked and double checked everything we can, not found any reason why
    it shouldn't work.
    I have to be rid of this CAT5 cable soon, it's purple FFS!
    Lozzo, Jul 16, 2005
  5. Using the patented Mavis Beacon "Hunt&Peck" Technique, Lozzo
    Erm... OK, WEP is an encryption technique for WiFi. If it's enabled on
    Elly's machine then you can see the network, but not use it.
    Sorry mate, I'm on Gardening Duty tomorrow (wivva hired rotavator!), so
    I can only take the piss from afar. Check whether Elly remembers typing
    an encryption key or string in, if she did that's your problem.
    Take a look at the network properties on her machine. If it says
    anything like "WEP enabled", turn that off and try again. If that fixes
    it, you need to turn it back on and use the same string/key.
    Don't run it unencrypted for any length of time.
    Ewwww....
  6. Lozzo
    Catman Guest
    Not that nearby, but if you want to give me a bell (IIRC Pip has my number)
    or mail me for it, I can almost certinaly talk you down......
    www.cuore-sportivo.co.uk
    Catman, Jul 16, 2005
  7. Lozzo
    Paul - xxx Guest
    Wicked Uncle Nigel came up with the following;:
    It might say WPA-PSK instead.
    One small niggle we had when we set a wireless net up was to set the
    'Transmission Mode'. It came set to 802.11b only, but we had a mix of 11b
    and 11g cards, so that needed changing to 'Auto', as did the Transmission
    Rate before it worked reliably.
    I have a few hundred metres of it left over from when they 'did' our school
    IT [1] suite.
    A cupboard with seven computers ...
    Paul - xxx, Jul 16, 2005
  8. Lozzo
    Cane says...
    Du'h
    I knew I'd done something wrong, thanks Cane.
    <wonders if Catman will stretch across the front of the house and
    through a top-vent window>
    Lozzo, Jul 16, 2005
  9. Lozzo
    Dr Zoidberg Guest
    Several times I've had this sort of problem , and it's usually worked if you
    use the hexadecimal version of the WEP key instead of the plain text version
    (even though it should be ok with the text version)
    Alex
    www.drzoidberg.co.uk
    www.sffh.co.uk
    www.ebayfaq.co.uk
    Dr Zoidberg, Jul 16, 2005
  10. Lozzo
    sorby Guest
    "Rapunzel, Rapunzel! Let down your golden CAT5 cable...!"
    sorby, Jul 16, 2005
  11. Lozzo wrote:
    Hopefully you'll be sorted before then, but I'll be back down your neck
    of the woods on Tuesday night or Wednesday morning and I'll be happy to
    take a look.
    Higgins not @ Work, Jul 16, 2005
  12. Lozzo
    Higgins not @ Work says...
    Oooh, ta.
    Lozzo, Jul 16, 2005
  13. Can't connect, or get nothing through the connection?
    Hang on, what are you tryig to connect to, a router/access point or
    direct to another PC with wifi card?
    hmm, this answers above, I think - the words you might be looking for
    are "internet connection sharing". Except, that it works via cable. hmm.
    Out of interest, this purple cable - what's it plugging into t'other
    end? Elly's PC?
    actually, I don't have a clue what I'm talking about, I'd ignore me IIWY.
    Dnc
    B1200 - +30bhp ~|~ ZZR1100 - tagline being developed
    V2300 - flat cap and rug ~|~ VS800 - borked
    Doesnotcompute, Jul 16, 2005
  14. Lozzo
    Doesnotcompute says...
    Get nothing through the connection
    With Elly's laptop set up with the same settings as my desktop, hers
    works, mine doesn't
    I know and I already did :)
    Lozzo, Jul 16, 2005
  15. good good
    but have you set up the /router/ to allow your mac address?
    so that narrows down the problem to being between you and the router then.
    Story of my life mate.
    Dnc
  16. Wicked Uncle Nigel wrote
    Silly boy.
    steve auvache, Jul 16, 2005
  17. Lozzo
    BGN Guest
    It sounds very much like WEP to me. Lozzo can see the network but
    can't connect to it. He needs to have the same key as the router is
    expecting.
    If Elly doesn't know they key, then get her to set it to a new key and
    you can both use that one.
    BGN, Jul 16, 2005
  18. BGN wrote:
    Excpet they calim to have matched the setting across the two machines -
    I would expect those settings to include entering a WEP key where required.
    but that's assumption for ya...
    Dnc
  19. Lozzo
    BGN Guest
    I think another option would be to make sure the IP/DNS/Gateway that
    Lozzo's WiFi card is assuming the correct settings. I remember a few
    months ago that the Ethernet card and the WiFi cards o na couple of my
    machines were expecting different settings. If he sets his WiFi card
    IP/etc to something like his Ethernet cad is set to, then that may
    sort it out.
    BGN, Jul 16, 2005
  20. Lozzo
    BGN Guest
    FFS. Ingerleesh!
    BGN, Jul 16, 2005
