Wiring-in accessories
Discussion in 'UK Motorcycles' started by Jeremy, May 12, 2006.
  1. Using the patented Mavis Beacon "Hunt&Peck" Technique, Grimly Curmudgeon
    Dunno these days. Have you tried a Rite of Summoning?
    Wicked Uncle Nigel - Podium Placed Ducati Race Engineer
    Wicked Uncle Nigel, May 12, 2006
  2. Jeremy
    Moon Badger Guest
    7) a relay.
    Be fussed about accessories being ignition controlled. Its worth fitting an
    ignition controlled relay as this makes it a doddle for fitting other
    electrical things later like heated grips/clothing. Get a 5 pin and you'll
    also have a separate 12v feed when the ignition is off, should you ever
    need it for things like a flashing red LED ( faux alarm/immobiliser
    warning )
    Moon Badger, May 12, 2006
  3. I'm right out of Rites, no call for them any more and sent them back.
    Hold on, I might have an old one under the desk...
    GS850x2 XS650 SE6a
    Every post contains Nutri-Ceramide-R and Pre-Biotics
    for your reading pleasure.
    Folding@Home Team UKRM
    Grimly Curmudgeon, May 12, 2006
  4. Jeremy
    muddy Guest
    This is how I did it. I also have a powerlet outlet on the left top of
    the fairing to power whatever else I need.
    http://homepage.mac.com/mike.bothe/PhotoAlbum30.html
    muddy, May 12, 2006
  5. Jeremy
    muddy Guest
    I'm here, what's up?
    muddy, May 13, 2006
  6. Jeremy
    raden Guest
    .... But it's Spring
    raden, May 13, 2006
  7. Jeremy
    gomez Guest
    I have a ninety-year old Riot here that might do?
    gomez, May 13, 2006
  8. Jeremy
    Dan L Guest
    muddy wrote:
    That's not a CB radio on your LH Handlebar is it?
    Dan L (Oldbloke)
    Space in shed where NSR125 used to be
    BOTAFOT #140 (KotL 2005/6), X-FOT#000, DIAABTCOD #26, BOMB#18 (slow), OMF#11
    Dan L, May 13, 2006
  9. Jeremy
    muddy said...
    Sweet baby Jesus and the orphans!
    How many more gizmos can you fit to a two wheeled compressor?
    Lozzo, May 13, 2006
  10. Jeremy
    Jeremy Guest
    I can see it's eaier to wire straight to the battery but presumably a
    "better" job would be done if it were linked into one of the circuits
    that was live only when the ignition was switched on - for example using
    a scotchblock connector?
    Anyway off to Maplins for "stuff".
    jeremy
    '01 Triumph Sprint ST in green
    jeremy0505 at gmail.com
    Jeremy, May 13, 2006
  11. Using the patented Mavis Beacon "Hunt&Peck" Technique, muddy
    Oops. Wrong demon.
    Avaunt!
    Wicked Uncle Nigel, May 13, 2006
  12. Using the patented Mavis Beacon "Hunt&Peck" Technique, Jeremy
    Do not, I repeat DO NOT use Scotchlocks. If you want to wire into a
    switched circuit you'll need a relay (as already pointed out).
  13. Wicked Uncle Nigel wrote
    You rubbed Master?
    Damn, my bad, wrong summoner.
    steve auvache, May 13, 2006
  14. Jeremy
    Did you really just use "better job" & "scotchblock" in the same
    sentence? I think you did, didn't you.
    Krusty.
    http://www.muddystuff.co.uk
    http://www.muddystuff.us
    Off-road classifieds
    Krusty, May 13, 2006
  15. Jeremy
    Scraggy Guest
    Wot ee sed.
    Wiv bells.
    'Kin loud wuns.
    Scraggy, May 13, 2006
  16. Jeremy
    Jeremy Guest
    Yes. I did.
    <looks embarassed>
    I think some more knowledge may be required here.
    jeremy
  17. Jeremy
    Jeremy Guest
    Buggrit.
    Trouble is the 12v -> 5v transformer for the PDA draws current as soon
    as it is plugged into the socket so I don't really want it live all the
    time.
    The real problem is that I don't know what a relay is. There, I have
    said it. Having a look now around google seems to suggest that it may be
    a team running event, but I am sure that's not what you meant.
    OK so it's an electrically controlled switch of some kind. What spec do
    I need and how would I wire it in?
    Just returned from Maplins with a bag of bits and pieces to do the job
    and now it looks like I'll have to go out again later :(
    jeremy
  18. Jeremy
    SD Guest
    Not if you wire into your accessory board. :)
    | ___ Salad Dodger
    |_\_____/_| ..79553../..21469.../..31308.
    '^' RBR'06 Points: 75 Miles: 317
    SD, May 13, 2006
  19. Jeremy
    muddy Guest
    No, amateur.
    muddy, May 13, 2006
  20. Jeremy
    muddy Guest
    Fucking off sir.
    muddy, May 13, 2006
